Question about Canon NP 6050 Copier
MY NP 6340 is showing ERROR E 60 WAHT IS THE SOLUTION FOR THAT
How can I solve the E 800 error of Canon copier NP 6340
Your error code of E-800 means an open circuit. Most likely a bad power supply or main dc controller pcb .......probably not worth repairing due to the age of that copier.
Nov 11, 2014 | Office Equipment & Supplies
Error C:04:00
  1. Turn off the camcorder.
  2. Remove the battery or disconnect the AC power adapter for 60 seconds.
  3. Insert the battery or reconnect the AC adapter.
  4. Turn on the camcorder.
  5. If the error message appears, service may be required.
If your camcorder still shows the same error code, then you'll have to send in your camcorder for service.
Shamelessly copy pasted from another forum.
Jul 29, 2010 | Sony Handycam DCR-SR40 Camcorder
Brand new Lg dryer 2501, error code ''nP''
I had the same issue with two new dryers. The rep on the phone said nP can also indicate a power issue. It turned out one of the wires in the outlet had broken off. Rewiring the outlet solved the problem.
Mar 05, 2010 | LG Dryers
Canon NP 6230 copier - what does error code e244 refer to?
you have a scanner or lens problem look in the glass when you turn it on both the scanner and the lens should move some
Jan 13, 2009 | Canon NP 6230 Copier
Error code E004
the error has nthing to do with the drum!!!!!!!!!!!!!!!!!
I can tell you how to change it,but it will still have the code.
You have either a blown fuser lamp or thermofuse, you should change that before the drum since you still won't be able to use it?
Oct 28, 2008 | Canon NP 6050 Copier
Canon photocopier
Title : E020 Error Code Problem :
When you have followed all the steps from the troubleshooting guide in the Service Manual and still have not resolved the issue, here are some possible areas that might be related.
Solution :
1) Confirm that the toner and hopper sensors are being wiped completely.
2) Check the Gear Train on the hopper assy it may be locked up.
3) A possible bad hopper unit cable. FG5-5016-000. See The Parts Catalog page 620-2 item # 60.
Canon USA, Inc. Systems & Technical Support Division 1-800-528-2830
Jun 27, 2008 | Canon NP 6050 Copier
Finding acessories
According to the jazz camera website (http://www.jazzcameras.com/Product_Details/DV-169.htm) The DV169 uses a "NP 60 Rechargeable Li-ion Battery" I would do an ebay or google shopping search for "NP 60 Charger"...by the looks of it these are used by many different digital camera companies, but make sure to compare yours to the one in the pictures...plus look at your battery itself and make sure it says NP-60 somewhere on it. If you prevoiusly had to plug something directly into the Jazz camera, now you would just remove the bettery from the unit and charge it externally. Plus it looks like there are a bunch of deals where you could get a second battery out of it too.
Jan 30, 2008 | Jazz DV-169 Digital Camera
Canon NP 6050 Copier Logo
191 people viewed this question
old marine
old marine
