Question about Navman GPS
The visable satelite signal icon has turned red and the device freezes at the "finding your location" stage. The model is a S45 purchased in 2008 and used rarely, although was operating perfectly yesterday.
    Top Expert:
  • Navman Master
  • 75,452 Answers
Hello
Changing satellite signal symbol to red indicates that "Subscription Expired" Right click to purchase subscription.
In yellow colur indicates "Subscriptions Available". "Right click to Update and purchase new subscription".
In green denotes "Active Subscriptions". No updates are available for this subscription.
Activate your Subscription
Start => All Programs => Navman => NavDesk
1. From Available Subscriptions section, select the country for which you want to activate the safety camera.
2. Right click and select Activate my subscription.
The Activation window will display.
3. Enter the subscription product key in the Product Key field.
4. Click Continue.
Follow the prompts to update your subscription.
Your software will update automatically.
Posted on Mar 24, 2011
How do I download the updates to my TOMTOM GPS
You use a program from tomtom wesite named tomtom home. Download to pcinstall it then connect device to pc using usb cable. The tomtom home program will list all updates available and install all free ones. Ensure you make a backup first. If you have accidentally selected the flight mode from the menu options this turns off the satelite receiver so check this setting also from the menu you can select the satelite network and see if there is a signal being received and how many satellites it is connecting to. It requires at least three to function and possibly will not work with less than five if there is none then a reinstall of the program will need to be done following instructions from web site on reinstalling the application. You must backup the device first as you cannot download a free map. Follow the website instructions and if there is still no satelite signals being received then its busted. From the main map screen the signal strength may be segn as a small icon like a volume icon. Press this and you also get signal information.
Mar 19, 2013 | Tomtom One GPS
Uppon "swich-on", my magellan gps 315 does not
GPS SYSTEMS HAVE A TENDENCY TO LOSE CONNECTIVITY TO SATILLITES BECAUSE OF BAD WEATHER, CLOUD COVER, TUNNEL ENTRANCE, BAD OR NO POWER, BATTERY LIFE HAS BEEN EXPENDED, HAZARD OF ELECTROMAGNETIC INTERFERENCE TO GPS SYSTEMS, AND IMPROPER VEHICLE MOUNTING AND HAND HELD POSITION. FREE SOLUTIONS 1. ALWAYS PLACE YOUR GPS DEVICE IN THE UPPERMOST PORTION OF YOUR VEHICLE SO THAT THE GPS SIGNAL MAY EASILY LOCATE YOUR DEVICE EVEN WHEN THE WEATHER IS BAD 2. KEEP YOUR BATTERY CHARGED ONLY WHEN IT NEEDS IT MOST AND AVOID CHARGING OFTEN 3. IF YOU OVERCHARGE YOUR GPS DEVICE, YOU WILL EXPERIENCE BATTERY LEAKAGE, WHICH CAN EAT AWAY AT YOUR CLOTHING, DESTROY YOUR DEVICE IN SECONDS, AND CAUSE DAMAGE TO YOUR VEHICLE SEATS 4. YOUR GPS DEVICE HAS A TENDENCY TO FREEZE BECAUSE OF THE SIM AND MEMORY CHIPS LOCATED WITHIN IT 5. YOU CAN FIX THE FREEZING PROBLEM BY REMOVING THE SIM CHIP AND MEMORY CHIP AND RESTARTING YOUR SYSTEM 6. OTHER FREEZE PROBLEMS OCCUR BECAUSE THE DEVICE IS COLD WHEN IT IS KEPT IN THE VEHICLE AND CHIP CREEK OCCURS WHERE THE DEVICES MICROCHIPS BECOME LOOSE AND TIGHTEND BECAUSE OF WARM AND COLDER AIR FLUCTUATIONS. IT IS BEST TO KEEP THE DEVICE IN A PURSE OR ON A TABLE WHERE IT IS NOT SUBJECT TO CONSTANT TEMP. CHANGE 7. PREVENTION OF ELECTROMAGNETIC INTERFERENCE IS BEST SOLVED BY: interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common
Jan 23, 2011 | Magellan GPS 315 GPS Receiver
Since a few weeks ago, when turned on, "GARMIN"
Jan 20, 2011 | Garmin nuvi 1300 Car GPS Receiver
Old Panasonic tv approx 10/12 y/o? -Model TX-28CK1L Serial no ND-0360158 Last night 50% of screen from top to middle "blacked out"--half picture still visable on bottom half. Very bright thin...
The main coupling capacitor feeding the frame scan coils has failed or the output stage on the frame stage has failed due to dry capacitors or dry joints.
Fault finding and components are not a problem and yes it is very repairable. Any technician that knows how television works can repair this standard frame output stage.
I hope you find a good technician.
Dec 30, 2010 | Panasonic Televison & Video
Just got logik ldvr 1608 dvd but it cant find any
You need an aerial to tune the freeview.
However, to record from satelite you can connect a scart lead from the satelite vcr out to the dvd in and it will record vie the av "channel" on the dvd.
Depending on your location, regarding signal strength, you can purchase an indoor, boosted aerial to tune the freeview.
Also, if the scart connection on the dvd is a 2 way connection( allowing a signal to the tv as well as from the tv) you can connect the tv to the satelite and the dvd to the satelite only and the dvd will play through the satelite even when the satelite is off.
Aug 26, 2009 | Televison & Video
Cannot acquire satellites and freezes
use the web-updater at garmin
or update the firmware at garmin,
turn WAAS on
turn GPS signal off
go outside after the update
turn GPS signal back on ( takes upto 15 mins to locate satelites )
should be good
Regards
Richard.
Apr 21, 2009 | Garmin StreetPilot C330 GPS Receiver
Gps model 330
-after the units have been off for awhile...they need considerable time to reconfigure the satelites
-so.....
  1. go outside with unit turned on
  2. find an open area...with a clear view of the sky...i.e. away from trees/bldgs/etc.
  3. wait...upwards of 20+ minutes...depending upon your unit
  4. it should be picking up signals continuously...and begin to calculate your location
-the above assumes that the unit has batteries, hasn't been dropped, etc.
-if that is the case....then the unit has other issues
Nov 06, 2008 | GPS
Locating satelites
Are you outside, exposed to the GPS signals?
If so, have you tried resetting the unit?
Remove the face cover (GENTLY pry it loose by using the fingernail groove directly under the GARMIN logo), press the RESET button, then re-attach front cover... this is covered in the owners manual, also available online at garmin.com /support /downloads
Feb 27, 2008 | Garmin StreetPilot c340 GPS Receiver
GPS Logo
Top Navman GPS Experts
Martin Murray
Are you a Navman GPS Expert? Answer questions, earn points and help others
