Question about Fujitsu AMILO PC Laptops
Time and date always need to be reset - Fujitsu AMILO PC Laptops
DATE -TIME RESET??
What seems to be the problem with the date and time?
If you want to change the date and time settings, then you can click on the time on the bottom right corner of your screen. There you can change the time and date settings.
Or if date and time are always changing whatever you do then you would need to change the CMOS battery of your computer.
David
Jun 10, 2013 | HP Compaq Presario V2000 Notebook
After battery change on my 2001 avalon the time/date reset to default even I set the time/date correctly then turn off the ignition and turn back on again then the time/date reset to default again .
If some connections were changed then the ALWAYS ON +12 volt to the clock circuit back up is not powered all the time . check if while the battery was changed if there was any link that was disconnected that is the continuous supply to the clock.
Jul 02, 2011 | 2001 Toyota Avalon
How do I keep the date correct?? It alway pops up
Next time you finish setting it, press the set/ok button twice.
Apr 01, 2010 | Polaroid A500 Digital Camera
Camera resets DATE and Time to Jan 2002 when
Some of these cameras cannot save the date, and has no internal battery to save the data. The best solution I have use is to buy another battery with these kinds of cameras and always have one charging, or take two batteries when you take pictures.
These older point and shoot cameras are nice, and slower than the newer ones, but will not save the data unless you keep the main battery in it, or replace the one to be charged with another battery within a very short time.
Sep 27, 2009 | Nikon Coolpix 4300 Digital Camera
I have a panafax uf-550 that won't print a confirmation page. I need to reset the correct date and time on the panafax uf-550
Time and Date
function-7-1-start- adjust the time and date hit start then stop
comm journal
function-7-4-start-1-2-start-2"should say always"-start-stop
your time on incomming fax
function-7-4-start-9-start-2"should say valid"start-stop
Apr 21, 2009 | Panasonic Office Equipment & Supplies
At start up i always have to input the date &time etc why?
You have to change the on board battery.
Thanks, PREM
Mar 29, 2009 | Dell Latitude C610 Notebook
Batterie
Your internal CMOS battery(button battery) needs to be replaced. That keeps your date & time always working. Therefore when your main Battery runs out and external power is not present the date and time goes back to the date of manufacture.....sodeep
Mar 24, 2009 | Computers & Internet
Date and time wrong on the journal
to reset the time and date on the machine you need to hit
Time/date
Function-7-1-start- then adjust the time and date and hit start then stop
Com journal after every fax
Function7-4-start-1-2-start-2"should says always" then start stop
receive time print." puts the time and date of your machine of the fax..example if your receiving a fax from new york and your in california it will put your time and date at the bottom.
Function7-4-start-9-start-2"should say valid" start then stop.
as for why your losing your time and date all the time is because the battery if dead on the machine.
hope this helps.
Jan 07, 2009 | Panasonic Panafax UF-585 Plain Paper Laser...
Clock always reset to default upon power up
Either the replacement battery was dead or the camera needs to be serviced. If the date/time needs to be reset every time the camera powers up, the camera is not receiving the power it needs from the date battery.
May 04, 2008 | Canon PowerShot S5 IS Digital Camera
Fujitsu AMILO PC Laptops Logo
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
