Question about Simrad AP24 AUTOPILOT DISPLAY UNIT
Problem: Autopilot does not engage. This is a new problem as it was working quite recently. Model: Simrad NSE8/AP24 with AC42 Autopilot Computer. Attempts to engage the autopilot result in an error message indicating that a Rudder test needs to be done. This test was accessed by Menu-Settings-Autopilot-Installation-Commissioning-Rudder Test and the test was run. Result: Failed Min Drive. The actuator pump was heard to run at ever increasing speeds during the test but the steering wheel did no move, nor did the actuator arm. The test was run numerous times, with the same result. For one test the actuator arm was disconnected from the steering mechanism. The result was the same - no movement of the actuator arm indicating that it was not a high load problem. Voltage measurements across terminals of the autopilot computer during one rudder test indicated that both drive engage terminals were at 12 volts when the actuator pump was running, This is counterintuitive to what I would expect.
  • 3 Answers
Jimtippettau:
Which drive are you using with the AP24, is it just a hydraulic pump on a powerboat, like our RPU80, or is it a hydraulic linear drive (like our HLD-2000) or draglink drive (like our DD-15) on a sailboat?
Posted on Mar 31, 2011
I have a Simrad hydraulic drive HLD2000L autopilot on my boat. I can not find the recommended ISO VG 32 oil. Are there any substitutes that can be used until I find he correct oil? PS I am in the...
International Standardization Organization (ISO) established a viscosity grading (VG) system for lubricants. According to the system way lubricants are designated by the letters ISO followed by a number equal to the oil viscosity measured in centistokes at 40°C (104°F): ISO VG 32. Any atf, thf, stou, ps- fluid or aw32 hydraulic oil. Visit the next link and look for the Hydraulic Fluid Cross Reference Chart for hydraulic fuild brand reference: http://www.hfifluidpowerproducts.com/Pages/Hydraulic-Fluid.html
Mar 04, 2011 | Simrad AP24 AUTOPILOT DISPLAY UNIT
Selenoid bypass valve has failed
Contact don@sun-me.net and he can help you.
May 07, 2010 | Simrad Ap1603r Autopilot Ap16 Rc36 Rf300...
Simrad AP 11 Autopilot control head
I happen to have an ap11 head unit in good condition, please contact me.
Oct 28, 2009 | Simrad Boating
Testing Simrad Autopilot RPU160 Reversible Pump (21118237)
yes, hook it to 12V it runs, reverse wires it runs opposite it will spit oil, watch out! shoulda coulda left it in place and tested with jumper cables or battery if pump is bad 1 find out why your boat eats pumps 2. call me, i have it in stock for less than you paid before (most likely) 3. you can replace the electric motor without disturbing the hydraulics!!!
847-746-0100
Sep 13, 2009 | Simrad Rpu160 Reversible Pump 21118237
Problems talking to autopilot
I think you use the NMEA output to the autopilot .
The plotter shows you only when you have a seatalkconection with a Raymarine autopilot on you Plotter
Apr 06, 2009 | Raymarine E120 Multifunction GPS Receiver
Simrad ac10 current overload
Normally this is the electric motor causing this problem. Just went on a call and had the same thing. Checked voltage coming from the AC unit to the motor and had 12 vdc then put a new one in it's place and it solved the problem. You don't have to change the pump portion, just change the motor itself. Indeed you will have fluid leaking but many times it's better than plumbing in a new pump.
Feb 18, 2009 | Simrad Ac10 Course Computer
Tppk26 feed circuit broke
I got Marine Superstore in Port Solent to order one for me. Your local friendly chandler should be able to order it up for you. Cost me £24 inc...
Jan 25, 2009 | Simrad Tp32 Autopilot Up To 39'
Simrad AP24 AUTOPILOT DISPLAY UNIT Logo
570 people viewed this question
Top Simrad Boating Experts
Steve
Steve
ray gallant
Don A
Don A
Are you a Simrad Boating Expert? Answer questions, earn points and help others
