Question about Raymarine RL70CRC GPS Receiver
Which wires to connect when connecting a marine antenna to a raycraft gps
I want to get my GPS up and going but the only thing stopping me is these 5 wires running out of the antenna and the 5 wires i need to connect them to. I'm not sure which wires to connect them to because they are not matching colors. Can anyone help me?
Hi. I have G series Raymarine and I listen the noise when swtich on I am not shure , may be from the ventilation (the fan).
I not find troubleshooting to G raymarine, I hope find the soulatoin thanks.
regard
kareem
Posted on Aug 06, 2008
Connected marine radio to humminbird gps antenna but the radio will not show gps
Hi Ken
A little wiring 101 is in order here I think.
NMEA out (+ and -) from your GPS goes to NMEA in (+ and -) of your VHF.
Hope this helps you out
Mar 10, 2016 | Humminbird Boating
INTERNAL WIRE CONNECTION GARMIN GPS 2010
Electronics technician can fix your problem. They knew where the positive and negative pin by using a tester.
Feb 01, 2014 | Garmin GPS
Bought a 987c si hd. i have a 917c on the front. I bought a inter link for them. when it is hooked up like the diagraphm says, that is 1) plug the puck into the gps port on the interlink. 2) run power...
If you have put power to the gps antenna then there is going to be a problem with your gps antenna. The Humminbird gps antenna gets it power from the unit. If you have done this you will need to contact our customer service group to get it resolved. There number is 800-633-1468.
Joby @ Humminbird
Jan 29, 2011 | Humminbird 4068201 AS InterLink Network...
Need 5 pin wiring code for Navman Tracker 900 marine device
Dan,
Did you receive the color wiring following order? I ask this because I need the colorcoding as well. If you have please mail me chrisjord4@zeelandnet.nl
Kind regards Chris Jordan Holland
Apr 23, 2010 | GPS
We lose fix info. on the c120and the Auto pilot has no display. The problem is intermittent
This sounds like a problem with the receiver. If you can not get GPS fix (sometimes) you will have to start looking at the GPS antenna and cable. If the unit is new check out the location of the antenna. As with anything that works with satellites it need a clear view of the sky to fix onto the "birds". A GPS connects to numerous "birds" at a time, so ensure that the antenna has a wide angle view of the sky. If it is old you will have to start looking for connection problems. This is usually the case when the fault is intermittent. Check for possible water damage and loose or less than adequate connections. Also ensure the cable is in a good condition.
Apr 03, 2010 | Raymarine C120 System Pack C120 Raystar...
Can i replace my 330c head unit with the 525c using the same wires antennae etc lowrance
Hope its not to late, before you replace (buy a new one) call Lowrance. I have a 525 and working through some problems and they advised me that they would replace my unit for $200 no questions asked. To answer your question not 100% positive but I did see a recent question where Lowrance lost his unit and sent him the 525 as a replacement and the connections were different. I believe my 525 has a 5 pin system with one notch. Does yours have a external gps module? The 525 does!
Mar 01, 2010 | Lowrance Lms 525c Df 5" Df Sonar...
Need to connect NMEA0183 to radio
Thank you for your quick respond.
I downloaded the owners manual and it had all the informaion I needed.
May 24, 2009 | Magellan GPS 320 GPS Receiver
GPS Module not responding
i just got it back from Lowrance and they replaced antenna and it works, but for how long is anybody's guess. The technician at Lowrance told me the antenna should be at least 3 feet from base unit and he thinks that is problem, because mine is only 2 feet. Why doesn't it say that in manual, if true and why doesn't MarineMax install it properly. MarineMax just gave up trying to help me, even though it was under their warranty. They just care about the sale and their installation was shoddy at best with wires hangiing all over the place. I decided to take care of it myself, so we will see.
Nov 11, 2007 | Lowrance LMS-332C GPS Receiver
GPS Elevation/Azimuth Always Read Zeros
Josh, The grey cable that you see (sometimes it comes in a black woven cable as well) as soon as you open up your unit has to be connected to the main board in the corner. Additionally on the I/O card or GPS board (the board that's attached to the rear cover) has to be connected as well. If you see any loose cables and you find a place it fits, plug it in. So, the answer to your question is yes, that could be the problem. -Daniel
Dec 24, 2006 | Magellan RoadMate 700 GPS Receiver
Raymarine RL70CRC GPS Receiver Logo
439 people viewed this question
Top Raymarine GPS Experts
Steve
Steve
Jon Piercy
Are you a Raymarine GPS Expert? Answer questions, earn points and help others
