Question about Yahoo Mail
Impossible to open messagerie its instable - Yahoo Mail
  • Yahoo Master
  • 4,737 Answers
Have you tried re-installing the Yahoo! Messenger? If not, uninstall it and then reinstall. Follow this LINK if you wish to know how to install or download the Yahoo! Messenger. If the problem persists, let me know with more details.
Good Luck.
Thanks for using FixYa.
Posted on Mar 24, 2011
Hi, I'm having a bit of a problem with instability while planing. Is there anywhere I can read up about how to fix this?
Here is a thread you can read about this exact problem. good luck!
http://www.star-board.com/forum/showthread.php?t=3561
Feb 27, 2013 | Water Sport
Tip
?JCB FAULT CODES LIST
P0087 (flashing code 227) shared sump low pressure fault (for pump without pressure supply)
The main fault symptoms
• Engine severe vibration.
• idling unstable
• Output Fall
• exhaust smoke
• It may be too large output
P0088 (flashing code 118) shared the tank pressure is abnormally high (first or second stage)
• idle instability
• Output Fall
• channeling gas engine failure
• exhaust smoke
P0089 (flashing code 151) shared the tank pressure failure (for pump pressure supply is too large)
• idle instability
• Output Fall
• exhaust smoke
P0090 (flashing code 247) SCV drive system open, + B short circuit or shorted to ground
• Depending on the open / short situations, there may be an engine stall and / or launch
Machine channeling gas.
• exhaust smoke
• Output is too large
P0107 (flashing code 71) atmospheric pressure sensor circuit input low (open or shorted to ground)
Due to spare the equivalent altitude 2000 m (6562 ft)
• exhaust smoke at high altitude.
• insufficient output at low altitude
P0108 (flashing code 71) atmospheric pressure sensor circuit input high (+ 5V shorted)
• The high altitude exhaust smoke
• lack of low altitude output
P0112 (flashing code 22) intake air temperature sensor fault (low voltage fault, earth fault, short circuit)
• When cold starting, may exhaust white smoke.
More here http://truckmanual.weebly.com/jcb-fault-codes.html
on Dec 20, 2016 | Cars & Trucks
Tip
Messageries instantan?es : bien d?buter avec Windows Live Messenger ...
Messageries instantanées : bien débuter avec Windows Live Messenger
MSN a changé de nom et est devenu Windows Live Messenger. Son utilisation est toujours aussi intuitive, n'hésitez plus à vous lancer. Retrouvez notre tutoriel pour bien l'installer et faites vos premiers pas dans le monde des messageries instantanées.
L'installation : facile comme un clic Il faut avant tout ouvrir un compte chez hotmail ou MSN c'est-à-dire une adresse mail, pour pouvoir se connecter. Il s'agit de votre compte Passport qui vous servira d'identifiant pour entrer sur le réseau. Vu le nombre d'utilisateurs, qui augmente considérablement avec le temps, il devient de plus en plus difficile de choisir un nom qui ne soit pas déjà utilisé. Soyez créatifs mais n'oubliez pas que le nom que vous choisirez sera communiqué à toutes les personnes avec qui vous souhaiterez communiquer. Depuis peu Il est également possible de se connecter avec un mail qui ne provienne ni d'hotmail ni de msn et on peut aussi bien directement se connecter via le web sans rien télécharger (mais sans avoir toutes les options). Ensuite il vous suffit de télécharger le logiciel ici.
Suivez les indications pour l'installer, puis double cliquez sur l'icône dans le bas de votre écran à droite. Entrez l'adresse de messagerie et le mot de passe enregistré avec votre compte Passport. Il reste à vous faire connaître auprès des personnes qui ont déjà MSN.
1.jpg Cliquez sur l'onglet Contacts en haut à gauche puis sur ajoutez un contact Pour ce faire, cochez la case en bas et entrez l'adresse de messagerie du contact que vous souhaitez ajouter. Le contact s'ajoute automatiquement dans votre écran principal, il vous suffit ensuite de le placer dans la catégorie qui vous convient (amis/collègues/famille/autres contacts...)
Avant de pouvoir lui parler, sachez qu'en l'ajoutant vous venez de lui envoyer un message lui demandant s'il accepte d'être ajouté dans votre répertoire. Si la personne accepte (ce qu'elle devrait normalement faire) vous recevrez un petit message de confirmation. "X a accepté de devenir votre ami". Ce petit message vous confirme que vous ne vous êtes pas trompé de messagerie en envoyant votre message.
Premières conversations Une fois tous vos contacts ajoutés, retournez dans la fenêtre principale de MSN Messenger, double-cliquez sur le nom d'un contact en ligne pour lui envoyer un message. Vous écrivez dans la partie inférieure, une fois envoyé le texte apparaît dans l'écran du dessus et vous pouvez suivre la conversation en continu.
2.jpg Notez qu'une utilisation répétée de MSN est une bonne techniquepour apprendre à taper plus vite sur un clavier. Il ne vous reste plus qu'à entamer la conversation. Vous pouvez voir sur la photo les coordonnées du contact ainsi que les options offertes par messenger... envoyer des fichiers, démarrer une conversation audio ou vidéo. Vous pouvez parler à autant de personnes que vous le souhaitez, double cliquer sur un contact ouvrira à chaque fois une nouvelle fenêtre pour parler en tête à tête... Vous n'êtes limité que par le nombre de vos contacts et votre capacité à gérer plusieurs conversations en même temps.
