Question about Intel Asus P5SD2-X SiS 656 SiS 965L Chipset 800 / 533 MHz FSB Dual Channel DDR2 667/533/400 Socket 775 ATX... (MB77ASP5SD2X) Motherboard
Back pannell sound which is attached with motherboard is not working properly......
  • Wes Clark Mar 24, 2011
    When did this start? Is it out of the box? Did you recently reinstall your operating system? Just describing the problem is never enough when you're trying to get help. Describing how you got to this situation is really important.
    Telling a little story about it is the easiest way. I.E. "My last motherboard died, so I decided to replace it myself. After installing the motherboard I started my computer and there was no sound coming out of the onboard sound on my motherboard"
  • Intel Master
  • 27,725 Answers
If your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Posted on Mar 24, 2011
Zoostorm netbook mouse buttons
check to see if front pannel wiring board has the jack well placed there and all wiring is ok, if all ok you could try with contact spray within the jack itself, last option is to check if wires from front pannel to motherboard are placed where they should be, respecting the proper way of placement (+,-) , if that doesnt work, try installing your sound card again and it's application, in the application itself you should have a option : Pop-up when jack input detected. hope that helped you.
Mar 02, 2014 | Intel Computers & Internet
Multimedia audio controller
First right click my computer clickproperties then click hardware then device manager and in the click sound vedio and came controller and see wether the driver is installed properly if you see question mark in the driver or the driver not installed properly reload your sound driver which came with the motherboard if the drivers are installed properly then click start settings control pannel then click sound and audio device then click volume and move the slider to high then untick the mute button if ticked then restart the computer
May 01, 2011 | ASUS P4S800-MX Motherboard
DH Audio Driver R1.85 is not ok
May 01, 2011 | Intel DG31PR Motherboard
When i clicked at the volume control an eror msg shows that there is no active mixer installed it this computer..and also no sound card detected...soo please give me the sound driver of my motherboard.
first right click my computer clickproperties then click hardware then device manager and in the click sound vedio and came controller and see wether the driver is installed properly if you see question mark in the driver or the driver not installed properly reload your sound driver which came with the motherboard if the drivers are installed properly then click start settings control pannel then click sound and audio device then click volume and move the slider to high then untick the mute button if ticked then restart the computer
Apr 01, 2011 | ASUS P4B-M (P4BM1400WOLTINY) Motherboard
Sound is not working
Mar 28, 2011 | Computers & Internet
My front panel audio and microphone doesn't work
try to check the connection on the board wether its proper if no then check the manual of the board it will help u also check the setup in the bios also there r setting in some program of the sound software check this should solve the problem thankyou
Nov 16, 2010 | ASUS P5KPL-AM SE Motherboard
I don;t have any sound on my computer
First connect your spearker to your computer -
1. check you have installed your sound driver in your computer.
2. If there is no installed drivers install drivers from *********** board CD.
3. If you attached sound card in your motherboard, install CD which you have sound driver card.
4. Another option for drivers download from Internet and install in your PC
If not Work:
go to start - control pannel - sound & game controller - check sound balance
Feb 01, 2010 | Computers & Internet
Somebody while working in my p.c has removed the sound system in the year 2006 april.
First of all u go to start- programme- accessories-system tools then click on system restore , system restore in back date when ur computer sound was working fine . After that if ur sound is not coming then go to controll pannel then add/remove programme , remove the sound driver and then restart the pc , after restarting the pc then reinstall the sound driver properly then after install the driver check
Jun 01, 2009 | Foxconn P4M800P7MA-RS2 Motherboard
Sound driver not functining properly
http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=1066
Download the latest drivers. Also make sure you have your operating system updated fully using Windows Update.
Jan 14, 2009 | Intel Desktop Board D845EPIL Motherboard
Computers & Internet Logo
35 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
