Question about Dryers
Dryer quit heating up,timer doesn't work,this happened all at one tim
  • marklaney Nov 23, 2008
    Greetings all: I have a whirlpool dryer that's been running strong for years. Today I opened the door and the clothes were spinning, but they were cold and damp. Is there a reset button/switch or something else I can dry to get the heating coils to fire up?
  • kevin mcdowell
    kevin mcdowell May 11, 2010
    hiya
    when this happened did your electrics blow? and have you replaced the fuse in the plug?
No dyer run's just does not heat up,timer never move's,which I think need's too for dyer too heat up,i could be wrong,just happened all at one time
Posted on Aug 04, 2008
My whirlpool dryer comes on and runs good but it wont get hot can you tell me whats the problem
Hello there and welcome to fixya there are several things that could make this dryer not heat up
Here are the most common things
Thermal Fuse
If the dryer doesn\'t heat, but the drum
turns, check the thermal fuse(s). The thermal fuse protects the dryer
from overheating and helps to prevent fires. If the thermal fuse is
blown, it will have to be replaced.
Enter your model number to see parts for your dryer.
Help me find my model number
Gas Valve Solenoid
The gas valve has two or more electric
solenoids which open the valve to let the gas flow into the burner
assembly. If the dryer doesn\'t heat one or more of the solenoids may be
defective. If the igniter glows for 90 seconds but the burner flame
doesn\'t light, replace these coils as a set.
Dryer Igniter
If the dryer doesn\'t heat, the igniter might
be burned out. Check the igniter for continuity with an ohm meter. Dryer
igniters burn out over time, similar to a light bulb.
Heating Element
The heating element on an electric dryer can
burn out over time. If the dryer doesn\'t heat, the element should be
checked for continuity. The heating element cannot be repaired and must
be replaced if defective.
Heating Element Assembly
the heating element assembly on an electric
dryer can burn out over time. If the dryer doesn\'t heat, the element
assembly should be checked for continuity. The heating element assembly
cannot be repaired and must be replaced if defective.
Flame Sensor
Gas dryers have a flame sensor to detect the
heat given off by the flame. If the dryer doesn\'t heat, the flame sensor
might be defective. Check the flame sensor for continuity. This is not
as common as a burned out igniter or thermal fuse.
High Limit Thermostat
Although not common, if the dryer doesn\'t
heat the high limit thermostat can be defective. It can be checked for
continuity. If the thermostat is "open" the dryer doesn\'t heat.
Cycling Thermostat
The cycling thermostat regulates the
temperature of the air in the dryer. If the dryer doesn\'t heat it may be
caused by a defective cycling thermostat. This is not common.
Main Control Board
The main control board is normally not at
fault when the dryer doesn\'t heat. Check all of the other components in
this troubleshooting guide before replacing the main control board. The
main control board cannot be tested easily and must be replaced if it is
defective.
Timer
The timer is normally not at fault if the
dryer doesn\'t heat. In many situations where timers are replaced they
end up being returned. Check all of the more common components in this
troubleshooting guide before replacing the timer
Oct 14, 2013 | Dryers
I have a ldg382 gas dryer. The dryer runs and heats a little, and the timer will not advance, stays in same position.
disconnect vent tube, run dryer as it shall work now. I would guess restricted vent tube. Good Luck Tim
Jan 16, 2011 | Maytag Atlantis MDE6400AY Electric Dryer
Dryer runs but theres no heat and the timer does not work
sounds like it is the timer motor this website will show how to test, Tim:
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Nov 27, 2010 | Whirlpool LER4634J Electric Dryer
Timer dont work and wont heat up
timer motor this website will show you how to test it, Tim:
The knob on my dryer will not turn while turned on nor will it heat up. how do i fix this?
sounds like the timer motor, this website will show you how to test/replace, Good Luck Tim:
Oct 20, 2010 | Roper Dryers
Kenmore Dryer 70 series electric-quit heating and timer wont shut
https://www.repairclinic.com/RepairHelp/Dryer-Repair-Help
This link will help you in diagnosis/disassembly/parts.
Possibly a faulty heat element is most common failure. Fix the no heat problem and the dryer should shut off ok.
Make sure you have correct voltage to the unit before tearing apart. Again visit the link above
Nov 24, 2017 | Kenmore Dryers
Gas dryer not heating. Drum does turn. Tim,er
The dryer has a bad thermal fuse . A small slim white piece with 2 wires attached . IF you do not see the glow from the ignitor .
Jul 15, 2009 | Whirlpool Dryers
Clothes dryer don't run
sounds like a bad cycle timer switch
Apr 22, 2009 | General Electric Clothes Dryer Knob -...
Maytag dryer heating element does not turn off when tumbling stop
your timer is bad,the cost of a timer is close to a new dryer.
Jan 21, 2009 | Dryers
Dryers Logo
128 people viewed this question
Top Dryers Experts
