Question about Sony Handycam HDR-HC3 HDV Digital Camcorder
Lcd display goes green when folded out but normal when folded back reversed!!
    Genius:
  • 1,812 Answers
The most likely cause for this is a damaged or defective flexible ribbon cable that connects the LCD to the camera body and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
Posted on Apr 01, 2011
Hi, I have a philips lcd tv and every so often the screen goes green and the soud goes.If i turn off the tv and the switch it back on everything is back normal.Any help would be gratefuly received.
Check all the flat cables that goes from its T'Con to display panel for loose contact. Re-set it at both ends once and check. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Nov 02, 2014 | Philips 42PFL5332D 42 in. LCD Television
Pyle PLCM4300WIR
The Green wire is a reverse trigger wire. It should be tied into the reverse light hot wire. This tells the monitor to turn on and switch to Video 2 so that it displays what is seen by the backup camera. When you take the vehicle out of reverse thus removing power from the green wire, the monitor switches back to normal driving mode. ( no video displayed ).
Jan 15, 2012 | Pyle Car Audio & Video
Hi, no display in camera mode but displays works when playing the tape back,thanks Andy
In your statement since the LCD is moving there's miniature wire or ribbon wire attached to the folded LCD display. From thousand times you folded the display, the tendency of that ribbon wire will be crack, so mini switch that enable or trigger the transfer mode will not respond. So better replace it with a new ribbons wires. or call service personnel to replace it for you.
Jun 10, 2011 | Panasonic NV-EX3EN Mini DV Digital...
Led goes from red to green and back to re flashes
led goes from red to green and back to red when turning tv on ...... thats normal operations ....
Jan 16, 2010 | Proscan 19LA25Q 19 in. LCD Television
Viewer turns off (black) when folded back against the camera.
When the big LCD is black the view finder will turn on, right?
You need to replace a new hinge unit. Here is similar solution
How to fix an intermittent display LCD on Canon PowerShot S5IS
Jun 26, 2009 | Canon PowerShot S2 IS Digital Camera
What does the green/white wire connect to on my jensen vm9312hd? Says it is reverse +
Rear View Camera Input: The VM9313 features a composite video input and a green/white wire lead attached to the harness for connection of a rear view camera. If a rear-view video camera is connected, the unit is on, and the TFT monitor is retracted inside the unit, the TFT monitor automatically moves into the viewing position and Camera modes is selected upon shifting into Reverse gear. When shifting into Drive gear, the TFT monitor is retracted back inside the unit. If the monitor is already in a viewing position and in display mode, the monitor automatically switches to Camera mode upon shifting into Reverse. When the reverse driving stops, the monitor returns to its original input display mode. You can choose for the monitor to display a Mirror mode image or a Normal mode image from the rear-view camera.
Jun 21, 2009 | Jensen's VM9312 Car DVD Player
Flickering screen and no display
thats the complaint of LCD inverter circuit...if u dont know to open it,then dont do any thing better thing is go to the nearest service center of toshiba and try to repair it if thats failed. u have to replace with a new inverter circuit.dont try to repair urself...thats all.
Dec 13, 2007 | Toshiba Satellite P25-S507 Notebook
Sony Handycam HDR-HC3 HDV Digital Camcorder Logo
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
