Question about LG Washing Machines
Fault code oe please explain what this means - LG Washing Machines
  • 1,998 Answers
"OE" Drain error. Cause: not fully drained within 10 minutes Check there isn't a kink in your drain hose, ensure the filter is clean, the drain hose can become clogged with sludge, sometimes a hot wash with 1/2 a cup of vinegar will remove this sludge http://www.appliancefactoryparts.com/applianceshvac/help-center/fault-codes/fault-codes-washer.html if you have any further questions message me back and please remember to rank how this opinion has helped in your applaince situation it allows me to help others in similar situations Thanks
Rick
Posted on Mar 24, 2011
  • gary nelson Aug 05, 2012
    thanks rick there was a kink in the waste pipe .first class well done ,many thanks
My lg direct drive dishwasher has a code OE, what does this mean please?
The 0E fault code means it cannot drain away the water used during its last cycle, please check to see if there is a bend in the outlet hose or of the drain to pump is clogged with food or grungy grease from cooking oils washed off the items, I hope this helps.....
Feb 21, 2018 | LG Dishwashers
My LG washing machine is showing OE fault what do it mean ?
OE means uneven load.
If you can open door, put a dry towel in with the washing and try spinning again ...
Nov 20, 2017 | LG Washing Machines
What does 'OE' display mean after washing circle?
The LG error code OE simply means "the pump is blocked".
A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain.
Sep 12, 2014 | Washing Machines
I have a code that sa OE and dont know what it means
Check out this tip it will help explain that OE code
LG Washing Machine OE Error Code
heatman101
Sep 26, 2010 | LG Washing Machines
READING A CODE OF OE WAT DOES THIS MEAN?
The LG error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn’t pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code Washing machine has an OE error code
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 07, 2010 | LG WM2487H Front Load Washer
Error code OE. What does it mean? washer seems to be having a hard time draining the water
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Please check the above link for a detailed picture wise explanation for the error code.
May 17, 2010 | LG WM-1832C Front Load Washer
Im receiving an OE error code on my LG Dishwasher Model LDF7811st. The machine runs for a little bit and then it dings a few times with the "OE" code and stops running. HELP please
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
Apr 21, 2010 | LG 24 in. LDF 7811 Stainless Steel...
What does OE mean on a Hitachi washer??
Mar 31, 2009 | Washing Machines
OE fault displayed on spin cycle LG 1019BD 10KG WASHING MACHINE
Jan 29, 2009 | Washing Machines
Washing Machines Logo
118 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
