Question about Jacuzzi Home
Hi, My jacuzzi Laser Select Series was in operation during heavy rain. Since then, when I try to switch it on, the power trips all the time. I change the fuse, disconnected the pump and it does not work. Is it the Balboa H700 board which need to be replaced? or the 240V Transformer? Anyway for me to check. Many thanks
SOURCE: Hotpoint CTD00 trips the power
This happened to me.
Your condenser unit on the front bottom left corner may be clogged up and causing water to back up around the fan and heating element behind the rear panel.
Take condenser unit out and give it a good clean removing as much fluff as possible.
If the heating element senses damp on it, then it will trip the electric.
The back panel which is at 45 degree angle on back. I took this off and sure enough there was water in there.
Wipe away all water and use an ever so slightly damp cloth to remove as much dust stuck to the metal as possible.
I used a hair dryer for about ten minutes fanning over the heating element and circular fan. Don't rush this. Take your time to make sure all signs of damp have been removed from heating element before putting the back panel back on.
After carrying out the above my machine worked fine and no longered trip electric.
It is a pain, but to prevent this problem happening I suggest cleaning condenser unit about once a week if you have alot of washing. Empty water panel after every two loads, maximum.
Good luck
Jon
Posted on Dec 05, 2007
  • 3 Answers
SOURCE: Stopped working
I had a similar problem with a jvc 8040. when I replaced the fuse it became very obvious that the b1560 output on the center channel was blown (smoke and sparks, always a dead giveaway). I haven't fixed the center channel yet but simply unplugged the center channel board and removed it from the unit. Now everything works fine except of course the center channel. Pre outs still operate just fine so a slave amp could be used for center channel power, or you could just go and buy a marantz amp; I did and then I realized that I was lucky that the old jvc quit.
Posted on Jan 30, 2008
farfield
  • 462 Answers
SOURCE: CARRIER AIR CONDITIONER/HEAT PUMP PROBLEM WOULD
what I have always been told is if your 24 volt side burns out check the high volt side if the hi volt side burns out check the low volt side.
A quick way if the primary side is burningout due to a problem with the low volt side:
1 MArk all the thermostat wires at the indoor unit
2 Disconnect them at the indoor unit.
3 Check main line voltage before proceeding (A 208 volt is not considered 220V and 240v Is not considered 208V> In these circumstances the voltage may have changed with the power company replacing a transformer and now you need to change the main power input lines at your control transformer for the correct operating voltage). If okj then proceed:
4 If you have an amp meter attach it to one of the lines going to the transformer.
5 Apply main power and listen for hum, note if smell starts again and if so problem has to be in board or main incoming voltage too high or too low. Amp draw should be less than 3 amps.
6 If your to this point and still havent found any trouble in the above as of yet, Connect the wire marked "C" together. Then just touch the thermostat wires one at a time to the places where they go on the indoor unit and watch the amp meter. If you donmt see the meter jump the circut is probably ok but leave them disconnected until you touch all of them to the correct place or wire. Here is a possible problem I ahve seen a thermostat wireing problem if the wires are stripped too far and a "whisker" of the wire sticks out and allowes one of the other wires to cross short out. In this case just cut off the excess wire or bend it over out of the way asnd continue with the test. You can always cut it off later after the tests. If you see the meter jump up and stay up and /or blowes the fuse the wire that you used and it blew is where to consentrate.
7 No wiring problem found means that you could have a relay or contactor not pulling in properly.
and this will cause the amp draw to go way over the transformers power out put or VA rating.
8 Inspect the thermostat wiring for the "whisker" I mentioned above.
9 If you have done this to the end of the thermostat wires and your main incomming voltage is correctly wired in on the transformer andf your relays and contactors are pulling in evenly and not delaying excessively your problem should be fixed.
If this helps you please rate me as high as you can and thank you for using fixya.
Posted on Apr 25, 2009
t1m130
  • 86 Answers
SOURCE: Blown Transformer heat pump
blown transformers are usually from a low voltage short the first thing i would do is wire a automotive or resetable 3amp fuse in line with the transformer so you dont blow transformer after transformer the wire coming off the transformer that say 24v take that wire a couple of inches down and cut it and install the fuse in series there
24v----------------
24v----------x----------
24v--------{3ampfuse}----------
now you can go through your low voltage wires one by one and test them unhook all the wires to your outdoor condenser at your indoor unit(furnace or airhandler) and try turning it to cool now if you blow the fuse the short is between the tstat and the indoor unit if the fuse is still good leave it on cool and hook up one wire at a time to your outdoor unit starting with R a lot of times your contactor or your defrost board will short out on you also look for pinches in wires wires with cracks in the insulation and wires touching metal this situation can be a real pain sometimes i would recommend calling a hvac company if you start to get stumped
hope this will help you
Posted on Jul 26, 2009
  • 532 Answers
SOURCE: 1999 Ford Expedition - fuel pump not working after replaced alter
replace the fuel pump
Posted on Nov 15, 2009
Speedqueen heavy duty extra large capacity trips power
Does this happen simply plugging it in? Or is it when you try to operate it? If it occurs as soon as plugged in, you may have grounded something inside the unit during transport that is causing the power to trip. Or you could have a faulty breaker. If it is when trying to use it, determine if the circuit load is adequate for the unit. There may be other items on the circuit causing it to overload when operated.
