My msgbox is locked,,,,,can u help me out - Computers & Internet
  • 53 Answers
COM 0R MOBILE
Posted on Mar 24, 2011
How to Make a Popup (for Windows)?
Open Notepad (Start>Programs>Accessories>Notepad).
Copy and paste the following text into the program: lol=msgbox("",16,"Error")
26319026-bxzhjmonsmllydp0qa2riq2g-2-2.jpg In between the two adjacent quotation marks, type the error message you wish to appear in the popup (eg. lol=msgbox("Example",16,"Error")).
Click File>Save As. 26319026-bxzhjmonsmllydp0qa2riq2g-2-9.jpg In the 'Save type as' dropdown, change the setting from 'Text Documents' to 'All files'. Then, as your file name, type your file name (when you open the file, it will trigger the popup), followed by '.vbs' (eg. Example.vbs). Then, in the 'save in' dropdown, select a place where you can access your file. When you have selected your desired place to save the file, click 'save' to save your file.
Open 'My Computer' (Start>My Computer) and find your newly-created file.
Open the file, and your error message should pop up on the screen!
Oct 20, 2016 | Microsoft Computers & Internet
18. A palindrome is a string that reads the same
here is a little vbscript sample str=InputBox("Type String To check For palindrome","")
strR=StrReverse(str)
half=Int(Len(str)/2)
If Left(str,half)=Left(strR,half) Then
    MsgBox ("It's a palindrome string")
Else
    MsgBox ("It's not a palindrome string")
End If
Jun 05, 2010 | Computers & Internet
The fallowing script says VBScript runtime error: Path not found if the directory dose not exsists. However the point of the script is to check if the directory exists and if not create it. Option...
I have the solution.
You must create each subfolder in every folder.
Check this script that is working and you must just to adjust for your needs:
Option Explicit
Dim LocalDir
Dim ServerDir
Dim LocalDisk
Dim oShell
Dim strUserName
Dim strHomeDrive
Dim objNetwork
Dim objFSO
Set objNetwork = WScript.CreateObject("WScript.Network")
strUserName = objNetwork.UserName
Set oShell = CreateObject("WScript.Shell")
strUserName = oShell.ExpandEnvironmentStrings("%USERNAME%")
strHomeDrive = oShell.ExpandEnvironmentStrings("%HOMEDRIVE%")
LocalDir = strHomeDrive&"\E810\PD810\Export"
REM msgbox(strUserName)
REM msgbox(strHomeDrive)
REM msgbox(LocalDir)
ServerDir = "\\epcdhe.com\public\profiles\"&(strUserName)&"\E810\PD810\Export"
Set objFSO = CreateObject("Scripting.FileSystemObject")
If objFSO.FolderExists(LocalDir)=false Then
objFSO.CreateFolder(strHomeDrive&"\E810")
objFSO.CreateFolder(strHomeDrive&"\E810\PD810")
objFSO.CreateFolder(strHomeDrive&"\E810\PD810\Export")
End If
If objFSO.FolderExists(ServerDir)=false Then
objFSO.CreateFolder("\\epcdhe.com\public\profiles\"&(strUserName)&"\E810")
objFSO.CreateFolder("\\epcdhe.com\public\profiles\"&(strUserName)&"\E810\PD810")
objFSO.CreateFolder("\\epcdhe.com\public\profiles\"&(strUserName)&"\E810\PD810\Export")
End If
May 26, 2010 | Computers & Internet
How to get MsgBox function on Form
This question is way too generic but in Visual Basic 6 for example you would just call the function from a method such as:
sub buttonclick()
msgbox("Hello World")
end sub
May 07, 2010 | Microsoft Computers & Internet
How to create an object of VSI-Fax like in winfax
For VB
Private Sub Form_Load()
Dim sendObject As Object
Dim ret As Integer
Set sendObject = CreateObject("Winfax.SDKSend")
ret = sendObject.SetSubject("TEST!!!")
If (ret = 1) Then
MsgBox ("SetSubject Failed")
End
End If
ret = sendObject.SetKeywords("Test")
If (ret = 1) Then
MsgBox ("SetKeywords Failed")
End
End If
ret = sendObject.SetResolution(0)
If (ret = 1) Then
MsgBox ("SetResolution Failed")
End
End If
ret = sendObject.SetQuickCover(1)
If (ret = 1) Then
MsgBox ("SetQuickCover Failed")
End
End If
ret = sendObject.SetCoverText("This is a Test.")
