Help.i want to format this laptop compaq armada m300 but seems that cannot boot from external dvd drive.. boot selection available is floppy (which the laptop doesnt have)/hard drive/ethernet/multibay..which should i choose from?
  • Ghost Tech
    Ghost Tech Mar 24, 2011
    oh no...thr is only one usb port..its just made with only one usb port..whts SB drive?
    Scholar:
  • 135 Answers
Try to update bios or go to a SB drive to do what you need
Posted on Mar 24, 2011
    Problem Solver:
  • 16 Answers
Try plugging your external drive into a different USB port.
When a compaq armada m700 laptop is showing non-system disk or disk error replace and strike any key when ready
this usually happens when the computer is trying to boot from a disk that isn't a valid boot disk.
if you have a floppy drive plugged into the multibay and a floppy in the drive, try removing the floppy.
if there is no floppy involved, try to boot from your system recovery disks, as it's likely that the boot record on the hard drive will need repaired. your system recovery disks should walk you through the process.
Nov 03, 2011 | Compaq Armada M700 Notebook
My compaq armada m300 wont recognise new hardrive
just try with fixing the hard drive connection properly and in bios also check how much capacity motherboard can support .according to your specification it will not support the higher capacity hard disk .make sure you installing the new hardidsk as same capacity of your older hard drive.
Nov 25, 2009 | Compaq Armada M300 Notebook
I got ahold of an old Compaq Armada M300 but it has no operating system. I tried installing Ubuntu and Xubuntu but it says that the bios age 1999 cuts off at 2000. I downloaded the BIOS update from compaq...
Borrow a USB floppy drive, copy the update on a floppy disk. You will need a floppy to update the BIOS of the old computer anyway. Reviving a defunct machine with Linux is a worthile endeavor.
Hope it helps.
Aug 31, 2009 | Compaq ARMADA M300 11.3" Flat Panel LCD...
Compaq armada e500
you can safely install up to a 80 GB HDD in that compaq. When getting into the bios go to the boot sequence section and change the boot squence to be CD=>HDD=>FLOPPY or FLOPPY=>CD=>HDD
Jun 02, 2009 | Compaq Armada E500 Notebook
How to install operating system on laptop with now cd-rom drive or floppy
Did you change the '1st boot' drive to the optical drive?
If you haven't, you need to enter the BIOS setup and change from C: to whatever your optical drive is named and then change it back once the operating system is installed on the C: drive.
Oct 11, 2008 | Compaq Armada E500 Notebook
Please help me with my COMPAQ ARMADA 1700
plz check the hard disk cable if its ok then your hard disk may be bad.
Jun 11, 2008 | Compaq Armada 1700 Notebook
HELP
Are you trying to upgrade 95 to 98SE or just new install of 98.
What you may have to do is
  1. insert win 98 boot floppy
  2. boot with cdrom support
  3. at the prompt change to cd drive E:\ (press enter)
  4. at the E:\ prompt type cd Win98 (press enter)
  5. at the E:\Win98 prompt type format C:\ (press enter)
  6. confirm all data will be erased
  7. reboot with floppy in and at the a:\ prompt run FDISK to see if the full size of the hard drive is available. (option 4)
  8. If everything is normal exit fdisk reboot with floppy, choose with cdrom support, type in the cdrom drive letter (usually e) and cd Win98(change directory Win98)
  9. at the win98 prompt type setup (press enter) and follow the prompts.
May 30, 2008 | Compaq Armada 1500C Notebook
HOW TO BOOT
If you have access to an external drive enclosure, OR you have a computer you can put the hard-drive from
that machine in temporarily, put the drive in one of them and copy the WIN98 directory to the harddrive.
Once the WIN98 directory is there, you can just install it from there. That is of course if the hard-drive has been
formatted with the /sys command, and set to primary boot drive using FDISK. As far as installing from floppy,..
the floppies haven't been on the market for a LONG time, and if you have them,.. I imagine they've seen better
days. If you HAVE to install from floppy though, use another computer, put in the CD, open the cd using windows
explorer. Once here, click on the WIN98 directory, and locate the files you need ( too many files and directories
to list here ) Seriously the best way would be to use an external drive enclosure ( since it's probably a 2.5" drive
size ) and just copy the whole directory to the drive and forget the floppy idea. It will take MUCH less time.
Feb 25, 2008 | Compaq Armada E500 Notebook
Boot sequence problem
try booting to DOS screen only by inserting a boot-able floppy disc (I use Win ME disc at this point although my system is also Win XP). Then select "boot with CD-ROM driver". It will detect your CDROM drive and assign a letter. Now insert the CD and boot from there. I have done this sequence many times with no problems.
Jul 13, 2007 | Compaq Armada E500 Notebook
Boot up with no operating system
When the system starts, hold the F10 key and go into BIOS and set CD Rom as 1st Boot device (in Boot Order). Because most Compaq's would put the BIOS in a hidden NON-DOS partition on the hard drive, you may have to get an OEM recovery disk for that model. Because there is no BIOS to go to, the machine doesn't know it has a CD, HD or Floppy to go to. A boot floppy/CD is no help. Alternative 1: With another desktop and IDE to Laptop HD connector, FDISK (make active partition and hidden partition [5mb]), Format both, copy the cabs from WinME CD to c:\windows\options. Alternative 2: Find the COMPAQ OEM CD for that model. Since there was no exact model number Click here Please indicate whether this is helpful or not.
Oct 28, 2006 | Compaq Armada 1750 Notebook
Computers & Internet Logo
David Payne
David Payne
