Question about Nokia X3 Cell Phone
I use Nokia x3 slide mobile phone a number disturb me every time. Can i block it? i want to block one number but x3 dose not have disturbing block list. please helm me some one! my Email is: ahmadi21@live.com
    President:
  • Nokia Master
  • 2,246 Answers
Install application black list caller to your phone
and you can block the number
Posted on Mar 24, 2011
My phone doesnt ring for incoming calls
It can be confusing and frustrating to miss calls because your iPhone isn't ringing. There isn't a single reason why an iPhone stops ringing - but most of them are pretty easy to fix. Try these steps before concluding that your iPhone is broken and needs an expensive repair.
If you're not hearing your iPhone ringing, there are five possible culprits:
  1. A broken speaker
  2. Mute is turned on
  3. Do Not Disturb is turned on
  1. You've blocked the phone number
  2. A problem with your ringtone
Does Your Speaker Work?
The speaker at the bottom of your iPhone is used for every sound your phone makes. Whether that's playing music, watching movies, or hearing the ringtone for incoming calls, the speaker makes it all happen. If you're not hearing calls, your speaker could be broken.
Try playing some music or a YouTube video, and make sure to turn up the volume. If you're hearing audio fine, then that's not the problem. But if no sound comes out when it should, and you've got the volume up loud, it could be that you need to repair your iPhone's speaker.
Is Mute On?
It's always good to rule out the simple problems before diving into more complicated ones. In this case, you need to make sure that you haven't silenced your iPhone and forgotten to turn the ringer back on. There are two ways to check this:
  1. Check the mute switch on the side of your iPhone. Make sure that it's turned off (when it's turned on, you'll be able to see an orange line inside the switch).
  1. On your iPhone,go to Settings and tap Sounds (or Sounds & Haptics, depending on your model). Make sure the Ringer and Alerts slider isn't all the way to the left. If it is, move the slider to the right in order to turn up the volume.
Is Do Not Disturb On?
If those aren't the problem, it could be that you've enabled a setting that mutes phone calls: Do Not Disturb.
This is a great feature of the iPhone, introduced in iOS 6, that allows you to stop sounds from calls, texts, and notifications when you don't want to be bothered (while you're sleeping or in church, for instance). Do Not Disturb may be great, but it can also be tricky - because you can schedule it, you may forget that it's enabled. To check for Do Not Disturb:
  1. Tap Settings.
  2. Tap Do Not Disturb.
  3. Check to see if either the Manual or Scheduled sliders are enabled.
  4. If the Manual is enabled, slide it to Off/white.
  5. If Scheduled is enabled, review the times Do Not Disturb is scheduled to be in use. Did the calls you missed come in during those times? If so, you may want to adjust your Do Not Disturb settings
  6. If you want to keep Do Not Disturb but allow calls from some people to get through no matter what, tap Allow Calls From and select groups of contacts.
Is the Caller Blocked?
If someone tells you they called you, but there's no sign of their call on your iPhone, maybe you've blocked their number. In iOS 7, Apple gave iPhone users the ability to block phone calls, FaceTime calls, and text messages. To see whether the number that someone is trying to call you from is blocked on your phone:
  1. Tap Settings.
  1. Tap Phone.
  2. Tap Call Blocking & Identification (it's simply Blocked on earlier versions of the iOS).
On that screen, you'll see all of the phone numbers you have blocked. If you want to unblock a number, tap Edit in the top right corner, tap the red circle to the left of the number, and then tap Unblock.
Is There a Problem With Your Ringtone?
If your problem still isn't solved, it's worth checking your ringtone. If you have an iPhone custom ringtone assigned to contacts, a deleted or corrupted ringtone can cause your phone not to ring when someone calls.
To address problems with ringtones, try these two things:
1. Setting a new default ringtone. Here's how:
  1. Tap Settings.
  2. Tap Sounds (or Sounds & Haptics).
  3. Tap Ringtone.
  4. Choose a new ringtone.
2. You should also check to see if the person whose calls you're missing has an individual ringtone assigned to them. To do this:
  1. Tap Phone.
  2. Tap Contacts.
  3. Find the person's name and tap it.
  4. Tap Edit in the top right corner.
  5. Check the Ringtone line and try assigning a new ringtone to them.
If the unique ringtone seems to be the source of the problem, you'll need to find all the contacts that had that ringtone assigned to them and select a new ringtone for each. It's tedious but necessary if you want to hear those calls as they come in.
If None of This Fixed the Problem
If you've tried all of these tips and still aren't hearing your incoming calls, it's time to consult the experts. Make an appointment at the Apple Store and bring in your phone for inspection and, potentially, repair.
Dec 14, 2017 | Lands Phones
I want to block all incoming calls except the one in contacts, is this possible ?
Not sure on a Nokia but on an iPhone you use the Do Not Disturb setting. It only lets calls ring from those in Contacts or Favourites.
Oct 31, 2015 | Nokia 220 RM-971 Unlocked GSM 850 / 1900...
Call divert incoming number
unfortunatel your phone does not reject.The only thing you can do is to add that number under screened numbers so that it does not ring when calling you.It will be able to call you but will not ring.
Apr 16, 2014 | Nokia 1280 Cell Phone
When someone calls messae says' not accepting calls' how do i turn this off
Does this happen on all inbound calls or just some?
If this is on all inbound calls...Sounds like Do not disturb is turned on. Most uniden's have a DND (do not disturb) mode. Try turning this off and see if that helps.
Using Do Not Disturb
  • The Do Not Disturb or DND feature turns off the audio ringers of the base and all handsets at the same time. It does not affect any of the visual ringers.
  • With the phone in standby, press and hold Do not Disturb on the base. The phone automatically turns on the answering system and shows Do Not Disturb in the display on all handsets.
  • To cancel, press Do not Disturb.
If this is not the issue, it may be turned on at the central office (your phone company) try using the DND activation/deactivation code of *64 from your phone.
If this is just on some inbound calls...Then it you may have anonymous call rejection turned on. That feature blocks calls from people that block their calling number when placing calls.
Mar 01, 2012 | Uniden DECT 6.0 Cordless Phone ID
Please dont send any message on my mobile and dont cut any balance from my mobile my mobile mo is 08029339237 and also stopped mazook service from my mobile
The process is simple. Send an SMS "DND" to the number which disturbs you so often. DND means do not disturb. You will see that the problem will come to an end soon. Else you are now eligible to charge a file in the court.
Hope this one solved your problem. If you have additional doubts, please come back to us.
Regards
Sunny.
P.S: If the solution is helpful, please accept the solution.
Feb 14, 2011 | Nokia 5130 Cellular Phone
To block a particular no. in my nokia 3310 model
get a number screening software and add that number so that the calls and messages will be blocked by software u can get the software from ovi suite ovi store
May 23, 2010 | Nokia 7310 Cellular Phone
Nokia X3 Cell Phone Logo
342 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
