Question about Fagor 31 in. VFA-78S Electric Cooktop
Fagor Innovation 4-zone gaz top: sparks ignotor doesnt stop after cleaning
Often during cleaning, using liquid detergent but carefully so, the sparks on one or several zones wants to ignite, this can last hours, with or with out tge gaz switched on. Logically certain liquid drain causes this. How can this problem be avoided? Cleaning advice?
  • Anonymous Dec 28, 2008
    same issue as above
When I try to use my gas cooktop, it makes a loud "pop" sound and has a big electrical spark that smells like fireworks then it flips the breaker.. Any ideas??
The electrical wiring under the burners has been short
probably from liquids leaks during cooking.
That is why you had the spark. The only electrical part you
have to your coo top is the electric ignite nothing else. So you should remove
all burners' assemblies from the top so to reach the bottom part where the gas
pipes are located and the ignite part no 318 in drawing Spark module
Part Number:
AP3778816made by GE.
So first you can use a hair
dryer do try it out and be sure there is not and liquid in it and put
electrical plug again to test it. If you still have the same problem, replace
the Spark module with a new one.
Here below you will find the
parts layout of your range for all the help you might need.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5235927&diagram_id=25698825#d25698825
Dec 13, 2010 | GE 30 in.Profile JGP945 Gas Cooktop
How do I clean my new electric Jenn-air cooktop with its glass top? Do I need a special cleaner for the glass?
  • Step 1 Wipe up spills as soon as they happen with a clean dry towel. According to the Jenn-Air website, for glass top cooking surfaces, you should do this even if it is hot since it will be harder to clean up later. Be careful not to get burned.
  • Step 2 Use a cooktop cleaner once it is cool. You can also use dishwashing detergent and water or just a baking soda paste (made with water).
  • Step 3 Apply the cleaner to a sponge, cloth or paper towel. For more stubborn stains, you can use a non-abrasive or "scratchless" pad.
  • Step 4 Rub the soiled areas until clean. Rinse well, especially if you used the baking soda paste as that can leave a residue.
  • Step 5 Use a razor blade for burned on and crusty stains that will not come off using the previous methods. Jenn-Air states to hold it at a 30-degree angle to carefully remove the stain.
  • Or you can use this on the link below.
    http://www.amazon.com/Blue-Ribbon-88100-Cooktop-Cleaner/dp/B000HM5INA
    Good Luck and please rate 4 thumbs up for the free answer
    Jun 25, 2010 | Jenn-Air 30 in. CCE3401 Electric Cooktop
    All 4 of the hobs started sparking/ clicking after cleaning the cooker top. Now they won't stop sparking/ clicking.
    there is probably some water in unit that is causing the unit switches to not work. you can try to use a hair blower to thoroughly dry components.
    Feb 26, 2010 | Smeg 23 in. SE64 Gas Cooktop
    Viking 30" gas professional series cooktop sparking problem
    And before that Most likely one of the ignition switches (they are under knobs) got shorted possibly due to spilled liquid or a cleaning stuff sprayed on. In that case it should stop sparking after a switch drys. Still no go replace the spark control unit.
    Thanks
    Kindly rate the answer
    Kevin
    Jul 06, 2009 | Viking 31 in. VGSU101 Gas Cooktop
    3 of 4 knobs do not compress to turn on gas
    You must replace those controls. Cleaning or loosening them up would be temporary at best and the next time they stick it could be in the open position. Safety first...Eric
    Jun 14, 2009 | Jenn-Air 30 in. CCG2423 Gas Cooktop
    Electric starters keep firing after I sprayed cleaner
    your spark modual got shorted with the liquid you sprayed in there or spilled you can try unplugging it overnight to let it dry. at least 24 hours or you can take the cooktop of and get a hairdryer and dry out the spark modual.or if you wait 24 hours - 3 days and still not dried out you need to replace your spark modual but more than likley give it time it will fix itself.
    Apr 23, 2009 | Amana AKS3040 Gas Cooktop
    Fagor cook top connection
    Guy from Fagor said brown & blue go to black & red. White and ground together go to green & yellow. Hope he's right.
    Apr 04, 2009 | Fagor 31 in. VFA-78S Electric Cooktop
    Fagor hob touch control
    Our hob has the same problem. I would really like to know the reason for this! Try using a rubber eraser instead of your finger - this works every time with our hob. Covering Up and Down arrows with the rubber, zeros it instantly just like using both fingers. Hope this helps.
    Jan 28, 2009 | Fagor 31 in. VFA-78S Electric Cooktop
    Spark ignitor won't stop clicking
    the spacing between the ignitor and the plat is less the minimum. that will cause the ignitor to ignite prematurely. use a small screw driver or a nail filler clean out the space between the ignotor and the plat.
    Dec 08, 2008 | Jenn-Air JED8430 Electric Cooktop
    Sparking element
    i would stop using hta burner for a fewdays let it dry out and then try it, sparking it will only damage it.
    Mar 05, 2008 | Cooktops
    Fagor 31 in. VFA-78S Electric Cooktop Logo
    237 people viewed this question
    Top Fagor Cooktops Experts
    Dan Webster
    Dan Webster
    Paul Carew
    Are you a Fagor Cooktop Expert? Answer questions, earn points and help others
