Question about Casio Computers & Internet
Casio Keyboard CTK700 The sound does not sustain when the key is pressed for 4 notes. How to rectify the same
  • 604 Answers
Sustain is typcially a product of the sound you have chosen, If you have a sustain pedal you can sustain any sound. you may also have some choices on the switches that allow special sustain, but I dont own a casio keyboard (I have yamaha) but they are nearly the same in operation. The easiest way to get controllable sustain is by plugging in a sustain pedal
Posted on Mar 24, 2011
I plugged a sustain pedal from my Yamaha DX7 on the dumper pedal jack but it works opposite as it should (by pressing the pedal sound cancels as i release the keys; when pedal runs completely free sounds...
every sustain pedal got different polarity.. normally just go to global setting on your keyboard and change damper polarity setting to plus or minus (select which one work with your sustain padle).
Jul 26, 2011 | Korg M50 73 Note Workstation
Hi, i have a problem with my casio wk 210 keyboard. when i push a key then the note keeps playing and doesn't stop. i have tried turning off the power and turning off reverb and none of them fix the...
It sounds like the sustain is stuck on as if a sustain pedal is active. You don't mention if you have one, however if you MIGHT have one and you have used a Roland pedal, that brand is reverse sensed and would cause note to remain on.
Jun 14, 2011 | Casio WK-210 PACKAGE 76 Keys Electronic...
I've recently purchased a Roland foot pedal for my casio privia px-300 keyboard. When playing a note, even though the pedal is not pressed, the note sustains. When I press the foot pedal down, it cuts...
Sorry, but Roland uses the opposite sense switch. They use normally closed where Casio requires normally open contacts. SOMETIMES one can rewire the pedal internally, but you have to be mechanically and electrically inclined to do that.
Jun 04, 2011 | Casio Privia Keyboard Case
Hi. I'm Using PX330 as a midi controller that plays "Galaxy pianos" in cubase 5. I'm interested in buying a continuous sustain pedal (the one I got with the piano is an On\Off pedal). can you...
The Yamaha FC-3 uses a TRS (three conductor plug). The PX330 does NOT use TRS jacks for the sustain and sostenuto pedals so they are NOT compatible with the Yamaha FC-3. Therefore I would conclude that continous sustain that the Yamaha pedal would be used for is NOT supported.
Feb 15, 2011 | Casio Privia Keyboard Case
I just got an sp-3 sustain pedal for my casio ctk 560l keyboard but have no sound when i plug it in. How can i get it to work? I there a button i have to press or something?
Make sure you are plugging it into the place for the sustain pedal. If you happen to plug it into the audio out it may kill the sound.
Sep 29, 2010 | Casio SP3 Sustain Pedal
Sustain pedal not working on my Yamaha P-90
What I figured out is that when i turn on the keyboard, if i hold down the pedal by accident, it will work in reverse. I dont know if this is what you mean. If it is, just dont touch the pedal when you turn it on. If it isn't, try to return the pedal. I dropped one, it had this problem, and they gave me a new one. Your cord for it might have been bent (?). Also, turn the keyboard on with the pedal already plugged in. It's not made to be plugged in while it's on. Hope this helps. - Matthew
Mar 12, 2009 | Yamaha Music
Casio 1600 sustain pedal problem
Not if its like mine, its a completecircuit vs.incomplete circuit problems.
I had the exact same problem with my Casio keyboard and a Yamaha sustain pedal I bought.
I'm not an electrical genius, but I was able to get it to work by opening it up and doing a little modification. Of course I first just tried switching the white wire with the black one but that didn't change anything at all when I tried it. It turns out the Casio wants the circuit completed to sustain, and broken for no sustain, which is the opposite of what the Yamaha pedal does.
I opened it up and mine had three three flat metal strips let's call them Top, Middle and Bottom. The Middle and Bottom ones were joined together on the right side, and the Middle and Top ones were touching on the left side when the pedal was not pressed. These seperated when the pedal was pressed, thereby breaking the circuit because the wires were on the top plate and on the joined Middle/Bottom plate.
So to flip it I:
1. Unsoldered the Bottom wire
2. Cut apart the Bottom and Middle plates on the right.
3. Bent the Middle plate on the right to touch the Top plate instead and soldered those together.
4. Soldered the Bottom wire back on.
That's it! Once I figured it out, it took only a few minutes to fix.
Paul
Aug 25, 2008 | Casio LK30 Note Lighted Keyboard
Casio WK 1600 : Sustained keys
Remove all power sources for at least 2 minutes. That means removing the batteries and power cord completely from the K board. Then try again. If that doesn't do it, it'll be time for a service visit...accordianman
Sep 18, 2007 | Casio LK30 Note Lighted Keyboard
Computers & Internet Logo
231 people viewed this question
Top Casio Computers & Internet Experts
k24674
jackcity
jackcity
Level 1 Expert
Are you a Casio Computer and Internet Expert? Answer questions, earn points and help others
