Question about ASUS M2V Motherboard
Usb 3.0 satadata cable one is not working if l connect all 3 cables its failed to respond
    Renaissance:
    An user who is expert in 3 categories / brands.
  • ASUS Master
  • 2,226 Answers
Bad board jim
Posted on Mar 24, 2011
Ematic lp2p tablet doesn't recognize usb or pc
1 port is a mini hdmi port to connect to a tv via a hdmi mini to hdmi cable,the other is a mini usb port,with the data cable that you can buy for it,you can connect to a computer,not just any usb cable will work,there is 1 for charging and 1 for data Ematic Edan XL EGS109 9 Inch Tablet 5 ft USB 2 0 Mini Micro Cable
Apr 27, 2015 | Tablets & eReaders
USB not recognizing my mobile phone
Try the following:
1 Connect the USB cable to a different USB connector on your PC. 2. Connect your phone to he PC with a different cable (these cables are fairly fragile). 3. Try a temporary connection to a friend's PC. 4 have a technician repair your phone.
Nov 25, 2011 | Samsung SGH Cell Phones
I have a canon pixma mp 287 printer i have installed the drivers also and it is also not offline but when i am giving command to it then it is showing that printer is not responding.why it is showing like...
solution :
1. Uninstall driver printer and remove Printer USB cable from computer. After uninstall finish, restart printer.
2. Reinstall driver printer (don't connect printer USB cable to computer). Wait for the install process, until message "connect a printer USB cable to computer". After message appear, connect printer USB cable to computer.
3. Wait process install finish and try to print.
Sep 23, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
My M1522 MFP printer is working it used to be network shared but now I want to print direct from laptop to printer using usb cable (I no longer want it networked). It went to restor defaults and cleared...
When you changed from Network to USB cable, one or both of two things may have occurred.
First check your printers list in the control panel. You may find you have two apparent installations of the device. If so try a test page from each install and record the port settings for the one that responds. Delete the other and re-test. If the machine fails to print on any setting, delete ALL installations for the device and re-install from fresh with the USB cable. You may also need to go into the settings on the device itself and disable any network settings.
Oct 16, 2017 | HP LaserJet M1522nf Multifunction Printer...
Mt nuvi 3750 can not be found by 3 computors, says no devise found ? what could my problem be ? 2 pc's with win 7 , one with win xp, all i want to do is update my garmin..
Try a different USB cable.
The likelihood that 3 computers all have a failed USB ports is pretty slim. Using the same USB cable to connect the 3750 to them however throws suspicion to a defective USB cable. If it still doesn't work with a different cable - then it could be the 3750. Before doing anything else, check it out with the new cable on several computers. If it still fails to connect, contact Garmin Support.
I hope this helps and good luck. Please rate my reply. Thank you.
Apr 09, 2011 | Garmin GPS 3700 series Garmin nuvi 3750...
My printer is not responding to the computer
Test the cables.
USB cables uses to fail without advise.
If you are connected by parallel cable, replace it.
If it is connected by Ethernet, make a ping to the ip address of the printer con see if there is phisical connection to the printer.
Dec 11, 2010 | Canon imageCLASS MF7480 Laser Printer
The printer is not printing any document
Hi
Please check
1. Do you have a printer cable failure?
The printer will not be printing if its not connected to the computer. Check that the printer cable connecting your printer to the computer is firmly attached at both ends. Apart from this cable, there should be one more cable which is the one connecting to the wall outlet.
2. In case it still not work after checking try resetting and printing.
3. Else please change the Data Cable if it is very old one.
Jul 22, 2010 | HP LaserJet 1300 Printer
It will not charge
I have the exact camera, when you plug it in does the USB cable show red? If so this means the cable and the battery are connected and the red is a charging status. If you can turn on the camera while it's plugged in then its not the cord or the camera but the battery. If it just fails to charge but does power up and connect via USB i would look into a new bettery. If the USB cable does NOT respond at all when plugged into the PC by itself then the cable is bad and you need a new one. It will flash red/green/yellow if it's 100% functional. If your cable does respond but does nothing when the camera is plugged in then it may also be the cable's connections or the camera's internal port has been damaged. If you want to make sure it is the battery then plug in your cable, wait for it to cycle through the colors and connect your camera WITHOUT the battery inserted. It should do nothing, then while its connected to the cable insert the battery, If the cable turns red but will not charge then it's 95% a battery issue.
Jun 28, 2010 | Samsung SL420 Digital Camera
Usb not responding to connections of cables
Try using a different USB port on your laptop, or verify this port is working with another USB device.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jan 26, 2010 | Televison & Video
T819samsung usb driver/software
my usb cable for my phone doesnt respond when it is connected to the computer
Aug 16, 2008 | Cell Phones
ASUS M2V Motherboard Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
