Question about Health & Beauty
I want to block someone messaging me and disturbing.. so how could i block him??
If you want to block sms from a particular person or group of person you have to install extra softwere to your phone . there are lots of software available in the markets for buying. for example www.killermobile.com .there are lots of other mobile software available for your needs.
Posted on Mar 25, 2011
My phone doesnt ring for incoming calls
It can be confusing and frustrating to miss calls because your iPhone isn't ringing. There isn't a single reason why an iPhone stops ringing - but most of them are pretty easy to fix. Try these steps before concluding that your iPhone is broken and needs an expensive repair.
If you're not hearing your iPhone ringing, there are five possible culprits:
  1. A broken speaker
  2. Mute is turned on
  3. Do Not Disturb is turned on
  1. You've blocked the phone number
  2. A problem with your ringtone
Does Your Speaker Work?
The speaker at the bottom of your iPhone is used for every sound your phone makes. Whether that's playing music, watching movies, or hearing the ringtone for incoming calls, the speaker makes it all happen. If you're not hearing calls, your speaker could be broken.
Try playing some music or a YouTube video, and make sure to turn up the volume. If you're hearing audio fine, then that's not the problem. But if no sound comes out when it should, and you've got the volume up loud, it could be that you need to repair your iPhone's speaker.
Is Mute On?
It's always good to rule out the simple problems before diving into more complicated ones. In this case, you need to make sure that you haven't silenced your iPhone and forgotten to turn the ringer back on. There are two ways to check this:
  1. Check the mute switch on the side of your iPhone. Make sure that it's turned off (when it's turned on, you'll be able to see an orange line inside the switch).
  1. On your iPhone,go to Settings and tap Sounds (or Sounds & Haptics, depending on your model). Make sure the Ringer and Alerts slider isn't all the way to the left. If it is, move the slider to the right in order to turn up the volume.
Is Do Not Disturb On?
If those aren't the problem, it could be that you've enabled a setting that mutes phone calls: Do Not Disturb.
This is a great feature of the iPhone, introduced in iOS 6, that allows you to stop sounds from calls, texts, and notifications when you don't want to be bothered (while you're sleeping or in church, for instance). Do Not Disturb may be great, but it can also be tricky - because you can schedule it, you may forget that it's enabled. To check for Do Not Disturb:
  1. Tap Settings.
  2. Tap Do Not Disturb.
  3. Check to see if either the Manual or Scheduled sliders are enabled.
  4. If the Manual is enabled, slide it to Off/white.
  5. If Scheduled is enabled, review the times Do Not Disturb is scheduled to be in use. Did the calls you missed come in during those times? If so, you may want to adjust your Do Not Disturb settings
  6. If you want to keep Do Not Disturb but allow calls from some people to get through no matter what, tap Allow Calls From and select groups of contacts.
Is the Caller Blocked?
If someone tells you they called you, but there's no sign of their call on your iPhone, maybe you've blocked their number. In iOS 7, Apple gave iPhone users the ability to block phone calls, FaceTime calls, and text messages. To see whether the number that someone is trying to call you from is blocked on your phone:
  1. Tap Settings.
  1. Tap Phone.
  2. Tap Call Blocking & Identification (it's simply Blocked on earlier versions of the iOS).
On that screen, you'll see all of the phone numbers you have blocked. If you want to unblock a number, tap Edit in the top right corner, tap the red circle to the left of the number, and then tap Unblock.
Is There a Problem With Your Ringtone?
If your problem still isn't solved, it's worth checking your ringtone. If you have an iPhone custom ringtone assigned to contacts, a deleted or corrupted ringtone can cause your phone not to ring when someone calls.
To address problems with ringtones, try these two things:
1. Setting a new default ringtone. Here's how:
  1. Tap Settings.
  2. Tap Sounds (or Sounds & Haptics).
  3. Tap Ringtone.
  4. Choose a new ringtone.
2. You should also check to see if the person whose calls you're missing has an individual ringtone assigned to them. To do this:
  1. Tap Phone.
  2. Tap Contacts.
  3. Find the person's name and tap it.
  4. Tap Edit in the top right corner.
  5. Check the Ringtone line and try assigning a new ringtone to them.
If the unique ringtone seems to be the source of the problem, you'll need to find all the contacts that had that ringtone assigned to them and select a new ringtone for each. It's tedious but necessary if you want to hear those calls as they come in.
