Question about Maytag Neptune MAH5500B Front Load Washer
Neptune washer front load may4000awq
We have a neptune front load washer that wont spin. when i start the machine it starts filling with water then shuts off after 30 seconds, the door lock lite not on. turn to rinse, pump comes on, door lite lock lite on, water pumps out. turn dial to spin, pump comes on, door lock lite not on, no movement off tub. tub spins free by hand
  • 1 more comment
  • 83subby Aug 03, 2008
    i,m sorry for not telling you, but the belt is fine.
  • j_arzaga73 Aug 07, 2008
    i have the same problem- the washer will not spin- the water fills up then turns off.
  • linedry Aug 11, 2008
    I have the same problem! Washer turns on, fills then shuts off 30 seconds into the cylce. Basket will not turn on any function, yet all functions as normal except the basket not turning. Belts and pulley look fine. Western Mass Calling for help!
    An expert who has written 2 tips or uploaded 1 video tip.
  • 24 Answers
Check your washer belt has not slipped off.
Just so you know thats not the problem.. Ours went ga ga and it was only the belt!
Posted on Aug 03, 2008
  • mommasuec Aug 04, 2008
    Its one for the big boys on here then.. Wouldnt it be wonderful if everything was easy?
    All the best with it love, and I hope you get it sorted really quickly.
    Sue x
Washer starts/ stops
recycle power. if problem persists, timer problem
Mar 18, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytage MAH6500AWW Overloaded washer now leaks when filling
since you can drain it
take off the back and watch what happens when u turn it on
i believe you make have a loose drain connection
Oct 09, 2009 | Maytag MAH6500 Neptune Front Loading...
No spin
If anyhow the drain pump is blocked the spinning will be blocked. Check for a forrign object in the drain pump. If you can feel/hear it buzz (very quietly) while it should be pumping out it might be jammed up with something. That however is kind of rare with the angled tub the Neptune uses.
Are you sure the machine is actually not pumping out, or is it possible its just turning off in the rinses?
Reason I'm asking is the control will shut the machine down if its taking too long to fill up. Many times it will fill fine for the wash fill, but because the rinse takes twice the ammount of water it activates the system and shuts down while its half way filled. Look for a slow cold water fill for that problem.
Is the door locking in the spin? One very common problem on the older 3000 and 4000 series machines is the R11 resistor on the machine control board bruning out leaving the door lock inoperative. If the door won't lock, it won't spin. I do believe, however, the machine will still pump out. But many times what happens is the pump removes all the standing water, but without spinning everything in the tub stays soaked. The saturated clothing drains the water out and then leaves a few inches in the bottom of the tub.
If you have the newer style Neptune (with the control panel on the front of the machine) only the top paragraph applies.
Thank you Sir, Have a nice day.
Sep 21, 2009 | Maytag Neptune MAH5500B Front Load Washer
Sometimes there is water that fills in my washer after I use it. It does not happen right away but by the next day. I don't know the model but I do know this is an old have had it for...
Q - My washer seems to keep filling  with water, the water keeps coming in the washer and going out the drain without the washermotor running.
A - This often is a drain hose that is too low or a drain hose that has been pushed too far down inside the stand pipe....the water is actually siphoning out of the washer. Do not "seal" the drain hose to the house plumbing pipe, this will also allow the water to be siphoned out.
  1. Boot change helps
  2. Consumer Display Code Table on the Electronic Display Maytag Neptune Front load washer
  3. Free on-line repair manual for the Neptune washer MAH3000, MAH4000, MAH5500, MAH7500  ( Acrobat reader required )
  4. How to access the console on the mechanical timer models
  5. How to access the workings of the washer
  6. My washer door is locked and it will not open up...HELP
  7. My washer will start when I push the start button, but a few seconds later, it will shut off
  8. My washer will not pump out + pump noise problems
  9. My washer will not spin
  10. Odor complaints from the front load Neptune washer - mildew complaints + a new "freshen up" procedure
  11. Parts breakdowns/exploded of the Maytag Neptune front load washer ( mechanical timer models )
  12. Problem chart for MAH3000 & 4000 Neptune washers
  13. Readers repair tips
  14. Trouble shooting tips from the Neptune manual for MAH3000 and MAH4000 models
  15. Tips from our friendly engineer on changing the boot and re-installing that clamp and spring
  16. Tips on changing the washer belt  ( acrobat reader required ) Belt parts link
  17. Tips that show what components need to be checked/replaced if a certain resistor on machine control board is bad. It is as follows: Burnt resistors in Maytag Neptune washer models MAH4000 and MLE/MLG2000
  18. Washing one item in a front load washer
Apr 01, 2009 | Maytag Washing Machines
Maytag Neptune MAH-1 won't stop filling with water
A couple things may be going on here... you may not want to hear, but the Neptune has a had many "consumer related problems".
If your complaint is "will not stop filling with water" I would access your inlet water-valve (typically blue with 2 black battery looking solenoids; where your water-lines connect directly), test for continuity and replace as necessary. Sometimes inlet-water valves also go bad where the complaint is: "no water comes in at all".
Jan 26, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Washer MAH3000AWW
This is out in cyberspace Cant remember what or where. Do a search for "Maytag Neptune shuts off"
Sep 17, 2008 | Maytag Neptune Washer
Washing machine it shuts down water filling cycle
First thing to check is the filter,
open the bottom pane (3 screws on bottom front lip)
in the cent is a large removable filter ,
set a pan or rags under it ,there will be water.
clean out any debris an be sure the pump impellers move freely.
let me know if that fixes it.
Jan 29, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Washer wont run
Try using the spin only function with some water in. To see if it runs, & to wake up the machine.....
Aug 19, 2006 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
239 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
