Find the equation of the hyperbola which satisfies the given equation center(1,-2) transverse axis to the x-axis transverse 6 and conjugate axis 12
  • Office Equip... Master
  • 8,073 Answers
I am not quite sure how the major axis of your hyperbola is directed and i do not know if the lengths you give are measures of the major and minor axes or the measures of the semi-major and semi-minor axes. So I am giving you the equations and the graphs so that you can decide for yourself what is appropriate for your problem.
Major axis parallel to the X-axis
Equation and graph
Center is at x=1 and y=-2, semi-major axis length is a=6, and semi-minor axis length is b=12
Major axis is parallel to the y-axis
Equation
Center is at x=1 and y=-2, semi-major axis length is a=12, and semi-minor axis length is b=6.
I trust you can customize the equations to fit your need.
Posted on Mar 26, 2011
Write the equation of a line parallel to the given line but passing through the given point. y=1/4x-2;(8,-1)
Being parallel to the given line, the equation of the line you are seeking has the same slope, which in this case is a=1/4.
So the equation sought is as follows
y=(1/4)x +b, where b is to be found.
To find b, use the stated fact that the line passes through the point (x=8, y=-1). All that means is that the point (8,-1) is on the line whose equation you are looking for. If it is on the line with equation y=(1/4)x+b
then its coordinates x=8, and y=-1 satisfy the relation y=(1/4)x+b. In other words, if you substitute 8 for x, and -1 for y, the equality holds true -1=(1/4)*8 +b
This gives you a way to find the initial value of the function (the y-intercept b ). Just solve -1=(1/4)*8 +b to find b.
I leave this pleasure to you.
Jan 15, 2014 | Mathsoft StudyWorks! Mathematics Deluxe...
Y=1/4x-2; (8,-1)
What is the question? Do you want the distance between the hyperbola and the point? Or did you mean the line y=(1/4)x-2? Do you want the equation of the perpendicular? We can't give you an answer if you don't state a question.
Nov 22, 2013 | Computers & Internet
-6x-3y=27
The x intercept is where your line will cross the x axis. Therefore, the value for y at this point is 0. Substitute 0 for y in this equation and solve for x.
6x + 3(0) = 27
x = 27/6
x = 4 1/2
x intercept = (4 1/2, 0)
Follow the same reasoning for the y intercept.
6(0) + 3y = 27
y = 27/3
y = 9
y intercept = (0,9)
Now plot these two points and draw your line through them.
May 18, 2012 | SoftMath Algebrator - Algebra Homework...
3x+6y=90 what is the y and x intercepts
By definition, the y-intercept is the value of y when x=0. Just set x=0 in the equation and solve for y.
Hence 3(0)+6y=90 or 6y=90. This gives y=90/6=15. The point of intercept of the y-axis is (0,15).
To get the x-intercept, set y= 0 in the equation and solve for x.
3x+6(0)=90 or 3x=90. This gives x=90/3=30.
The point of intercept of the x-axis is (30,0).
Jan 20, 2012 | SoftMath Algebrator - Algebra Homework...
What is the equation of the pair of points (-5,-8) and (-3, -1)
The site seems to eat the plus signs I enter, so I will use PLUS to symbolize addition.
To find the equation of the straight line (
y = a*x PLUS b) that passes through two points P1(x1,y1) and P(x2,y2) , you need to use
1. the coordinates of the points to calculate the slope a (gradient) as a=(y2-y1)/(x2-x1)
2.
Replace the calculated value of a in the equation and write that one of the points ( P1(x1,y1) for example) satisfies the equation. In other words y1=a*x1 PLUS b.
Here y1 and x1 are known values, a has been calculated, and only b is still unknown. You can now use the equation
y1=a*x1 PLUS b to calculate b as
b=(y1-a*x1)
Example: Equation of the line through (1,5) and (3,6)
Calculate the slope (gradient) of the line as a=(y2-y1)/(x2-x1) where y2=6, y1=5, x2=3, and x1=1. You should get a=(6-5)/(3-1)=1/2
The equation is y=(1/2)x PLUS b, where b is not known yet.
To find b, substitute the coordinates of one of the points in the equation. Let us do it for (3,6).
The point (3,6) lies on the line, so 6=(1/2)*3 PLUS b.
Solve for b: 6 MINUS 3/2=b, or b=9/2=4.5
Equation is thus y=(x/2) PLUS 9/2 =(x PLUS 9)/2
I trust you can substitute you own values for (x1,y1, x2,y2) to duplicate the calculations above.
Jan 27, 2011 | Texas Instruments TI-84 Plus Calculator
Find an equation of the line containing the given pair of points (1,5)and(3,6)
The point (3,6) lies on the line, so 6=3/2 PLUS b.
Oct 20, 2010 | Texas Instruments TI-84 Plus Calculator
Find an equation of the line containing the given pair of points (-6,0) and (0,1) what is the equation of the line? y=
Calculate the slope (gradient) of the line as a=(y2-y1)/(x2-x1) where y2=1, y1=0, x2=0, and x1=-6. You should get a=(1-0)/(0-(-6))=1/6
The y-intercept is the y-cordinate for x=0. Its value is 1.
The equation is then y=(x/6) 1.
Oct 18, 2010 | Texas Instruments TI-84 Plus Calculator
What is the forular/working out of- ellipse with a long axis 2.500mm and short axis .850 (double the 0.425 radius) the area is 1.669 thus the area of the part circle is 0.835. what is the formular
I'm not sure what your ellipse looks like but the equation for the area of an ellipse is given by:
pi times the long axis times the short axis
pi = 3.1416
The length of the long axis is from the center of the ellipse to the outer edge of the ellipse
The length of the short axis is from the center of the ellipse to the outer edge of the ellipse
Hope this helps Loringh
Nov 01, 2008 | The Learning Company Achieve! Math &...
Analytic geometry
assuming the question is what is the circle equation?
and if (-2,2) is the center of the circle
the equation should look like this: (x+2)^2+(Y-2)^2=R^2
And now only R is needed.
given 2x-5y+4=0 equation of line perpendicular
we can rearange the equation to be y=(2x+4)/5
from that we can see that the slope of the line is 2/5
And from the fact of perpendicular line we can say that the slope
of the radius line is -2/5.
The motivation now is to calculate the distance between the center of the circle to the cross point of the radius with the line perpendicular
For that we would calculate the radius line equation and compare it to the equation of line perpendicular
As mentioned earlier the slope of the radious line is -2/5.
So the equation is y=-2/5x+b and b can be calculated by using the center of the circle coordinates
2= - (2/5)*(-2)+b ------> b=2-4/5=1.2
radius equation is y=-(2/5)x+1.2
Now the cross point is calculated by comparing the equations:
-(2/5)x+1.2=(2x+4)/5 --> -2x+6=2x+4 --> 4x=2 --> x=1/2 --> y=1
So the cross point is (1/2,1).
The distance between the points is calculated by the following
Formula:
R=SQR(((1/2)-(-2))^2+(2-1)^2)=SQR(2.5^2+1^2)=SQR(6.25+1)=
SQR(7.25)
Therefore the circle eq is (x+2)^2+(Y-2)^2=7.25
Oct 26, 2008 | Casio FX-115ES Scientific Calculator
231 people viewed this question
k24674
jasbo
jasbo
