Question about Pentax AF-500 FTZ TTL Flash
Is it OK to use a Pentax AF500FTZ flash on-camera with a Nikon D70s? Is the trigger voltage going to be a problem? It looks like one can use a Nikon flash on a Pentax DSLR without problems.
  • 685 Answers
The brands use the flash contacts to communicate to the camera. They do not make their flashes compatible with other brands. Don't mix brands. Even if trigger voltageis not an issue, the TTL and AF is not going to function.
Posted on Oct 21, 2014
FlashyBits
  • 11 Answers
SOURCE: Vivatar 283 and Nikon D70s
The Vivitar 283 was manufactured in China & Japan over a number of years & the specifications did change over this period.
The older Vivitar flashes had a voltage on the shoe which could reach 150 volts whilst the later ones had voltages of only 5 to 9 volts.
If you have, or can get hold of, a small voltmeter then you can measure this voltage.
Turn on your flash & let the unit charge up to 'ready' & connect the meter between the contact in the centre of the shoe & the little contact tucked away in the lip of the shoe. (DC volts not AC) There is no danger to you in doing this!
This should tell the voltage on the shoe of your unit & if it is 15 volts or less, it will be fine with your digital Nikon camera. If more than 15 volts than best not to use it.
Hope this is of some help!
Posted on May 09, 2008
  • 4 Answers
SOURCE: Sunpak Auto zoom 3000 thyristor
r-sensor to plug in accessory remote sensor for use instead of the fixed one on the front. This allows flash to mount to the side with the remote sensor on the hotshoe. The other socket that has the interlock with the power switch is for a high voltage input (500V input!) from a special mains powered adapter for continuous power and faster refresh instead of using the batteries.
Posted on Oct 26, 2008
lightingman
  • 22 Answers
SOURCE: what is the trigger voltage for Pentax AF 500FTZ
When using a digital camera with a flash unit of unknown trigger voltage, you are risking the life of your camera. Excessive trigger voltages can disable the cameras internal circuitry to the point where it is totally beyond repair.
I do not have, in my files. the trigger voltage for the specified flash unit. I only have the specs for larger portables and studio flash gear.
A simple test , however, will reveal the exact trigger voltage. If you have a multi-meter or a DV voltmeter with a 250 VDC range (just to be in the safe side) you can preform this test at home or an electronics service technician can do it for you in a few minutes.
The test lead are placed across the synch contacts on the foot of the unit or plugged into the sunch socket if the flash unit has one. If the reading is more that 4 or 5 volts you can still safely use the flash with the aid of a protector device which goes in between the flash and the camera. Theses are available at better camera shops and dealers.
Ed
Posted on Dec 01, 2008
SOURCE: Vivitar 283 with new Nikon Digital camera
the nikon D80 has a 250 volts safe range and i have the same issue but readin on the internet i learned that yo can now the voltage of your flash with a voltage metter ond the hot soe.
Vivitar 283 has diferent ranges of voltages depending on the year of fabrication so older ones can achieve 300 volts and earlier have 230 volts so the best is to get a vivitar 285hv for about 75dollars or a safe sync for about 55dollars, you can find all on ebay or other brouser the safe sync converts up to 400 volts to a safe 6 volts that are yust the normal voltage for digital flashes.
Posted on Feb 22, 2009
  • 685 Answers
SOURCE: Canon Speedlite 199A
No. First the Canon 199 was designed for the Canon camera, and the electronics are very different in the Nikon. Two the 199 was designed for film and the digital metering is completely differnt for digital. Buy a Nikon flash.
Posted on Feb 28, 2010
I have Sunpak 622 Super Pro Handle Mount TTL Flash. Would it be compatible with a Pentax K50?
Before you attach it to your camera you must check the trigger voltage first, never use an old flash unit until you check the trigger voltage with a multimeter, most old flash units have a huge trigger voltage that will damage your camera.
Very simple to check the voltage on that Sunpak 622, turn on your volt meter and set it to about 200 volts DC, turn on your Sunpak flash and apply the RED lead to the bottom contact, apply the Black lead to the side of the hot shoe and look for the ground, usually a small metal piece on the side. Now look at the meter, if it shows a voltage of 6 volts or less then it is safe to use on your camera, if voltage is higher, say 12 volts or more, don't use it. A high trigger voltage will certainly mess up your camera in the long run. Even if it has a safe voltage of 6 volts or less, you will only be able to use that flash in Manual Mode, the newer cameras will not sync or recognize an old flash unit.
I have an old Vivitar flash unit that I can safely use on my Canon XTI because the old vivitar has a trigger voltage of 5 volts, safe for all newer digital cameras.
Mar 04, 2015 | Pentax Cameras
Can I use a Sunpak MG-1 (10+ yrs. old) with a Pentax K-5 II
The voltage across the points when fired is very high on old style flashguns if you try this on a modern digital camera you may fry the electrics in the camera. Get a flash gun that is compatible with your camera Have look at the Yongnuo range.
Feb 21, 2015 | Pentax Cameras
What is the trigger voltage of this flash gun
Okay to use on digital camera.
Trigger voltage is under 11V.
Apr 07, 2014 | Metz mecablitz 45 CL-4 TTL Flash
I have vivitar 2800 flash for my pentax can i use it with Nikon D70s
If there is a D after the 2800 you're probably safe. The trigger voltage is 8 volts so to be sure, find out what the upper limit of trigger voltage the camera can safely handle. If there is no D designation in the model number it will definitely fry the Nikon
Mar 14, 2013 | Vivitar 283 Flash
Metz mecablitz 45 ct 1 and Nikon D-90
The trigger voltage of the 45CL-1 is about 12V, so it should be safe to connect directly to the hot shoe with an adaptor, or to the pc soclet, if the D90 has one. If the D90 is anything like my Canon 40D, which can stand about 30V on the hot shoe, then all the 45CL series will be ok, as they have trigger voltages between 9V and 12V. The 45CT-5 has a trigger voltage of 15V and works well on the 40D. I use 3 different Metz 45 models with my 40D and all work well on automatic, where the flash sensor itself controls the light output.
Jan 26, 2009 | Metz 45 CL-1 Flash
What is the trigger voltage for Pentax AF 500FTZ
Ed
Nov 16, 2008 | Pentax AF-500 FTZ TTL Flash
Nikon SB800 flash
sb-800 trigger voltage is very low.....around 8 volts.
Jul 22, 2008 | Nikon Speedlight SB-800 TTL Flash
Achiever 260 AF for pentax
Check the voltage trigger of the flash, if you're under 7vdc. Then you are good to go.
atdlee@netzero.com
Jan 31, 2008 | Achiever 260AF for Nikon TTL Flash
D70s the flas will not stay closed waht should i try
The flash pops up automatically when half-pressing the trigger in Auto mode.
If you mean it can't be closed by hand, you need to send it to service.
Dec 23, 2007 | Nikon D70s Digital Camera
Pentax AF-500 FTZ TTL Flash Logo
320 people viewed this question
Top Pentax Cameras Experts
mohamed salim shaikh
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