Autre possibilité : vous parlez à une personne et vous souhaitez inviter un autre contact (ou plusieurs) à participer à votre conversation. Là encore, la simplicité règne. Il suffit de repérer la petite icône "inviter" qui se trouve juste au dessus du nom de votre contact dans la fenêtre de discussion. Vous tombez sur une autre fenêtre regroupant la liste de vos contacts en ligne, sélectionnez la personne que vous désirez inviter...et c'est parti. Recommencez autant de fois que vous le souhaitez.
on Oct 09, 2010 | Microsoft Windows Live Messanger
I can't open emails in yahoomail? what can I do to fix that problem?
Good Day Kofr00!
Switch to other internet browser so you can open your emails.
If you don't want to switch, it is best recommended to uninstall your current internet browser, then, download the latest version and install in your system.
Kofr00, you are currently having issues with your present internet browser. It is about to crash. Yahoo products are most likely to experience difficulty accessing when it is starting to have instability.
Jun 10, 2011 | Yahoo Mail
My toshiba satellite pro L300 restats itselfs..
System restarts by itself due to system instability. See what is causing the instability. It can be due to recently installed hardware or software. Try removing it and using it. This will solve the issue.
Nov 16, 2010 | Computers & Internet
Tip
10 reasons why PCs crash-You must know tip 6
6 Viruses
Often the first sign of a virus infection is instability. Some viruses erase the boot sector of a hard drive, making it impossible to start. This is why it is a good idea to create a Windows start-up disk. Go to
* Start-Settings-Control Panel-Add/Remove Programs
Here, look for the Start Up Disk tab. Virus protection requires constant vigilance.
A virus scanner requires a list of virus signatures in order to be able to identify viruses. These signatures are stored in a DAT file. DAT files should be updated weekly from the website of your antivirus software manufacturer.
An excellent antivirus programme is McAfee VirusScan by Network Associates ( www.nai.com). Another is Norton AntiVirus made by Symantec ( www.symantec.com).
on Mar 04, 2010 | Computers & Internet
Bonjour J'Ai portable téléphone Samsung M8800 non je-ne Peux Plus Recevoir d'appels en direct le téléphone sonne Pas NE et les Appels tombent rattachent directement sur ma Messagerie JE...
i have a problem with me mobile the function of my mobile about the camera the flush option has been disable and i dont know how to make it enable kindly plz help me abot that i am very upset about it my email id is star30046@yahoo.com ia m waitingt for yor email
Oct 05, 2010 | Samsung Cell Phones
Machine freeze up randomly. Must do a hard shutdown. Seems like a motherboard failure
Freezes and crashes are generally caused by some sort of instability in the computer system.
The following is a list of specific problems that can cause instability along with what to check when troubleshooting each.
Viruses can cause instability.
Run a virus check on the computer to look for a possible virus.
Conflicts can cause instability.
Check the Windows Device Manager to see if there are any yellow exclamation marks or red Xs beside the listings for device classifications. If there are, contact Tech Support.
Buggy or damaged software applications can cause instability.
If the system is less stable when certain software programs are running, shut down those programs and see if the problem continues to occur. If the problems stop, chances are that those software programs are causing the problems.
Buggy, outdated, or conflicting drivers can cause instability.
Check manufacturer web sites for updated device drivers for the various devices installed on the computer system, such as: printer drivers, modem drivers, video drivers, sound drivers, USB device drivers, etc.
Update one driver at a time and see if the system stabilizes. If this doesn't work, it may be a hardware problem, so contact Tech Support.
AC problems can cause instability.
Check to see if the computer system is plugged into an overloaded outlet.
Make sure the computer system is plugged into a surge suppressor.
The installation of new devices can cause instability.
There are three typical symptoms that point to this problem:
The computer system fails to boot, freezes during a boot, or freezes during an operation for no apparent reason.
The system fails to recognize the newly installed device.
One or more software applications fail to function as expected after an upgrade.
Hardware failure can cause freezes
Fan failure, cpu failure, memory failure, could be also a cause of freezing.
Keep track of the hardware and software that is added to a computer.
The addition of new hardware and software can often cause problems to occur.
Nov 07, 2008 | Computers & Internet
Antivirus 2008
Some Tips for Dealing with Freezes and Crashes
Research the compatibility of new hardware and software with the existing computer system before purchase and installation.
The older a PC, the more likely it is to crash.
When a computer freezes or crashes, chances are that changes made after the last save and when the freeze or crash occurred will be lost.
Oct 18, 2008 | HP Compaq Presario v3000z Notebook
Desktop freezes and can't do anything!!!!!
I suggest to you do the follow:
Start up your computer and before windows load hit F8, then select SAVE MODE
On SAVE MODE, uninstall all innecesary programs or recently installed, Clean your computer, and be sure that your computer is not virus or spyware infected.
After that reboot and work normally
This will be fixing your problem.
If the problem after that continues is probably then that your have some hardware issue.
Thank you for using FIXYA
Don't forget to rate my help!
Pablo :-)
Oct 14, 2008 | HP Pavilion dv1000 Notebook
Yahoo Mail Logo
164 people viewed this question
Top Yahoo Computers & Internet Experts
micky dee
Mike
fixrfast
Level 1 Expert
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
