Question about Maxtor Computers & Internet
I need to know the specifications concerning the power transformer, voltage etc. I've misplaced the power cord while moving residence. But I have two adjustable radio shack transformers. Just need voltage and amperes.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,226 Answers
There are four wires yellow is 12v black then black then red 5v black are ground
Posted on Mar 24, 2011
I have bose wave with input voltage 110 volts but i want to change it 220 volts where i can buy a transformer
Check the back or the bottom of the Wave unit for the input voltage rating. If it has a universal power supply, it will show something like "Input voltage 97-243 VAC 50-60 Hz," i. e., the input voltage rating spans the full range from 110 VAC US to 240VAC Europe. In that case, all you have to do is get a power cord suitable for the power in your area.
I checked the specification in the on-line owner's manual, but it wasn't helpful; it said the input power rating is "220V-240V
50/60Hz 60W max" We know it works on 120 V, so the 220V in manual may be a typographical error. Go with the information on the unit case. If it says "120 V 60Hz" and nothing about 240 V, then you would need a transformer rated for at least 70 Volt-Amps (60 Watts plus a reserve factor so you don't have to worry about overloading it).
I tried checking my favorite site for electronic products such as travel transformers and adapters (MCM Electronics), but as of this time they were having server problems. Note: they may have the 240 V version of the power cord, or you can check whether Bose sells it separately.
https://www.mcmelectronics.com/
Aug 05, 2017 | Bose Audio Players & Recorders
Replacement TRansformer and Power Cord
If you need a replacement Power and cord device, check on eBay. do a search for your model and/or serial number in the search box and then be specific on the voltage and amps you need for power adapter as it is sometimes referred to!
Sep 27, 2014 | HP Pavilion AllinOne MS214 185" Desktop PC...
Malibu transformer
Unplug transformer, change bulbs with low voltage bulbs from local hardware or home center. There are two screws on back of each bulb.
Copy following link for tips to get power pack to last longer, replacement trippers, warranty, troubleshoot. etc
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Reason for unplugging transformer: because product manual lists that as best way to change bulbs. The low voltage transformer output is 12Volts and does not carry enough power to cause you harm if you touch bare wire.
Add a comment and attach photo as needed.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
May 25, 2013 | Malibu ML600TW - Low Voltage Power Pack -...
Malibu transformer on but lights dont work
Voltage drop because transformer is not putting out enough power as when it was new.
Or Short along the wire somewhere.
Connect new wire and 1 bulb, but do not connect to existing wire.
Apr 14, 2013 | Hardware & Accessories
Printer will not power on
Check that the corded power supply is plugged into a live receptacle. Verify by using a lamp with a light bulb to see that it lights before plugging power cord into the wall.
Check that the connection at the printer is ok.
Push the power button, and if nothing happens, you might have a bad transformer either on the cord or in the printer itself, depending on the design.
One can double check by getting a spare power supply transformer or cord and trying it.
Or else, a multimeter should show the voltage printed on the power supply or printer. Check that the voltage is within specifications when plugged into the wall whether it is AC or DC voltage.
Jul 04, 2010 | HP Office Equipment & Supplies
There is no power to my router. how do i know if i need a new power cord or if it is defective unit. 2wire 1800HG older model
You can measure the power cord voltage with a voltmeter. The specifications, and voltage output are on the transformer, or modem body. If you don't have a voltmeter, you can take the power supply into Best Buy, Radio Shack, or any computer shop, and they'll measure it for you. If the voltage is ok on the power supply, chances are you have a bad modem, in which case you'd be better off getting a new one. Hope this helps.
May 14, 2010 | 2wire HomePortal 1800HG Router...
I have misplaced the power cord for my x1200 model printer
You may check on ebay for a power pack, otherwise you'll have to buy one from Lexmark or someone who sells Lexmark supplies.
Jul 27, 2009 | Lexmark PrinTrio X75 Printer
WX cc Sangean radio cuts out
The ATS-818 needs a transformer. The transformer converts AC power to the DC used by the radio, so no. You need the transformer.
Jan 20, 2008 | Sangean ATS 818 AM/FM/SW Radio
CFD-S300 Sony Boombox lost power cord
Purchase online at Sony.com, parts and accessories.
Jan 03, 2008 | Sony CFD-S300 Radio/Cassette/CD Boombox
Computers & Internet Logo
47 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
Phillip Whisenant
Phillip Whisenant
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
