Question about Oreck Air Purifiers
The red CHECK COLLECTOR CELL wont shut off? - Oreck Air Purifiers
Hi well is the check collector cell wont go off thats telling u the cell is dirty or check the wires ... if all wires are good then deppending on what modle you have reset the unit only on air professional push and hold air revitalizer button down untill check cell light blinks if tha dosnt work it may need service or repair if so call us at 562 924 5200 oreck of cerritos
Posted on Mar 25, 2011
  • rplaisie Jun 01, 2011
    Did that and the warning light went off.
Blinking 'Check Collector Cell' light
which model XL series do you have? There is obviously something shorted or arcing on the plates of the cell. look at the plates and see if they are laying flat and the wires are all still attached across the front of the cell. A loose, sagging, broken or bad contact on the end plates will cause the bad cell lights. clean off the area where the cell makes contact inside the unit. The metal strips that run across the ends of the cell make contact with the plates inside the cell and get their power from them, dirty contacts in any part of these contacts will cause the problem. Even a bad contact from the end cap to the plates inside the cell will cause this. Try wiggling the cell around, kind of push on it on edge to get the plates to shift slightly and clean the points where the plates touch the outer strips on the sides. Check for arcing with the lights turned off,
Oct 20, 2014 | Oreck XL Professional Air Purifier
Oreck XL air purifier (Tower Model)
Is this purifier wet at all, or been in any heavy areas of moisture. This purifier is very undependable with moisture. It may just have to dry out. Let me know if this solves your problem or we can explore further options.
Please keep me updated, thanks
Apr 13, 2008 | Oreck XL Professional Air Purifier
How do i stop the red lite for the collector cell to stop blinking ?
By changing the Collector Cell. The flashing light is an indication that it needs cleaning.
Here is a link to model you listed above. It has all the information you need, on how to clean the Collector Cell. You can download and print it for future reference.
http://www.oreck.com/PUG/3323-8889-Rev-K-AIR8.pdf
Hope this helps you solve the problem.
Mar 21, 2011 | Oreck XL Professional Air Purifier
"Cleaning overdue" red blinking light after cleaning was done
Check that there are no fine pieces of lint that are bridging the plates or the ionizing wires, to ground.
Check the contact points of the collector cell and inside the unit.
The light is caused by a shorted collector cell and associated components.
Dec 21, 2009 | Sharper Image Ionic Breeze GP SI730 Air...
Check collector cell
sounds like you need to clean the cell
Jul 26, 2009 | Oreck Professional Air Purifier Air...
Red Light
slow blinking light means the unit is in DRY MODE.. flast blinking light means some sort of arcing or bad power supply..
if in dry mode let the unit run for an hour and it will stop blinking ..
Jun 28, 2009 | Oreck XL Professional Air Purifier
Red light keeps blinking
I take mine apart when red light comes on and the filters and inside good. It goes off when the unit is screwed back in and turned back on
Nov 15, 2008 | Oreck XL Professional Air Purifier
Red light wont change back to green after cleaning
I did the same thing and now I need to replace the cell collector. You need to replace it to if the wire is broken. Please let me know the outcome of your problem.
Where to find the part is hard to get.
animallover2
Jun 05, 2008 | Oreck XL Professional Air Purifier
Collector cell light always comes on
We purchased one of these in April 2009. Same issue appeared with us. Cleaned the cell and the "clean collector cell" still stayed illuminated. Checked the manual and the trouble shooting section stated to hold down the "air revitalizer button" till the "clean collector cell" light blinks three times. After this operation the light went out and all was fine!!!! Hopes this clears your issue!
Feb 02, 2008 | Oreck XL® Air Purifier
Cleaning the grid
You clean the cell by soaking it in warm soapy water in the kitchen sink: "
soak the Electronic Collector Cell in warm
water in a kitchen sink or bathtub. Mild dish detergent (powder
or liquid) may be added to the water to help break down the
dirt on the Collector Cell. The Collector Cell should be allowed
to soak for two to three hours."
See the instructions here:
http://www.oreck.com/customer-service/owners-guides.cfm#
Dec 29, 2007 | Oreck Super Air 7 Air Purifier
Air Purifiers Logo
1,699 people viewed this question
Top Oreck Air Purifiers Experts
Jerry Greenberg
Jerry Greenberg
Are you an Oreck Air Purifier Expert? Answer questions, earn points and help others
