Question about Samsung Audio Players & Recorders
Samsung ht z120t shown protection warning on power up
SOURCE: Samsung HT-DS610 System Problem
I found this online. Don't know if it helps you guys or not?
Samsung HT-DS610
1. Remove any discs from the tray
2. Flash the RAM (disconnect from the mains for 30 seconds)
3. Plug it back in, switch on from the remote
4. Wait for "No disc" message
5. Press Enter.
6. Press 8,4,2,6,9 slowly.
7. Press Enter.
You may need to repeat steps 4 through 6 before the try is open.
Posted on Jul 02, 2008
SOURCE: Samsung home theater
After having my unit for a year, it now reads this PROTECTION message. I tried to restore factory settings also before calling Samsung & they said something wrong with the cooling fan. Haven't tore into it yet, but does the units come with a fuse that might be blown. I'm tring to find free schematics on the net but hard to track down. If you just got yours, take it back to the store & get a new one!
Posted on Nov 01, 2008
ginko
  • 19396 Answers
SOURCE: SAMSUNG HT-TZ212 home cinema kit comes up with protect
Protect mode will kicking whenever a fault is detected.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Posted on May 04, 2009
ginko
  • 19396 Answers
SOURCE: When i turn on my samsung HT-Z110, the word "Protect" appears...
Protect mode will kick in whenever a fault is detected.
You get the unit not powering up, and sometimes you hear a clicking noise, that is the protection switch that keeps shutting down the unit.
Bad speaker wiring.
Internal fault.
Regards.
SOURCE: SAMSUNG DIGITAL HOME CINEMA SYSTEM MODEL HT-Z110
Maybe the audio amplifier Ic are damaged and need to be replaced
Posted on Aug 14, 2009
Samsung HT-TZ312 Stereo System flashes protect and turns off
Turn the unit off.....reseat connector at the power board (supply).After reseating, turn it on again and the protect error will disappear....I have this problem after repairing the optr16 power supply that accidentally plugged into 220v...only the 5q1265rf (power switch)and 9v zener diode connected at optocoupler being damaged. Hope this helps! Mhar fernando from the Philippines
Nov 26, 2010 | Samsung HT-TZ312 Theater System
Power ON
over voltage to the system causes ur system to shut off.
get it checked or replaced if  warranty is still valid.
Mar 14, 2010 | Samsung HT-Z210 Theater System
Samsung HT-TZ312 shows "protect" and it turns off
A short on the speaker wires can cause this but most likely your amplifier bias is off or you have a shorted transistor.
First unplug all connections, even the power. Let it sit for a minuit then power it back up.
If it clicks off them it needs professional service.
If it turns on inspect all of your speaker wires for shorts them reconnect them one at a time.
Hope this helps,
Cheers
Feb 03, 2010 | Samsung HT-TZ312 Theater System
Powering off for protection samsung HT-WX70
the fan is broken on your unit, this is a feature to keep the unit from over heating
check if there is anything blocking the fan from moving/rotating
try to contact your manufacturer
Jun 30, 2009 | Samsung Audio Players & Recorders
Samsung ht-wx70 shutting off for protection
The word PROTECTION means that the cooling fan is defective. it needs to be replaced.
Call 1-800-7267864 (SAMSUNG) and they can repair it for you.
Hope this helps!
Jun 30, 2009 | Samsung HT-WX70 Theater System
When powered up, it states "protect" and shuts down.
it is a known product defect. samsung will fix it for you if you send them a lot of money. this helps them keep their prices low.
May 25, 2009 | Samsung HT-Z310T Theater System
Bad speaker wiring.
Internal fault.
Regards.
Mar 19, 2009 | Samsung HT-Z310T Theater System
Dsp protection
Resetting- taken from the user manual:
Jan 27, 2006 | Samsung HT-DB600 System
Top Samsung Audio Players & Recorders Experts
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
