Philips 42PF7220A 42 in. Plasma Television
Problem for Philips 42PF7220A 42 in. Plasma Television
Philips 42PF7220A/37 April 2006. Chassis Number BP2.3U
By inst on Aug 03, 2008
I have a Philips 42PF7220A/37 April 2006. Chassis Number BP2.3U TV that does not work. The front LED flashes red seven times and the power supply led flashes green three times. VSCAN voltage drops to zero (or climbs). I unplugged the power feed cable to the y-sustain board and the error codes go away and VSCAN voltage remains at -190VDC. I replaced the y-sustain board and the error codes went away for approximately 30 minutes only to return again. I still did not have a picture for that 30 minutes
Comments:
Nov 01, 2008
- O.K. I was able to solve this problem on my own. I had to replace both Y-Buffer cards (Upper and Lower) along with the Y-Sustain card.
I purchased the cards from the http://www.vancebaldwin.com/ website.
I took a long time for the cards to arrive. Even with the long wait, I am pleased with the results.
Nov 20, 2008
- Item Line Brand Chassis Description Model OEM Status
996500038481 73NA Philips Logic Board 42PF9630A 996500038481 AVA
996500033880 73NA Philips CBA PSU 42PF9630A 996500033880 AVA
996500033880 73NA Philips CBA PSU 42PF9630A37 996500033880 AVA
996500032643 73NA Philips Y-BOARD 42PF9630A 996500032643 AVA
996500032643 73NA Philips Y Board 42PF9630A37 996500032643 AVA
996500032641 73NA Philips Logic Board 42PF9630A 996500032641 AVA
996500032640 73NA Philips Y-BUFFER(D 42PF9630A 996500032640 AVA
996500032639 73NA Philips Y-BUFFER(UP) 42PF9630A 996500032639 AVA
996500032630 73NA Philips CBA PSU 42PF9630A 996500032630 AVA
996500032630 73NA Philips CBA PSU 42PF9630A37 996500032630 AVA
996500029198 73NA Philips LOGIC-BUFF 42PF9630A 996500029198 AVA
996500029197 73NA Philips LOGIC-BUFF 42PF9630A 996500029197 AVA
932222538682 73NA PHILIPS LCD PANEL 42PF9630A/37 932222538682 SNA
483531057692 73NA Philips USB Drive 42PF9630A37 483531057692 AVA
310432842611 73NA Philips SSB Service Kit 42PF963037 310432842611 AVA
310432842611 73NA Philips CBA SERV S 42PF9630A37 310432842611 AVA
310432839821 73NA Philips CBA SIDE I/O 42PF9630A 310432839821 AVA
310432839552 73NA Philips AMBIENT LIGHT 42PF9630A37 310432839552 AVA
310432836781 73NA Philips CBA LED PANEL 42PF9630A37 310432836781 AVA
310432836671 73NA Philips CBA SIDE C 42PF9630A 310432836671 AVA
310432836671 73NA Philips CBA SIDE C 42PF9630A37 310432836671 AVA
272217100258 73NA Philips AMBILITE ASM L 42PF9630A 272217100258
272217100256 73NA Philips AMBILITE ASM R 42PF9630A 272217100256
242254900635 73NA Philips TXMTR 42PF9630A 242254900635
Nov 20, 2008
- I tried to format the table as good but I goofed.
I googled the OEM part number and found the cards.
I could not find the site where I found the table. It took a lot of searching.
Nov 20, 2008
- I googled the part numbers and ended up on a website that allowed me to purchase the buffer cards for around $120.00 each. The Y sustain card was purchased of of e-bay for $80.00 including shipping. I think that I got lucky with the Y sustain card.
It took a lot of searching to find the cards.
Each card had multiple part numbers on them.
LJ41-02759A = LJ92-01200A = Y Sustain
LJ41-02760A = LJ92-01202A = Y Buffer Upper
LJ41-02761A = LJ92-01203A = Y Buffer Lower
I searched today for the same part numbers and they were priced much higher.
The site was a Vance Baldwin parts store which is where philips must be distributing their replacement parts.
Nov 20, 2008
- http://www.vancebaldwin.com/products/?LJ92-01202A
JVC LJ92-01202A P.W.BOARD ASSY 136.02
Philips LJ92-01202A Y-BUFFER(UP) CALL
Philips 996500032639 Y-BUFFER UPPER 151.13
Nov 20, 2008
- http://www.encompassparts.com/products/?996500032640
Philips 996500032640 Y-BUFFER LOWER 151.13
http://www.encompassparts.com/products/?996500032643
Philips 996500032643 Y-BOARD 188.37
Same Problem
Jan 04, 2009
-   i HAVE THE SAME SET BUT i AM LOOKING FOR REPLACEMENT SCREW MOUNTS FOR THE INCLUDED TABLE TOP STAND. dOES ANYONE HAVE AN IDEA WHERE I CAN GET THESE FROM? -   DIGINEWBIE
Nov 08, 2008
-   I have the identical problem however cannot find the appropriate circuit boards on that site referenced. What are the m#?-   cstatz
Nov 08, 2008
-   Same problem with the same model here. How much are these cards and what model numbers? I went to the site and couldn't find them.-   Guest
Oct 24, 2008
-   I also have the same problem, red light blinks 7 times. Won't power up. Green light blinks 3 times. Help-   hooptydue
Best Solution
posted on Feb 16, 2009
Helpful)
Terryfic
Rank: Guru  Philips Expert
Rating: 87%, 1715 votes
Usually, LJ92- numbers made by Samsung have the best price....
Replace both drivers & Y-main at the same time...........T.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Jan 05, 2009
Helpful)
zjut
Rank: Guru
Rating: 88%, 139 votes
Most likely the YSCAN UPPER board and/or YSCAN LOWER Board also gone. Your new YSUS board may damage again if you don't replace the bad YSCAN boards. Try to replace the three boards together and then to verify which boards are bad one by one. Good luck.
Was this helpful?
Yes
No
Popular Solutions for Philips 42PF7220A 42 in.
Questions and Unsolved Problems for Philips 42PF7220A 42 in.
Do you recommend Philips 42PF7220A 42 in. Plasma Television?
Answer
Answer
i have a 42'' phillips plasma tv and when we turn on the tv their are red lines on the screen. model... (More)
Answer
Same red lights blinking. I have removed the back, but suspect capacitors show no visible damage.... (More)
Answer
Green power light on but telly not on as regards main power or picture.Turn off on mains socket,... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Flat Panel... Experts
Top TV Repairmen
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
