Question about HP Photosmart C6180 All-In-One InkJet Printer
I can not choose to print on photopaper. The papersize "A4" is default, and could not be altered. What shall i do? It is an old computer, and i have not the install-cd left.
  • 604 Answers
When you click "PRINT" a box should open with the choices in it, under paper, ( you may have the default pop up because it is supposed to) you also have to have more than just the driver for the printer installed, there is certain software that pretains to that model of printer, with all the little nuances and choices, plus a bunch of other "bells and whistles" anyway, in that box you should be able to scroll down and choose the type of paper you want to print on the A4 default is the paper size and not the paper type, I don't think you want to change the size of the paper just the type, for instance GLOSSY, HEAVY GLOSSY, etc etc. If you don't see these options, the you should reinstall the software disk that came with your printer, If you have lost the disk you can go to the HP site and go to "downloads" and type in your printer model and find the software download which will be free. good luck
Posted on Mar 24, 2011
Printer will not print 8 1/2 x 11 photopaper, only 4x6. What's the problem?
Have you set in your softwRe the size you want to print, since it standard often is set to a4, just change it under options
Sep 25, 2014 | HP Photosmart D110a Wireless E-all-in-one...
I have a Canon Image runner 1023. when I print i get the message load paper A4, change reg'd size, common settings. and the error light is flashing
Hi
First check the document you are printing from and make sure the paper settings on the specific document are set correctly.Then check the papersize settings on the driver,go to printers and faxes in controll panel,Right click on the ir driver,select printing properties and the printing prefences,change the papersize to the correct papersize.
then check the papersize settings on the machine under the additional usermode.
Clear the job that is stucked in the memory by pressing the monitior button (diamand with a eye sign)select print and clear the job.
Try printing again.
Nov 17, 2009 | Canon imageRUNNER 1023N Black and White...
Problem to feed photo paper
pls... change the a3 photo paper to 230 gsm because the sensor can not load because of the thickness of your photo paper. change it to small gsm.
Sep 29, 2009 | Office Equipment & Supplies
When receiving a fax it won't print because papersize is wrong. received fax is A4, Printer Paper Settings in SetUp is A4.
The sensor for paper size is on the right side of the ink carts. at the bottom. You need to clean the underside of this sensor with a Q-tip dampened with water, and then it will see the correct paper size again...
Jul 14, 2009 | HP Photosmart 2610 All-In-One InkJet...
How do i set paper sizes on my canon ir2016i printer
Open the paper drawer
Remove the paper
There is a blue paper size plate,that keep the paper in the correct posision,Push it to the front and downwarts.The paper plate should come loose from the tray.Put it back in the openning for the A4.The openning for the A4 papersize is mark inside the paper tray.
Now set the blue papersize dail to A4 paper .
Then you are ready to copy with A4 paper.
Feb 19, 2009 | Canon iR 2016i Black and White Copier
TRAY SELECTION
I cant using bypass tray for printing. I set A4 for paper size to every places. But it tells the papersize is mismatch?
Jan 14, 2009 | Toshiba e-Studio163 Copier
I use an HP officejet 6210 and am trying to print some photos onto CanonPR-101 super high gloss paper size A4. It jams each time. Is there a solution?
By studying the print set-up box (for the first time!) I set the printer to the correct photopaper and print quality required, or as near as I could get, and managed to complete the print.Simple really.
Apr 28, 2008 | HP Office Equipment & Supplies
HP Photosmart C6180 All-In-One InkJet Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