If (ret = 1) Then
MsgBox ("SetCOverText Failed")
End
End If
ret = sendObject.SetUseCover(1)
If (ret = 1) Then
MsgBox ("SetUseCover Failed")
End
End If
ret = sendObject.ShowCallProgress(1)
If (ret = 1) Then
MsgBox ("ShowCallProgress Failed")
End
End If
ret = sendObject.SetTo("Somebody")
If (ret = 1) Then
MsgBox ("SetTo Failed")
End
End If
ret = sendObject.SetNumber("#######") 'My fax number
If (ret = 1) Then
MsgBox ("SetNumber Failed")
End
End If
ret = sendObject.SetAreaCode("###") 'My area code
If (ret = 1) Then
MsgBox ("SetAreaCode Failed")
End
End If
ret = sendObject.SetPriority(1)
If (ret = 1) Then
MsgBox ("SetPriority Failed")
End
End If
ret = sendObject.AddRecipient()
If (ret = 1) Then
MsgBox ("AddRecipient Failed")
End
End If
ret = sendObject.LeaveRunning()
If (ret = 1) Then
MsgBox ("LeaveRunning Failed")
End
End If
ret = sendObject.GetRecipientCount() 'this shows 1
MsgBox ("Recipient Count: " & ret) 'recipient
ret = sendObject.Send(1)
If (ret = 1) Then
MsgBox ("Send Failed")
End
End If
End Sub
If u like that Appreciate me by giving vote.
And try to be little specific while u ask question, that means, if u want code on any object ask for which language u r in need of?
Oct 19, 2009 | Esker VSI-FAX 4.x (25301) for Unix
An example of visual basic program
Visual Basic (VB) is the thrid generation event-driven programming language and integrated development enviorment (IDE) from Microsoft for its COMprogramming model. VB is also considered a relatively easy to learn anduse programming language, because of its graphical development featuresand BASIC heritage.
Here is an example of a code that displays a message box "Hello, World!"
as the program runs:
Private
Sub Form_Load()
MsgBox "Hello, World!"
End Sub
simply making duplicated lines of text and changing the words in the
speech marks can draw a different text and ammounts.
For example:
Private
Sub Form_Load()
MsgBox "Welcome, blue_skies61!"
MsgBox "My name is Siwek06!"
End Sub
you can also bold the text by puting this line before a text:
Sub SetFontBold()
Overall i think this is a easy language to learn.
Go on to microsoft.com help center, or the forums to learn more.
Feb 23, 2009 | Visual Land V-Touch Digital Media Player
How do you check a Text File is empty or not in vb6.0
Here is a script that shows you how to do this
On Error Resume Next
Dim fso, s
Set fso = CreateObject("Scripting.FileSystemObject")
Const ForReading = 1
Set ts = fso.OpenTextFile("c:\testfile.txt", ForReading)
s = ts.ReadAll
ts.Close
if len(s) = 0 then
msgbox "File is Empty"
else
msgbox len(s) & " " & s
end if
Nov 07, 2008 | Computers & Internet
Password
Hello, if you are using a vb program, i know a code that will allow you to make a password protect your programs. But you are prompt to enter it in every time you start the program.
passwordbox = InputBox("Please Enter Key")
If passwordbox = "Put Your Password Here!" Then
MsgBox "Welcome!"
Else: MsgBox "You have entered the wrong password"
Unload Me
End If
End Sub
You can try this. Hope this can help you in some way :)
Feb 29, 2008 | Computers & Internet
Program
I wrote this as a vbscript. It's Visual Basic code in windows script. If you have XP, just copy the text into notepad and save it as "vowel.vbs". Now double click the newly created script file.
' vowel.vbs
' This VBScript is used to count the vowels and consonants in a string.
' Designed and Tested on Windows XP Pro SP2
' Version 1.0.0 - 02.20.2008
' This code may be freely distributed or modified.
Option Explicit
Dim str
Dim vowels
Dim consonants
Dim i
vowels = 0
consonants = 0
str = "hello"
for i = 1 to len(str)
select case mid(str,i,1)
case "a"
vowels = vowels + 1
case "e"
vowels = vowels + 1
case "i"
vowels = vowels + 1
case "o"
vowels = vowels + 1
case "u"
vowels = vowels + 1
case else
consonants = consonants + 1
end select
next
msgbox "Vowels = " & vowels
msgbox "Consonants = " & consonants
'End of script.
Feb 21, 2008 | Computers & Internet
Hi........
' vowel.vbs
Option Explicit
Dim str
Dim vowels
Dim consonants
Dim i
vowels = 0
consonants = 0
str = "hello"
case "a"
vowels = vowels + 1
case "e"
vowels = vowels + 1
case "i"
vowels = vowels + 1
case "o"
vowels = vowels + 1
case "u"
vowels = vowels + 1
case else
end select
next
'End of script.
Feb 21, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Computers & Internet Logo
13 people viewed this question
Alun Cox
David Payne
David Payne
