SOURCE: strange noise, no heat
Sounds like the magnatron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnatron is about 95% of the cost of a microwave oven.
Most people don't, for this reason, replace the magnatron, they replace
the whole oven.
There is a possiblity that the circuit that provides power to the
magnatron is faulty and you need to take it apart, find the proper
electrical leads and test them with a volt meter. To do this you have
to remove it from its mounting and take it appart. It is a fairly
lengthy process however.
SOURCE: HAVE A SAECO TALEA RING
Click on the link below to access the Saeco Talea Ring Plus Coffee Maker user guide, the error codes are listed on page 29:
http://www.saeco-usa.com/download/pdf/manuals/talea-ring-plus-en.pdf
SOURCE: My delonghi eam3200s coffee machine
This unit uses 220v, which is two 120 lines, so it's possible that one side of the power could have shorted out at the main switch.
Also, it sounds like a thermistor could have shorted out, and thrown the breaker. I don't think it's a fuse, since most of it works. You will have to open the unit up and investigate, but look for a metalic, roundish device- it will be the thermistor. It might be discolored, or brownish in color due to the shorting out.
Don't know if you need it, but here is a link for the manual:
http://www.ps2netdrivers.net/magnifica/delonghi.eam3200/
Couldn't find anything specific on the problem, but hope this helps.
SOURCE: I have a deLonghi Magnifica
Hello scuzz. I recommend calling Delonghi directly:
Contact Center
1-877-882-8604
Monday - Friday
8am - 8pm EST
They will tell you how to send it in for a repair and whether or not it is under warranty. Joe
Thanks for choosing Fixya!
SOURCE: This morning when my wife
I know this sounds like a pain but it takes a while to get that silly light to stop.
If you have problems call the 1-800 number below.
Decalcifying your MR. COFFEE® Coffeemaker Minerals (calcium/limestone) found
in water will leave deposits in your coffeemaker and affect its performance. It's
recommended that you regularly remove these deposits using MR. COFFEE® Cleaner
or vinegar. MR. COFFEE® Cleaner is available at many retail stores or by calling the MR.
COFFEE® Consumer Service Department at 1-800-MR COFFEE (1-800-672-6333).
1. Follow package instructions to prepare one batch of MR. COFFEE® Cleaner. Pour the
mixture into the water reservoir. Before decalcifying, remove the water filtration disk
from the machine.
NOTE: 4 cups or 20 fl. oz. of undiluted, white household vinegar may be used as a
substitute for the cleaner.
2. Place an empty MR. COFFEE® 10-12 cup basket-style paper filter
or MR. COFFEE® permanent filter into the filter basket and slide
the brew basket in place.
3. Place the empty decanter back in the unit.
4. Press the CLEAN button until the CLEAN indicator light turns on
(Figure 9). For your convenience the cleaning cycle is automatic.
The entire cycle will take 45-60 minutes to complete.
During the cleaning your coffeemaker will:
a. Slow brew approx. 3 cups of cleaning solution.
b. Pause for 30 minutes (the CLEAN light will remain on to alert
you that the process is active).
c. After 30 minutes, your coffeemaker will brew the remainder of the cleaning
solution.
d. When complete, the CLEAN light will turn off and your coffeemaker will turn off.
5. Discard the cleaning solution and rinse the decanter thoroughly with clean water.
6. Fill the water reservoir with clean, fresh water.
7. Place the empty decanter back on the coffeemaker.
8. Remove and discard the paper filter used during the cleaning cycle. If a Mr. Coffee®
permanent filter was used during cleaning, remove it and rinse it thoroughly before
replacing it in the filter basket.
9. Begin brewing and allow the full brew cycle to complete.
10. Repeat steps 5 through 9 one more time.
Testimonial: "Thank You Whispis2 ! I will surely clean the unit as described. Hopefully the light will turn off.Thanks again !! Dave"
If you were to log on to the
manufacturer's web site, I think you will be pleasantly surprised as
usually one is able to download, by model number, Customer
Instruction Manuals, and a list
of Dealers for spare parts, as required.
Just Google the manufacturer's name and
follow the links. Make certain you are directed to the manufacturer's
web site as some search engines direct you to other sites and they
charge for the information that is normally free of charge.
I
hope this helps.
