Question about Samsung CLP 300 Laser Printer
Smearing of printed image in color printing mode
  • 604 Answers
Many times this problem is caused by the type of paper being used, especially with photos, try a different paper, or change the type of paper in the print box when you try to print. the amount of toner used is determined by the paper type. if you are printing on glossy paper you might get the smearing if you didn't tell the printer to print on "glossy" Anyway, this is most likely where to problem can be solved. good luck
Posted on Mar 24, 2011
I have colored smears on left side of all my printed pages with my Brother MFC-9420 CN. What causes this?
It's not unusual for paper to hit the bottom of the print head, especially if the paper is bent. This can cause smearing. If you have pets, you can check for pet fur in the printer, or other foreign material inside that can also cause smearing.
Sep 11, 2014 | Brother MFC-9420CN All-In-One Laser...
Why are there lines in my photos
The manual says:
This phenomenon is called smearing. This is not a malfunction. Smearing is not recorded on still images, but is recorded as streaks or uneven colors on Sweep Panorama images or movies. ("Bright areas" refers to the sun or electric lights which are much brighter than surroundings.) It does not say a thing about lines in the prints. Are you sure the pictures do have lines too? Can you describe this more accurate?
Description online of Sony DSC-H200
Nov 25, 2013 | Sony Cyber-shot DSC-H200 20.1MP Black...
I've got 2 Kyocera 5030's that are smearing color copies
if the toner can be wiped off of the paper then your issue is the media settings or the fuser is failing. If the image is fixed onto the paper but just "looks" smeared then it could be the drum(s), transfer belt, color registration, or cleaning system.
Mar 25, 2013 | Kyocera Office Equipment & Supplies
Gray color prints as brown using Photoshop CS6
check your image mode.. click image, then mode, then cmyk color.
Sep 23, 2017 | Epson Stylus Office T1100
Xerox 6180 color laser printer - black is smearing on image side of paper. Also have a bit of smearing on the back of papaper. Was a gradual degredation, now it is really bad.
I think it would be to blame the black cartridge has fewer pages to print, probably having lost toner waste tank full and probably dirty image transfer kit worn. replace the black cartridge(if is like i said) and clean image transfer with a clean soft cloth inside the printer and all intake of residual damage including Fuser .
Mar 31, 2011 | Office Equipment & Supplies
Kids removed a jam, now all prints/copies are ghosted/smear
Sounds like they touched the photosensitive drum. It needs to be cleaned with a cotton cloth. The drum is a lime-color cylinder and it is very fragile. Avoid touching with any object other than the cloth it or scratching it.
Good luck.
Sep 29, 2009 | Canon MF3110 All-In-One Laser Printer
HP 1600 color laser printer--colors are out of sync
Check the following information please.
General print quality issues
Solving issues with color documents This section describes issues that can occur when you print in color. Color document issues Problem Cause Solution Only black is printing when the document should be printing in color.
c00659983.gif Color mode is not selected in your program or printer driver. Select color mode instead of grayscale mode. The correct printer driver might not be selected in the program. Select the correct printer driver. The device might not be correctly configured. Print a Configuration page.
One or more colors are not printing, or are inaccurate.
c00659984.gif Sealing tape might be on the print cartridges. Verify that the sealing tape has been completely removed from the print cartridges. The media might not meet HP specifications. Use a different paper, such as high-quality paper that is intended for color laser printers. The device might be operating in excessively humid conditions. Verify that the device environment is within humidity specifications. One or more print cartridges might be low. If you are using non-HP print cartridges, no messages appear on the device control panel or in the HP Toolbox. Replace any low print cartridges. The control panel is set for override. Replace low or empty print cartridges. A color is printing inconsistently after you load a new print cartridge.
c00659985.gif Another print cartridge might be low. If you are using a non-HP print cartridge, it might be low or empty but you will receive no indication. Remove the print cartridge for the color that is printing inconsistently and reinstall it. The control panel is set for override. Replace low or empty print cartridges. The colors on the printed page do not match the colors as they appear on the screen.
c00659986.gif The colors on your computer monitor might differ from the device output. Select Screen Match in the Color tab of the printer driver. If extremely light colors or extremely dark colors on screen are not printing, your software program might interpret extremely light colors as white or extremely dark colors as black. If possible, avoid using extremely light or extremely dark colors. The media might not meet HP specifications. Use a different paper, such as high-quality paper that is intended for color laser printers. The finish on the printed color page is inconsistent.
c00659987.gif The media might be too rough. Use a smooth paper or print media, such as a high-quality paper that is made for color laser printers. Generally, smoother media produces better results. Repetitive image defect ruler Use a repetitive image defect ruler to measure occurrences of repetitive image defects to help solve image quality problems. Place the ruler next to the first occurrence of the defect on the page. Find the distance between identical defects and see the Repetitive image defects table to identify the component that is causing the defect. Repetitive image defects Measurement Component 24.7 mm0.97 inch Developer sleeve 26.7 mm1.05 inches Charge roller 32.9 mm1.3 inches RS roller 37.7 mm1.48 inches Transfer roller 54.5 mm2.15 inches ETB rollers 56.6 mm2.22 inches Fuser sleeve 62.8 mm2.47 inches Pressure roller 75.4 mm2.97 inches OPC
Have a good evening
Jun 18, 2009 | HP LaserJet 1600 Printer
Fuser
The fusing unit uses heat and pressure to bond the toner to the paper. Normally poor fusing is evidenced by repeating images or by the print smearing when you rub your fingers across the paper. One fuser roller (the heat roller) is probably aluminum with a teflon coating and the other one (the presure roller) is a type of rubbery material and is often orange.
By your description you mentioned cartridges and that the printer is a full color printer. Is this a laser printer having toner cartridges and imaging units? I just want to make sure you do not have an inkjet printer as they do not use fusers.
The washed out prints you speak of sounds more like a transfer issue such as the transfer belt, transfer charge roller, etc...
Please tell me the brand and model of your printer and I will be more specific.
Nov 11, 2008 | Office Equipment & Supplies
Samsung CLP 300 Laser Printer Logo
215 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
