Question about Sony TA-N9000ES 5-Channel Amplifier
I have a Sony power amp TA-N9000es there is no sound do you need a remote or is there a volume control inside the case. Have tried every input every speaker connect there is just no sound. what can i do it was repaired but have no idea how to operate it.
    Brigadier General:
  • 8,546 Answers
It's just a big amp with no controls you would change during normal operation. There's no remote. You don't name any source or if you even HAVE one attached. THAT would be a good place to look for missing sound.
Register and download the manual for free audio.manualsonline.com
http://audio.manualsonline.com/manuals/mfg/sony/sony_ta_tan9000es.html
http://dl.owneriq.net/f/fede44fb-b9ba-4e03-87bb-d0f3e29e22ef.pdf
Set the BTL/Normal switch on the back to Normal. In fact, any switch or knob with BTL, set it to whatever choice is NOT BTL.
Posted on Mar 24, 2011
Sony TA-N9000ES Power Amplifier Problem: I have a
I have just purchased a Audiosonic Soundbar KW-3508 and connected it up to an existing cetre speaker connection but could get no sound.Any suggestions?
Aug 04, 2013 | Sony Audio Players & Recorders
My digital amplifier S-MASTER,mod HDC-SB300 just 5 seconds after I turn it on swithes off by itself and the standby light keeps flashing and the display stays off and i can do nothing..thanks
hi,
may be ur amplifiers any of the output channel have some problem. that's why it goes off after power on, protecting ur speakers. disconnect all the speakers and inputs and then power on it if works check ur speakers and inputs. if not there is fault inside ur amplifier.
ok
Dec 22, 2010 | Sony TA-N9000ES 5-Channel Amplifier
I accidentally plugged my 110V amplifier to 220V outlet.It has no power anymore.what possible solution for this. Thank you very much. Do I need to replace the rectifier in it's circuit?
Hi and welcome to the site,
Initially, on a completely dead Sony TA-N9000ES, primary suspects to be checked would be:
  • 8A F1 fuse;
  • primary winding of T1 transformer;.
  • fusible resistors R816, R817 and R818.
Good luck and thank you for asking.
Jul 13, 2010 | Sony TA-N9000ES 5-Channel Amplifier
Hi I have got a sony TAFE 370 amplifier which does not produce any output, i have tried different input devices and also checked speaker wiring and the speaker selection is on i used it a day ago and all...
If you can't hear any sound from the headphone output, and by sound I mean a hum with the volume turned up, then the amp has either got a faulty internal power supply or the main amp has failed. Try looking inside to see if any fuse has blown. Also look around to see if you can see or smell anything has blown.
Sep 24, 2009 | Sony TA-FE370 2-Channel Amplifier
Volume knob broken
needle nose pliers to turn it down,find another knob there pretty common even if you had to use a drop of super glue.
Aug 29, 2009 | Sony TA-N9000ES 5-Channel Amplifier
No sound
When the amplifier will turn on but not produce any sound that is usually an indication of either the high voltage power supply inside the amplifier is not working, or the amplifier IC or amplifier circuit is damaged. It is not something that can be repaired unless you have experience working on electronics.
Dec 30, 2008 | Sony TA-N9000ES 5-Channel Amplifier
Sony TA-AV421 Amp
im needing help connecting my audissey aps 5+2 energy floor speakers . im confused on the 2 channels
Jul 30, 2008 | Sony TA-N9000ES 5-Channel Amplifier
Sony Stereo System
Your in luck there is a user guide online that has all you need to know.Here is the link
Sony TA-N9000ES Flash light when turn on.
an amp of this size generates alot of heat internally when in use as these use mosfet ICs and can get very hot.
your problem is most definately dry solder joints and possibly quite a few at that.
i've repaired quite a few sony surround receivers with similar problems and have all been down to dry solder joints.
hope this helps.
Jul 26, 2008 | Sony TA-N9000ES 5-Channel Amplifier
TA-N9000ES Amp - Standby light constantly blinks - no sound
The flashing light is indicating that a fault has been detected, and it is staying in "protect mode". First disconnect all cables from the processor (except the power cord) and then power up the processor. This will eliminate the possibility of a shorted cable or a problem with any connected components. f the light still flashes, there is an internal problem and the processor will require profesional service.
Oct 09, 2007 | Sony TA-E9000ES Amplifier
Sony TA-N9000ES 5-Channel Amplifier Logo
221 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
