Question about Electrolux Washing Machines
My washing machine model is EWF 10571> The
jsrock516
  • 5911 Answers
SOURCE: Loud clicking noise at spin cycle
It sounds like you have a motor coupling that has gone bad. Most of the Kenmore top loaders that I'm familiar with are direct drive machines. Which means, they use a motor coupling between the electric drive motor and transmission to run. If you are in the habit of doing heavy loads like comforters, blankets and jeans this can put a heavy burden on the motor coupler and wear it out faster. The coupler is designed to take the burden of the punishment in order to protect the transmission and drive motor and it is common for them to wear out. The coupler is fairly easy to replace and usually runs about $15. It is located inside the machine between the drive motor and transmission under the wash tub. You would have to remove the outside machine casing, the water pump and drive motor to get to it, though. Make sure the machine is unplugged before attempting any repairs involving removal of the drive motor. If you are not mechanically inclined, you may want to seek the aid of a repairman. I hope this helps.
Posted on Apr 29, 2007
MNTECH
  • 1543 Answers
SOURCE: Visible water level in front-load clothes washing machine?
Yes, it is normal. There is water in the machine. One of the big draws for this style machine is that they use much less water than top load machines. If you stopped the cycle and opened the door, dug down in the clothes, you would find water. The machine fills a small amount of water (below the level of the door) and tumbles. As the water is absorbed by the clothing, the water level drops, so the machine adds more to maintain the water level. This is basically how the washer figures out how big your clothes load is and how much water that load needs. (Of course most sales persons at the big box stores and Sears have no idea how this works)
If you'd like, try running a cycle with no clothes to see how much water is in the machine. (It's not a lot) Now remember this: Because there is so much less water use than a top load machine, you must cut way way way back on the amount of soap and fabric softener used. Use no more than one tablespoon of HE (High Efficiency) soap (even less if it is 2x or 3x concentrate) and one teaspoon of fabric softener per load !!!!!
This should be a Fix-Ya for your question. Thanks.
Posted on Dec 14, 2008
  • 4088 Answers
SOURCE: my washing machine drains but does not spin
Look for a motor belt that is worn out and make sure that the drum turns freely (machine off).
Posted on Aug 01, 2009
GodBlessU
  • 3513 Answers
SOURCE: 22432 won't spin or drain
CHECK THE LID SWITCH THE PART THAT PUSHES THE SWITCH DOWN MAY BE WORN ENOUGH TO CAUSE THIS PROBLEM. WITH THE LID OPEN START THE WASHER IN THE SPIN CYCLE AND PUSH THE SWITCH WITH A POPSICKEL STICK AND SEE IF THIS PROBLEM STILL HAPPENS
Posted on Aug 30, 2009
  • 3 Answers
SOURCE: GE washing macine stops during the wash cycle
This is exactly what my machine was doing, as well. I fixed it by cleaning out the filter in front of the water pump.
Searching here, I found that you can remove the lower front panel (three screws along the bottom edge is all it takes) to get to the filter. With the panel removed, you'll see a round white plastic cover (about 3-4 inches diameter) that screws out. Get a bucket under the cover to catch the water that's in it (could be 2 quarts or more) and unscrew the cover.
The cover pulls out, revealing that is actually a screw-in plastic strainer. I found tons of coins, broken pens, paper clips, etc. in mine when I did this. A lot will be deep inside the black rubber hose that connects this filter housing to the washer drum. You can rake the stuff out with a bent wire clothes hanger. Shaking the black hose will help hurry the junk along and out of your machine. Screw the cover back on after the clean out and your machine should go back to normal.
Thinking about it, front loaders will have lots of small items flushed into the pump compared to top loaders. Coins you alway found in the bottom of the drum in a top loader, they all wind up in the filter of a front loader. And once it slow the drainage to a crawl the machine will shut down multiple times when it can't drain the water out completely, and it will never step up to it's max spin speed with all that water still in the drum.
Posted on Nov 30, 2009
My electrolux front load washer had a bang and a spark on electrical display now showing E60 EWF 1087
Family error code E60 is visible to customers and (could be E61,E62,E66,E68 and E69 only visible in service mode) means problem with heating phase.
Possible failures : heating element faulty, NTC sensor faulty, PCB faulty, wiring.
Dado
Feb 21, 2015 | Electrolux Washing Machines
Kenmore elite washing machine
What is the model number?
Jun 29, 2013 | Washing Machines
Electrolux EWF 1074 - How do I turn off the annoying beeps at the end of every wash
I have touchscreen! Doesnt work. Any suggestions? Hate having to get up middle of night to turn off this )%(/₪/#&/₪(" beep!
Feb 29, 2012 | Electrolux EW1000i Front Load Washer
When you run a wash there is some water on the tile floor. I found the rubber gasket inside the door is torn.
If the tear is small, try using silicon glue to repair it--clean the surface of the boot and apply the glue. Let dry for 24 hours before using the machine. If the tear is large, the boot must be replaced. It can be done from the front without removing the cabinet, but it's tricky. These tears usually occur when trying to remove jeans and a metal button catches the rubber.
Feb 13, 2010 | GE Energy Star WCVH6260F Front Load Washer
Torn rubber boot
for model # wsxh208a the part is
WH45X10062 - KIT-BELLOWS & MTG SPRING
should be able to change through bottom access panel and door hole.
make sure to pull clothes gently straight out of the unit and not at an angle across the rubber boot, it tears really easy..
hope this helps,
best of luck,
ttfn
Oct 26, 2009 | GE WSXH208A Front Load Washer
Water is coming out of the front of the washer
The rubber boot that surrounds the door inside likely has a tear in the rubber. If the tear is small, you might be able to fix it with an application of weather strip cement. A large tear means replace the boot.
Aug 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whats is the total weight of electrolux ewf 1495?
thas a question that the manufactuer should be able to answer for you, ifnot the dealer that your goingto purchase tehunit through should be able to get you those specs.
Mar 12, 2009 | Electrolux AWF1235 Front Load Washer
Rubber gasket around opening
Iserial #15616047cc i want to know how to repair it my self
have a ANANA washer machine model alw 480daw
Jan 27, 2008 | Bosch WFMC 3200 Front Load Washer
Washing Machines Logo
Top Electrolux Washing Machines Experts
Tim Whalen
Gerry Harvey
Gerry Harvey
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
