Question about Bosch Classixx WFL 2066 Front Load Washer
The cycle has finished but the code F04 is flashing and it looks as if there is water still in the machine. I had noticed a strange noise when it was spinning.
    Brigadier General:
  • 6,277 Answers
'F04'- taking too long to drain water!
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 24, 2011
Tip
Wet cloths or error F04
I could not find anything on the internet above this error, the reason for this.
Machine runs fine and completes the cycle with no error, but with 1 fault, cloths are still wet. just once it showed error F04.
I noticed that:-
1. the drum did not spin fast
2. water was draining out of the outlet pipe but at a slow rate
Fix:-
water pump access at the bottom right of the machine was blocked with coins and a plastic strip, cleaned and all working again.
Did not expect the pump to be the fault as water was coming out the outlet pipe.
on Jun 05, 2018 | Whirlpool Washing Machines
Machine stopped in middle of cycle ,wash flashing something on screen, tried to restart wont't run water could it be out of level for it not to run water
It's probably flashing an error code. Write down the code and look it up in the owners manual or online to find out what the issue is.
Aug 17, 2014 | Samsung WF328AA Front Load Washer
Have a Bosch Exxcel - error code F04 comes up half way through cycle - cleaned filter...still not resolved. Any ideas?
washing machin pipes were frozen in garage, defrosted now. done one wash half way through, error f04 came up. water still in machine and it makes a noise when trying to spin. The fillter knob has broken and i can't undo it to clean it out.
Oct 15, 2009 | Bosch Exxcel WFO 2264 Front Load Washer
Kenmore HE 3t started leaking from the side when filling
check dispencer and make sure its not cracked,,if not turn your water pressure down to the dispencer its splashing up and over running down..keep me posted onthejob
Jan 12, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Will not go into tumble action
Because F04 is not a clearly defined failure, the possible cause of your situation is a timer, a lid switch, a belt, a drive motor, or an agitator.
Solution, before proceeding watch your timer (does it follows its cycle?) if no replace timer, if yes, then check your lid switch replace if defective, check your belt if it broken or worn replace it, check your drive motor for functionality, and check your agitator--your agitator can become worn, strip out the spline that allows it to properly grip the shaft.
Jul 07, 2008 | Frigidaire ATF6000ES Front Load Washer
No longer spinning/loud noise
Did all the standing water pump out?? If sou you may have broken a drive coupling
Jan 22, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Bosch Classixx WFL 2066 Front Load Washer Logo
57 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
