Question about Samsung SyncMaster 753S 17" CRT Monitor
Samsung SyncMaster 793s monitor - Samsung SyncMaster 753S 17" CRT Monitor
    Problem Solver:
  • 26 Answers
Kindly give me More detail for your problam , Did you find any kind of message on display Or nothing at all ?
Shahzad Rashid ( Sunny - IT )
Cell - +971 555 2008 74.
Posted on Mar 24, 2011
SOURCE: Samsung SyncMaster [Monitor] (22.0 - I need best settings
hi , any has got the drivers for this monitor , kindly let me know to download it . regrads
Posted on Nov 10, 2008
vanbiaka
  • 104 Answers
SOURCE: i want defalt settings of samsung syncmaster 793s
The default resulution is 1024 x 768, you can keep the Screen Refresh list at 75 Mhz
If you have been at "Out of Range" then you need to reboot and press F8 before windows load up, then choose VGA Mode. When windows finished loading you can fix the resolution again as you like. Hope this fix your problem
Best Regard!
Posted on Dec 03, 2008
Benimur
  • 6966 Answers
SOURCE: schema diagram samsung syncmaster 551v
Hi and welcome to FixYa,
Initially, pls try here.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 10, 2008
  • 36 Answers
SOURCE: cannot set my SAMSUNG SYNCMASTER 710V MONITOR RESOLUTION
hello
I am a technician-informatic. I have repaired about 80 Lcd Samsung monitors with theese problems. I offer the repair manual.
Manual has been done with the experience of the repairing Samsung Lcd monitors. Manual was made by me and shows how to open monitor, how
to solve dark screen problem, how to check and replace capacitors, how to solve the problem non-optimal mode (without reprogramming MCU or
changing the main board) photo are included. 100% functional. The repair process is very simple 30-40min. (does not need a lot of
experience in electronics and expensive instruments) and is not expensive. With this manual you can solve problems by yourself and save
money.
"Not Optimum Mode 1280x1024 60Hz"
- The monitor turns on but turns off by itself, the LED blinks green.
- If you detach from the PC points to "control cable" the picture runs continuously in the vertical direction or presents while line , and
as soon as it is reconnected, the monitor goes off.
- The monitor does not turns on and dont dispaly anything, the LED blinks green-lit, if you detach from pc points to "control cable".
- The monitor turns on, works well some time, but after a window apiers "Not optimum mode. Mode recommended 1280X1024 60Hz"
- The monitor turns on, works well only with low resolution 800x600, when try to change a window that reads "Not optimum mode. Mode
the manual you can find on ebay (my ebay name is asnerejas123):
Samsung monitor repair manual guide 710n,913v,510n more
220498646211
Riparazione - repair Lcd Samsung monitor 710n,913v,510n
220498645860
Reparaturhandbuch für Samsung 710n,913v,510n und andere
220499443698
Posted on Oct 27, 2009
How to know our samsung crt black monitor 17" warranty?
Most SAMAUNG monitors have 3 years warranty.
It has 3 years warranty from purchasing date:
http://www.superwarehouse.com/Samsung_SyncMaster_793S-Black_17_CRT_Monitor/793S-BLACK/pw/422156
Please leave rating if it helps.
Jan 07, 2011 | Samsung 793S 17" CRT Monitor
No width for samsung syncmaster 793s crt monitor why
Click Display in Control Panel "Monitor" alter specs.!
Nov 02, 2009 | Philips 105S51 15" CRT Monitor
I want defalt settings of samsung syncmaster 793s 2004 model monitor
Best Regard!
Dec 03, 2008 | Samsung 793S 17" CRT Monitor
A black flickering line about 5" from the bottom on my samsung syncmaster 793s 17" CRT Monitor
Hi rkarthea,
Well to narrow down the problem I would suggest first that you try to disconnect the monitor from your APC Back-UPS and just plug it directly to the wall outlet, UPS or surge protectors may cause interference at times with some electronic devices. Then if it's still here, I would recommend that you try to degauss the monitor, all CRT monitors have this option in the OSD. You should also check if there is any magnetic device near the monitor, like a speaker or phone that can cause this. If another PC is available can you try it there also, see if the problem is seen on another PC.
Finally, run the monitor self-test, to do this just leave the monitor plugged into the power outlet and disconnet the video cable, and you'll see it. If the problem is still there then most likely the monitor will have to be checked in a service center or be replaced eventually, since this would already be a hardware problem. Especially since you said the problem is apparent even in the OSD.
Hope this helps!
Peace! :)
Oct 23, 2008 | Samsung 793S 17" CRT Monitor
Increase or decrease of contrast
Rammohannnnn........wake up!!!
Try the same processed again like last time go to contrast, this time press the + buttons to increased the contrast to the desired setting. Have a nice day!
Sep 28, 2008 | Samsung Computers & Internet
Monitor problem
1240/1024 and 75hz refresh rate
May 09, 2008 | Samsung 793S 17" CRT Monitor
Monitor settings
You can increase brightness by eht .Move button of screen that is placed on eht
Hope this solution works
May 06, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Focus on monitor
Try replacing the filter capacitors on the video circuit.
Apr 28, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Samsung SyncMaster 753S 17" CRT Monitor Logo
238 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
