Question about Onkyo HT-S6300 Theater System
So I've had my system for a couple of weeks and it worked great. All of the sudden now it starts saying either no signal from the input or it displays some weird colors on the screen in 800x600 resolution. I tried everything and I got it to work again for a little after I jiggled the HDMI cable on the tv out. It worked a little while but then it started again. And I can't seem to fix it. Any ideas?
  • 1 more comment
  • Josh Pegel Mar 24, 2011
    I'm not sure how to bypass the Onkyo because my TV doesn't appear to have the HDMI out it's a Samsung PN50D550 if that helps with the specs what my setup is. I know it's not the TV because when I hook all of the other things my XBOX, PS3 and Directv up through HDMI to the TV the picture works fine. The "no signal is found on the receiver and what displays on the TV is a blue screen in 720x480p. I looked through the manual and it hasn't been much help. My HDMI connections goes as follows. On receiver HDMI 1 PS3, HDMI 2 not used, HDMI 3 DirecTv, HDMI4 Xbox 360. They all directly from the source to the receiver. Then I use the HDMI out from the receiver to my television. The receiver is able to send out images like the setup menus to the tv. Thank you so much for your help so far. How would I bypass sending the video to the receiver? I would love to know how to do that but not sacrifice 7.1 because I was told that optical only does 5.1. I mean ideally I would like the receiver to do both. Thanks for the help please let me know what you think.
    I also forgot to mention that none of the HDMI inputs appear to work.
    It appears that the HDMI inputs are what the issue is. So I'm going to contact the retailer I got it from to get another one thanks for the help
    Brigadier General:
  • 8,546 Answers
If you jiggle the HDMI cable and it gets better that suggest you have bad cables or connections. Take the next step and replace the cable.
Posted on Mar 24, 2011
    Thanks for the quick reply. I switched out all of the cables and pretty much nothing happens so I should pretty much assume that the HDMI went bad. Or could it be a sound issue because I still don't get any sound out of it either. I also do keep on getting an 800x600 resolution which does not make much sense.
  • David Dunn
    David Dunn Mar 24, 2011
    The unnamed input is always a potential cause for failure. Check IT out. You COULD bypass the Onkyo to prove it's working as expected. In fact, if it was mine, I wouldn't even have good video coming into it at all, as the TV is the ultimate and primary user of video.
    "No signal". What device says that and is it verbatim? I'm thinking we're dealing with a display/TV issue.
    Have you perused the Onkyo manual?
    Register and download the manual for free at retrevo.com
    http://www.retrevo.com/support/Onkyo-HT-...
    I need to know some details (point-to-point) of the HDMI connections.
My HP desktop fan turns on as does the green light, but there is a constant beeping sound and no display on the monitor
This error message mean that there isn't video signal from the video card going to the monitor.
Try reconnecting the video cable to the monitor. If this does not work then you may have a faulty video card.
Sep 18, 2012 | HP Pavilion a1410n (ER890AA) PC Desktop
Power comes on - screen says NO SIGNAL. Have already checked cable line with another TV and it works fine. Have we hit something on the remote that has put it into that mode?
The only reason your TV would say "no signal" is that it's searching an input for a signal and not finding it. That being said, Yes, You've probably hit the "input" button on your remote. Easily fixed by selecting a different input or changing the channel on the television.
May 03, 2011 | Televison & Video
Hi there, I'm trying to play a VSH/DVD through my
This happens when the computer signal is being used as the input, and the signal disappears or is the wrong type.
It may have tried switching inputs if you were using the video input rather than the pc input.
Press the auto image button to get it to select the correct input.
If you are using the PC as the dvd player, then change the display settings ie computer screen refresh rate, and resolution to suit the projector
Apr 06, 2011 | InFocus IN26 Multimedia Projector
No Input Signal, Monitor Going to Sleep
if you have twisted od bent the cord to much the wires could have broke inside the cord.
Jul 31, 2009 | HP w1907 LCD Monitor
My LG 42pg3000 stopped displaying hdmi inputs.
I have a similar issue. HDM1 does the same thing, did you ever find a solution?
JP
Apr 05, 2009 | LG Televison & Video
Sharp sd nx10_out signal trouble
Try all of the spaekers on the channel you know works. If all are fine, swap the speaker lines to test them. Is the input a DVD player on RCA cables? A bad signal cable from a component can be a source for problem. Connect the speakers directly to the amp(if possible) bypassing the sub box. If all works without the box, suspect bad crossover or in the self-powered boxes a bad amp.
Jun 22, 2007 | Sharp SD-NX10 CD Shelf System
Onkyo HT-S6300 Theater System Logo
155 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
