Question about Kenmore Kitchen Ranges
I have a kenmore warm and ready drawer glass top oven (model # 790.96413400) that's about 6 years old. one of the burner (small one in the rear) no longer works and another one (in front that has single/dual heat feature) now only heats at high dual. what would be the most likely problem and how much would it be for parts only (doing the repair myself) or including the labor? i'm trying to decide whether it would be better to replace the whole thing based on the cost of the repair. thanks.
    President:
  • 1,654 Answers
The burner replacement is very easy and cheap, you can get replacement at the big harware stores or sears, they simply pull out and new ones slide in. There may be some retaining screws involved. As far as the switch goes for the front burner, it needs replaced as well. The burner controls are like dimmer switches for lights, they change the currunt going to the burner, when a burner only works on high that means the switch has gone bad. These are also easy to replace, usually a nut that holds it in oplace behing the panel and a couple of wires. Depending on where you get the parts, the should run between $15.00 and 25.00 for the burner, and $20.00 -$50.00 on the switch. I am not seeing this model number for some reason so I am ball parking these prices. Add another $60.00 to $100.00 for labor if you call a service person. But these are not hard to do, google the phrase, how to replace a burner on an electric range, there are instructions there and you will see how easy it is to do.
Posted on Mar 24, 2011
Electric stove top. Only the warmer drawer knob works. Why don't the others?
THE HEATING ELEMENTS COULD NOT BE MAKING A GOOD CONNECTION,TRY PUSHING THEM IN.
Jul 05, 2015 | Kenmore Kitchen Ranges
Kenmore warm ready drawer oven
I don't know about the burner... but the oven needs a safety valve (or the igniter) The safety valve is about $140. some people would rather replace the whole range than pay for the part and the service call.
Oct 20, 2013 | Ovens
OUR HOME WE BOUGHT CAME WITH A RANGE, BUT NO MANUAL, WHERE CAN I GET A COPY OF THE MANUAL FOR THIS RANGE?
You will need to find the model number to get a manual. http://www.geappliances.com/service_and_support/literature/ provides a search box for looking up the manuals. For GE ranges, the model number could be in several places: on the frame behind the warming or storage drawer or kickplate, on the left leg behind the warming or storage drawer or kickplate, on the frame of the oven behind the door, under the left front surface burner, or under the lift-up cook-top at the center or on the right hand side.
If you clean the oven with non-abrasive products and avoid the spray on oven cleaners, you are unlikely to damage the surfaces/range even without the manual for your range. (Use glass cleaners for glass cook-top.) Warm water mixed with a mild detergent is useful for most spills. Avoid cleaning the seal around the oven door; damaging the seal may cause major problems.
I hope this helps.
Jan 27, 2012 | GE Kitchen Ranges
I have a Kenmore Elite Kitchen stove top (one with the burners underneath a glass plate). Model number: 911 99004990. I believe it was purchased close to or around March of 2000. The problem I have with...
I have the same problem with ours! Our 2 small burners don't work at all and the 2 larger ones only work bright red hot. I called Sears and they said there is no recall on my particular model, but there are tons of recalls on other models. The problem is with the venting from the oven doing damage to the wiring (shorting them out maybe?). We're trying to find someone who knows anything about this and if we can get it fixed as our stove is only 3 years old.
Nov 15, 2010 | Kenmore Kitchen Ranges
I have a Kenmore flat top electric range with the warming drawer that is only a few years old. We got this from a friend (so no manual) and our problem is whenever you turn the oven on it seems to...
control board is showing H.E across the front its a Kenmore Model# C970-440994 Why Would this happen its only two years old/What can we do to get this off so we can use the flat top???
Aug 10, 2010 | Kenmore Kitchen Ranges
Dual element burner on glasstop range...inner element stays on
It is the burner control (behind the knob). The triac in the control has failed. $50 item, 10 minute change. Just make note which wire goes to which terminal.
I doubt that it is the control board, as the board has little to do with the stove top, but rather controls the display and the oven temperature/feedback monitoring.
Hope this helps.
Jan 14, 2009 | Frigidaire FEF366DC Electric Kitchen Range
Baking Element Caught fire
this a common complaint when the element burns out it is scary to see but all you need to do is replace element
Apr 21, 2008 | GE Profile 30" Free-Standing 5 Burner Self...
Kenmore Stove Glass top
I have a Kenmore glass stove, not sure what the model number is I don't have it with me right now. Yesterday, the timer started to beep and F1 started to flash in the display. The stove top is working, but the oven does not. The only way I can get the timer to stop beeping is to unplug the stove.
Any suggestions as to what is going on with this stove. It's only 4 years old.
Thanks
Oct 22, 2007 | Kenmore 46123 Stainless Steel Electric...
Burner keeps cycling on to high when OFF
Safety will require expert repair or replacing the oven.
Oct 21, 2007 | GE Profile JTP18 Electric Single Oven
Kitchen Ranges Logo
292 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
