Question about Koss KS3102 System
Pal/ntsc i hit this button and now my tv is black and white and rolling and i cant access button to put it back to regular setting. how do i get back to my menu and put it back the way it was? thanks Barbara
  • 1 more comment
  • newmoonangel Aug 03, 2008
    hi i should of added that i can see the menu button its just that the tv is rolling so fast i cant see what button i am pushing, it saids in manual that it should reset itself but its been on for a hour and i still cant see it to see what i am doin..
    thats what i did i hit the pal instead of the ntsc..
  • jovett Nov 26, 2008
    I am the same problem...hope someone can help us.
    I
  • Anonymous Jan 01, 2009
    I have the same problem, I can't get back to menu to get out of this problem. seems like the device is locked , tried everything. please contact me if you solve this.
  • Koss Master
  • 5,568 Answers
Those are the two common standards; PAL is used in Europe, NTSC in the US and they use different synchronization and resolutions which is causing your problem although it would seem that the menu should still appear since that is an internal function.
I suggest you email or call Koss for a suggestion; I don't believe you are the only one who has done this.
You might try pulling the plug overnight to see if the set will default to NTSC but as most sets today, it probably will remember the last settings and to access the area where this is stored is not a job for users.
A TV shop (if you can find one) will likely have a TV signal generator that can produce both standards and this will enable them to reset to NTSC.
Posted on Aug 03, 2008
  • Steve Allison
    Steve Allison Aug 03, 2008
    I'd still try pulling the plug overnight to see if it will default to NTSC since I suspect their sales are still greater in the US than across the pond.
My tv has gone black and white I dont know how to get the colour back
check color system matches . If tv uses PAL then DVD player needs to be set to PAL. If TV station uses PAL then set devices to PAL. If TV station uses NTSC set devices to NTSC for color system.
Aug 06, 2015 | Televison & Video
The tv is connected to a dvd player and someone was playing with the buttons, now the picture wont stop rolling
It is possible that the MODE of TV SYSTEM was shifted possibily from PAL to NTSC and so the pciture can roll or be in black & white.
So open the menu and check the settings, look for TV system , colour system and change.
Jul 21, 2011 | Sansui 19 in. LCD TV
Just setting it up. the picture is rolling and it
It occurs if the system colour on your tv is set to PAL, and your Wii is NTSC.. To Fix.. Adjust the system color on the tv to NTSC.
Hopefully this help..
Jan 18, 2010 | Nintendo Wii Console
How to make PAL region code 2 dvd's work on a regular tv
The tv in U.S. and Canada can't set in the play pal mode.Only in NTSC mode.
Aug 13, 2009 | GPX D1816 DVD Player
The display screen is rolling and is in black and white.
Hi
You switched to PAL mode from NTSC or vice versa. Most DVDs will only output PAL or NTSC, not both. So even if the disc is region ffree, the fact that it's encoded in PAL (50hz) makes it appear like you describe - no vertical hold / black and white.
Some set top players [Apex, Phillips] will convert PAL to NTSC on the fly or vice versa.
Remember, PAL/NTSC is not the same as Region.
Here's some detailed info:
http://www.michaeldvd.com.au/Articles/PALvsNTSC/PALvsNTSC.asp
http://www.sjbproductions.com/web_pages/tip_video/ntsc_pal.htm
http://www.dvdcity.com/codefree/codefree-ntsc-info.html
You can convert the DVD to NTSC, and strip the region code by following http://www.videohelp.com/guides/how-to-convert-interlaced-pal-dvd-to-ntsc-dvd-id1107#1107
-or-
http://forum.videohelp.com/topic221928.html
[This is very time consuming.]
You
What DVD
Most players are either NTSC or PAL, however increasingly DVD players from the Far East (Apex, Phillips etc)
, which is 50hz instead of 60hz, hence the lack of vertical hold
Mar 23, 2009 | Televison & Video
When I hook my playstation 2 to my trutech tv, it plays in black and white. How do I get it to play in color?
You need NTSC TO PAL converter or a RF converter for this problem.
your console must be of NTSC type and your TV PAL type or vice versa.
check your tv settings to change from pal to ntsc to get color. Mostly modern TV sets would have the settings to change on their remote controller from ntsc to pal, secam etc.
Dec 18, 2008 | Bethesda Softworks Black & White
New Nintendo Wii
check you've got it on the right PAL/NTSC setting.It's very likely the 50/60hz setting. 480i running at 60hz is NTSC resolution although the PAL Wii of course uses the PAL signal. The TV probably tries to interpret the signal as a real NTSC signal because it's 480i 60hz and thus can't handle the colors. There has got to be an option to switch between NTSC and PAL.
Are you using the same SCART socket that you use for your other consoles or a different one? My SCART3 input on my Panasonic telly has two different modes - one which displays in colour, and one which displays in a sort of grainy black n' white. There is a purpose to it but I can't remember what it is. :-)
Anyway, you switch between the two by pushing the AV button and then hitting the colour button which corresponds to SCART3 a few times 'til you reach the correct setting.
It probably isn't that, but... y'know. Sanity check.
Oct 23, 2008 | Nintendo Wii Console
TV plays color, dvd black and white
If I understand your post/description, the DVD plays OK except it is in Black & White. If so, change setting from PAL to NTSC or vice versa depending on the region you are in. US operates on NTSC, Most of Europe is PAL.
Hope that this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Jan 19, 2008 | Jwin Electronics JD-VD138 DVD Player
PLEASE HELP
there is a ntsc/pal botton on your remote press that and it sould go back to normal if its not onthe remote try to go in the settings and it will ce in there someware
Jan 17, 2008 | GoVideo R6640 DVD Recorder
Black & White picture
There can one of two problems here. Either your DVD player's output is set to NTSC and you are attempting to play it through a PAL (European) TV, or you are perhaps using the SVHS output incorrectly. The solution is to access the player's setup menu and ensure the video output is set to your standard (PAL or NTSC). Hope this helps!
Feb 14, 2007 | Philips DVP642 DVD Player
Koss KS3102 System Logo
89 people viewed this question
Top Koss Audio Players & Recorders Experts
Steven Wander
Steven Wander
Carlos L. Burgos
Carlos L. Burgos
Michael Galve
Michael Galve
Are you a Koss Audio Player and Recorder Expert? Answer questions, earn points and help others