If None of This Fixed the Problem
If you've tried all of these tips and still aren't hearing your incoming calls, it's time to consult the experts. Make an appointment at the Apple Store and bring in your phone for inspection and, potentially, repair.
Dec 14, 2017 | Lands Phones
Why does my mobile phone not ring when someone calls me. It goes straight to message centre
You may have accidentally turned on Do Not Disturb mode. In the top right corner of the screen, is there a tiny icon that looks like a crescent moon? If it's an i-phone, go to settings, and in the second group of items, make sure that Do Not Disturb is turned off.
Jul 09, 2017 | Cell Phones
How do I block a number, and report harrassment
Just install a callblocking apps n get rid of unwanted calls.
Feb 12, 2015 | LG Cell Phones
HOW TO BLOCK UNWANTED MESSAGES SEND BY VODAFONE
Knight
I searched for 2hrs and didnt find a way to block it out on your side.. only info was to contact the service and see if they have a way to stop it on their side.
Sorry
Chadman
Nov 22, 2014 | Samsung Galaxy Cell Phones
When someone calls messae says' not accepting calls' how do i turn this off
Does this happen on all inbound calls or just some?
If this is on all inbound calls...Sounds like Do not disturb is turned on. Most uniden's have a DND (do not disturb) mode. Try turning this off and see if that helps.
Using Do Not Disturb
  • The Do Not Disturb or DND feature turns off the audio ringers of the base and all handsets at the same time. It does not affect any of the visual ringers.
  • With the phone in standby, press and hold Do not Disturb on the base. The phone automatically turns on the answering system and shows Do Not Disturb in the display on all handsets.
  • To cancel, press Do not Disturb.
If this is not the issue, it may be turned on at the central office (your phone company) try using the DND activation/deactivation code of *64 from your phone.
If this is just on some inbound calls...Then it you may have anonymous call rejection turned on. That feature blocks calls from people that block their calling number when placing calls.
Mar 01, 2012 | Uniden DECT 6.0 Cordless Phone ID
To block a particular no. in my nokia 3310 model
get a number screening software and add that number so that the calls and messages will be blocked by software u can get the software from ovi suite ovi store
May 23, 2010 | Nokia 7310 Cellular Phone
Program "Do not disturb" on business phone
It's pretty straightforward. You pick a spare button, dial FEAT 00 press the blank button (with a light) and press FEAT 01. There are considerations that I'll reproduce here.
Do Not Disturb (F01) 8
Use this feature to be able to press a programmed button to prevent incoming calls for the
extension from ringing (lights still flash). When Do Not Disturb is on, outside callers hear ringing
while inside callers hear a busy signal. You should use Do Not Disturb only if someone answers
outside calls for your extension when you do not answer them.
Considerations 8
Do Not Disturb is available only on system telephones.
Do Not Disturb requires a button with lights. When the Do Not Disturb feature is on, the light
is also on, indicating that the telephone will not ring.
■ Use Do Not Disturb when you do not want the auto attendant or the voice messaging system
to transfer calls to you.
■ Use Do Not Disturb if you are assigned to a Hunt Group and you leave your desk, so calls to
the Hunt Group will skip your extension and ring immediately at the next available extension
in the group.
■ To avoid missing calls when Do Not Disturb is not needed, turn it off.
■ If Do Not Disturb is active at a doorphone alert extension, the person at the doorphone hears
signaling, but the alert extension is not signaled.
■ Unanswered calls that are transferred from an extension with Do Not Disturb active ring at
that extension if they transfer return.
■ Extensions with Do Not Disturb activated do not receive Caller ID information, unless the call
is answered.
■ Users with Automatic VMS Cover Assigned or with VMS Cover turned on can activate Do
Not Disturb
to Send All Calls immediately to their voice mailbox.
■ Users with Call Coverage turned on can activate Do Not Disturb to Send All Calls
immediately to the covering extension.
■ You cannot use Call Screening (F25) when Do Not Disturb is turned on.
Carl
May 10, 2010 | Lands Phones
Blocked calls?
it sounds like you have the DND or do not disturb button down
Feb 13, 2009 | Comdial 8324S-PT Corded Phone
Health & Beauty Logo
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Marvin
Marvin
Are you a Health and Beauty Expert? Answer questions, earn points and help others
