Question about Durabrand DUR7 Portable DVD Player
Power cord The power cord does not work and I need a replacement
    Champion:
  • 303 Answers
E93839 ka0121
hi
if you are not getting power to your mb then you have to try a different power cord to eliminate if the power cord is faulty
then you will need to consider the motherboard ac jack the power cord plugs into too
that will need to be tested and replaced if faulty
aries
Nov 14, 2013 | Computers & Internet
Hp laserjet 1020 meltdown
Try this out:
Some printers require time to turn on. These printers may or may not give feedback in the form of blinking light(s). Wait up to a minute for the power light to come on before proceeding with the steps below. Instructions If the printer uses a power adapter (module), follow the instructions below. If the printer uses only a power cord, see the section below entitled “ If the printer uses only a power cord .” If the printer uses a power module Follow the steps below to ensure power is properly supplied to the printer:
  1. Check the power module part number against the part number listed in the User’s Guide to ensure the proper power adapter is being used.
  2. Disconnect the power cord or adapter from the wall outlet.
  3. Disconnect the printer data cable from the printer.
  4. Disconnect the power cord from the printer, wait thirty seconds, then reconnect the power cord to the printer.
  5. Disconnect the power cord from the power module and reconnect the power cord to the power module. This may not be necessary if the power module has a permanently attached power cord.
  6. Reconnect the power cord directly into a working wall outlet. If the power cord was plugged into a surge protector or power strip, plug the power cord directly into a wall outlet instead. NOTE: "The HP Photosmart 8100, 8400, and HP Deskjet 6000 series printer power cords feature a green LED built into the power plug. If the LED is not glowing, the power module may have failed. Proceed to step 7 below.
  7. If the printer still will not turn on or the power LED built into the power cord is not glowing, plug the printer into a wall outlet in another room. If the printer or power LED turns on when connected to an electrical outlet in another room, there is a problem with the power in the original room.
  8. If there is still no power to the printer, then the power module, cord, or printer may be defective. Try the power module/cord on another HP Deskjet or Photosmart printer, of the same model if possible, to see if the power module is functioning. If the power LED is still not glowing, the power module may be defective. Replace the power module and cord.
  9. If the power module/cord works on the other printer, then this printer is defective. Service your printer.
  10. If you cannot determine whether the problem is the printer or the power module/cord, or if another printer is not available to test with, replace the power module/cord first. If this does not resolve the issue, service your printer.
If the printer uses only power cord Follow the steps below to ensure power is properly supplied to the printer:
  2. Disconnect the power cord from the wall outlet.
  5. Reconnect the power cord directly into a working wall outlet. If the power cord was plugged into a surge protector or power strip, plug the power cord directly into a wall outlet instead.
  6. If the printer still will not turn on, plug the printer into a wall outlet in another room. If the printer turn on when connected to an electrical outlet in another room, there is a problem with the power in the original room.
  7. If there is still no power to the printer, then the power cord or printer may be defective. Try the power cord on another HP Deskjet or Photosmart printer to see if the power cord is functioning.
  8. If the power cord does not work on the other printer, it is defective. Replace the power cord.
  9. If the power cord works on the other printer, then this printer is defective. Service your printer.
  10. If another printer is not available to test with, carefully inspect the power cord for damage.
  11. Inspect the power cord for visible damage. If the power cord is damaged, replace the power cord first. If this does not resolve the issue, or if the power cord looks fine, then service your printer.
Goodluck,
Dont forget to rate me as fixya..
Jan 30, 2008 | HP LaserJet 1020 Printer
Replace power cord
Definately replace power cord. I work with these microwaves all the time and if you don't it will cause a chain reaction and the fuses will explode into tiny sparks. This is coming from an expert
Jul 25, 2013 | GE Microwave Ovens
I need to find a replacement power cord for this tv, any suggestions? I can't find it
you don't say what has happened to existing cord or what is wrong with cord. Have you tried to get a replacement cord at a tv repair shop?
Nov 24, 2012 | Televison & Video
10 September 2011 I have a Denon clock radio in the kitchen, but it's not working. In fact, it hasn't worked in a long time. Help me. Serial # 71101100576
Hello there,
First you need to check if it is receiving power, try to connect the cord to another device to see if it will power it up. If it does, then it means the power cable is okay and does not need replacement, but if it does not power it up, then it means the power cord is bad and need to be replaced.
If the power cord works perfectly fine, check if the outlet is supplying current by plugging some other device to it to test if it is working.
If the power outlet is okay, then it means the problem is from the power board inside the unit of the denon clock radio. Have the power board checked for bad capacitors. If none found, replace the power board.
This time it should work.
Would be glad to know if this information was helpful to you. All the best Elect_Comp
Sep 10, 2011 | Vacuums
Whenever i plug in my laptop to a power adaptor it doesn't work , it only works with the battery. How can i solve this problem?
You need to replace the ac power cord of your laptop. IF replacing the power cord wont fix the problem. sadly you need to send your laptop to repair center for main board replacement.
Dec 30, 2010 | Toshiba Satellite A205-S4617 Notebook
Power outlet on drive is not working( believe one prong is broke)
The data can be retrieved once the drive gets power. Secondy for the replacement of the outlet or the whole drive you need to check with your vendor if its under warranty then you can get the entire drive replaced instead of the cord else they can suggest better..
Jun 24, 2010 | Western Digital WD Passport 250GB Portable...
Acer AL1916 can't start
If you press the power button and nothing comes on at all then something isn't providing power to the laptop as it should and you may likely need to replace the battery or the power cord.
Find a replacement battery. Change your battery with a new one then plug it up and turn on to see if this works.
If replacing the battery doesn't work then replace the power cord and trying turning it on again. If this doesn't work either, you have a more serious issue going on.
Not too long ago, I was on vacation, my laptop had been working fine until suddenly it wouldn't come on at all. I went into the office to grab a new battery and power cord. (I work on computers so I had spare parts in my office/Tech Room.)
I got home and replaced the battery then tried to turn it on using the old power cord...didn't work. This was a brand new battery so now I knew that I could rule out the battery as the issue...the only two things left to troubleshoot were the power cord and the laptop itself.
I put my old battery back in the laptop then tried to turn it on using a different power cord and it worked. I didn't need to replace my battery or laptop. The power cord had failed.
I hope that your issue is as simple as this solution. Try confirming whether your battery and power cord are still working...you may just need to replace one or the other.
Thanks for using Fixya.
Share your experience by rating this solution.
Mar 29, 2009 | Acer AL1916B 19" LCD Monitor
Not charging
Hello brocstar,
You could have a problem either with the power cord itself or the DC input jack on your GPS.
When you say you wiggled the "power lead" to fix the problem I believe you are referring to the actual power cord. If so, it's possible that the cord has a short that has progressively gotten worse and eventually caused the cord to fail. In that case it should be a relatively simple fix to simply replace the power cord and that's where I would start.
If replacing the power cord doesn't work then the problem likely is with the GPS itself and the unit may need factory service to repair the DC jack, battery or charge circuitry.
Hope this helps,
Ken
"Go Ahead. Use Us."
Jul 10, 2008 | Navman F20 GPS Receiver
Need replacement car power cord for NVX226 GPS
I bought a car charger for a motorola razr for ten bucks at a gas station and it works perfectly. i also bought a replacement cord from radio shack which also worked perfectly but hit me for 24 bucks. Either or is fine!
Oct 22, 2007 | Audiovox NVX226 GPS Receiver
Durabrand DUR7 Portable DVD Player Logo
47 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
