Epson 4880 service req 0001001b - Office Equipment & Supplies
leroyal
  • 2120 Answers
SOURCE: I have a service req E527 error on my Epson printer. how to fix?
To fix the E527 error, close the front panel (cover A) and open the top cover (cover B). With the photoconductor unit removed, the toner carousel will rotate. It only rotates if cover A is closed all the way. You can easily rotate the carousel to a position where you can remove/reinstall the stuck toner cartrdige. report_dis_text_13954 = 'We\'re sorry but you must be signed in to report inappropriate material. Click the button below to sign in or register.
  • Sign In / Register »
  • Cancel »
Posted on Jan 17, 2009
jacklee366
  • 541 Answers
SOURCE: Turn the printer on and I get this message:
try this turn off the printer
then...
hold the power button and the pause button together, it enters factory rest mode
Posted on Mar 09, 2009
  • 1121 Answers
SOURCE: EPSON 9800 foutmelding SERVICE CALL ERROR
did you used a non-original ink cartridge? if you did your printer says"ERROR 0001001B" is print head error. need to be replaced, send to repair.
Posted on Aug 08, 2010
broyyce
  • 30 Answers
SOURCE: Epson 4880- gives error message MNT
This error code means that you have printed so many pages that it's time to get your printer serviced. Kind of how you get your car serviced after so many miles. I'd reccomend bringing it to the nearest printer repair shop. Most will just install a maintenance kit and reset the maintenence count. It will continue to print if you put off getting it serviced but who knows how much longer. It's better to get it done now before it craps out on you and you have to print something really urgent.
Posted on May 20, 2011
SOURCE: I have an epson 4880
Service Request errors in the range 00010004 - 000101D are related to a carriage movement problem. In some instances like paper jams, the carriage locking tab may be partially pushed in, causing the carriage locking mechanism to put a drag on the carriage or lock the carriage completely. This will cause a carriage error. Make sure the carriage locking tab is pulled to the left. Then turn the printer's power off and release the carriage by pushing down on the cutter blade. Slide the carriage to the left and look for any paper that also may be restricting the carriage from moving freely.
00010004 CR Motor encoder check error 00010005 CR Motor out of step 00010006 CR Motor over current 00010007 CR Motor in-position time-out 0001000A CR axis detection error 0001000F CR Motor PWM output faulty 0001001D CR servo parameter error
The T-Fence may also be dirty or out of the carriage encoder. Check to make sure it is clean and in the center of the encoder. Contact Epson for additional assistance.
Posted on Jun 20, 2011
What does "service req. - 00010005" on epson 4880 printer mean?
http://largeformatrepairs.co.uk/errors/epson/sp4880/00010005/
Quoting from the link above:
Service Call Error 00010005 CR Motor Out Of Step During CR Motor operation, there may be a case where the encoder pulse signal within the specified range is not input within a specified period of time or the pulse width is extremely long or short. In such a case, the CR Motor is judged to be out-of-step, so that this message is displayed and the printer stops operating.
This error occurs on the Epson Stylus Pro 4880 large format printer and is not a routine maintenance request.
May 02, 2018 | Epson Office Equipment & Supplies
Service req 10037
i have the same 10037 error code in my machine. On internet is says it is 00010037 Print Head thermistor error. I can not understand the problem and service employee could not solve.
I would really appreciate if you can tell me what was the reason of the problem in your machine how the problem is solved on your side?
Best Regards
Cagr
Jan 13, 2013 | Epson 4880 Stylus Pro InkJet Printer
Service req 10037
Hello fddf,
Best Regards
Cagr
Epson 4880 stylus pro service req. 10037
Hello Frank,
Best Regards
Cagr
May 23, 2012 | Office Equipment & Supplies
I have an epson 4880 with an error reading "service req. 0001001d" How can I fix this
May 09, 2011 | Epson 4880 Stylus Pro InkJet Printer
EPSON 9800 foutmelding SERVICE CALL ERROR 0001001B
Aug 08, 2010 | Epson Stylus Pro 9800 InkJet Printer
Print head error 00010028
i have epson 4880. but now printer showing service Req. 00010028. pl tell me how to solve this problem
Jan 26, 2010 | Epson Stylus Pro 4800 InkJet Printer
Stops printing half way through a canvas
The service manual says
"0001001B Head driver (TG) temperature error"
Head failure or head cable splicing defective/breaking of wire
Solution
 Head cable joint
 Head Assy exchange
You might try pausing the printer for 10 minutes, before it gets to the halfway point to let it cool down, then un-pause it.
You don't say how large the canvas is. If it is 44" by 60" or something large, above might be OK, if it is only 24" x16", it might be more trouble than it is worth, unless you are only printing a few.
Mar 24, 2009 | Epson Stylus Pro 10000 InkJet Printer
then...
Mar 09, 2009 | Epson Stylus Pro 4800 InkJet Printer
512 people viewed this question
k24674
jasbo
jasbo