Aug 01, 2016 | Washing Machines
I have a 2007 Eddie Bauer Explorer how do I fix the message center that keep flashing circle slowly then it flashes calibrate complete.
Do you have base instrument cluster) or high series instrument cluster) ?
Symptom Chart Condition Possible Sources Action
  • The message center is not operating correctly (base instrument cluster)
  • Instrument cluster
  • OBSERVE the operation of the message center when pressing the TRIP/SELECT button. Does the message center display change when the TRIP/SELECT button is pressed?
    • If the message center display changes, the system is operating normally at this time.
    • If the message center display does not change, INSTALL a new instrument cluster. REFER to Section 413-01 . TEST the system for normal operation.
  • The message center is not operating correctly (high series instrument cluster)
  • Message center switch
  • Go To Pinpoint Test A .
Jan 24, 2015 | 2007 Ford Explorer Eddie Bauer
Earth leakage trips when i switch on jacuzzi
There is a ground fault somewhere...you need to isolate it with an ohm meter.
Dec 02, 2013 | Jacuzzi Water Heaters
Breaker trips intermittently will go weeks without tripping seems like it trips during or after a heavy rain
This is often cause from the start capitors or run capacitor being faulty.
You can disconnect the pump from the power and using an ohm meter test the capacitors to see if you have a bad one.
You can purchase these replacement caps at almost any local Electrical contrators or Motor rebuilders.
Oct 08, 2013 | Plumbing
Maytag front loader 2000 series code LF followed instructions in manual and has no power. Outlet works
Hi, is this a new washing machine? If not, then these Maytag front loading washing machines use a paraffin locking switch in the front panel to lock the door during operation. Now, if the switch has gone south and trip the the lock switch without locking the door. Then the washing machine want turn on.
What is a parfin locking switch work is a small container with paraffin (wax) in it with a heater. When the washing machine is turn on. The control board indicate that the machine is in operation and a small amount of current is applied to the paraffin switch to the heating element. This make the parfin to expand trip the locking mechanism and locking door during operation. Keep the door lock from accidental openings. It will take about 4 minute after the washing machine has quite it running operation to open the front loader door. The paraffin needs to cool down to release the locking mechanism. stewbison
Aug 20, 2011 | Washing Machines
Jacuzzi hot tub model J-300 series with an FL-1 code. I have shut off power at box and restarted a couple of times and the circulation pump reset. Now the reset won't happen. Both pumps still operate and I...
A flashing “FL1” display means the flow switch is
malfunctioning open, the filter cartridge is excessively
dirty or an “air lock” condition has occurred at the
circulation pump intake.
Jan 06, 2010 | Jacuzzi Signa 6 Whirlpool JAC-B540...
Samsung front load clothes dryer not working.
may have loss to one line of voltage.may only have half the voltage required to power the machine.make sure proper voltage is coming to wiring block at bak of machine.may need voltage meter.
Oct 16, 2009 | Dryers
I need to change the time on it.
You can try the following steps
Setting the clock
1 Press and hold SEL (select) for more
than 2 seconds.
“DEMO,” “CLOCK H,” “CLOCK M,” “DIMMER,”
or “AMP GAIN” appears on the display.
2 Set the hour.
1 Select “CLOCK H” (hour) if not shown on
the display.
2 Adjust the hour.
1 2
3 Set the minute.
1 Select “CLOCK M” (minute).
2 Adjust the minute.
1 2
4 Finish the setting.
To check the current clock time or change the
display mode
Press DISP (display) repeatedly.
Each time you press the button, the
display changes as follows:
• During tuner operation:
• During CD operation:
• During power off:
The power turns on and the clock time is
shown for 5 seconds, then the power turns off.
Thanks for using Fixya
Proton
Jul 27, 2009 | JVC KD-G200 CD Player
P4/not booting up upon start
Hi try to open you chase and unistall all the additional slot cards and try to boot up, sometimes one of the slot cards fails and if that happens your machine wont start up until that slot cart is removed, thats how your machine protects it self
May 08, 2009 | Intel D865GBF Motherboard
Home Logo
Top Jacuzzi Home Experts
Mike
john h
armylifer
Level 1 Expert
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
