Question about Casio FX-9860G Graphic Calculator
I have the casio fx 9860G. how do i take a screen shot form the calculator and then get it on a word document?
  • 113 Answers
The easiest way to do this is to take a photograph with a digital camera or mobile phone and transfer using blue-tooth or data cable to a PC.
Posted on Mar 27, 2011
What is an Ma error casio fx-9860gii
Ma error means Mathematical error.
Check input values and make corrections to ensure that values are within allowed limits.
Please Check the manual for the calculator. It is available on the Casio website. Here is the link.
fx 9860G fx 9860G SD Calculators Manuals CASIO
Aug 30, 2014 | Office Equipment & Supplies
Casio FX - 9860G SD have complex equations??
Your question (?) is not clear so I will not try to guess what you really mean.
Be it as it may, the Casio FX-9860G SD can solve a polynomial equation of degree 2 or 3 with REAL coefficients. If the complex MODE is set to REAL it will find the real roots. If the complex mode is set to a+ib, it will find the real and complex roots.
Apparently it will take coefficients that are real, and will give a Ma Error if any coefficient is complex.
Mar 16, 2012 | Casio FX-9860G Graphic Calculator
Can you calculate indefinite integrals on the casio fx-9860G
Unfortunately, the Casio FX-9860 G does not have a Computer Algebra System or CAS. For this reason it can only calculate definte integral over a given interval. The lower and upper limits must be supplied. The result will be a number.
Casio calculators that have a CAS are the Casio ClassPad CP330/ 300Plus/ 330, or the Algebra FX 2.0.
Feb 08, 2012 | Casio FX-9860G Graphic Calculator
Prime factorization using Casio FX-9860G Graphic Calculator
There is a program called Prime Factor Analysis on this site. It is written for the FX-9750GPlus calculator but I suspect you should be able to use it on the FX-9860G. To access the site you must have an account. You can register and it is free.
Jul 30, 2011 | Casio FX-9860G Graphic Calculator
How to do the log to the base e question with calculater casio fx-9860G
The log to the base e is the so-called natural log, denoted ln. Look at the screen capture below. The relevant key is at the bottom of the picture. Look also at the screen for syntax of the command.
Jun 07, 2011 | Casio FX-9860G Graphic Calculator
My screen is broken can i get it fixed?
Hi Jimbo_Hathaw,
Regarding about your broken Casio FX-9860G Graphics Calculator, i would recommend you to find a Casio service center in your area, if so you need to go there with the broken Casio along with your receipt. depending on the amount of damage which has been occurred to the screen charges may be applied to getting it replaced.
Casio Service Center :
www.casio.com
( click on your area and search for the service center's number in your specific area )
if you are how ever unable to find the service center in your area then the best option is to find an electronic store in your area. bring your calculator there and ask them whether they can fix the issue with the broken screen.
I hope i've given you insight about fixing your calculator, if there is any questions you have please contact me.
good luck!
Mar 15, 2011 | Casio FX-9860G Graphic Calculator
How can you change the mode on a casio fx-9860g calculator to deg. mode?
Press SHIFT MENU to bring up the setup screen. Use the arrow keys to move to the "Angle" line and press the function key for the desired angle mode.
Mar 04, 2011 | Casio FX-9860G Slim Graphic Calculator
I have the Casio FX-9860G Slim, how do i do logs with something other then base 10?
Use the logab function in the catalog. For example, to calculate log base 2 of 32:
OPTN F4 F6 F4 2 , 3 2 ) EXE
Dec 15, 2010 | Casio FX-9860G Graphic Calculator
My casio fx-9860G au, wont copy equations from statistic mode to graphic mode. can you please tell me how i can fix this?
Just in case you did not find the Copy function I am including this screen capture from the FX-9860G SD.
The function is available at the bottom of the screen that displays the regression curve. Press Copy and select a function Y1= or Y2=. The next time you press the Draw tab the scatter plot and the regression curve will be displayed on the same screen.
Aug 15, 2010 | Casio FX-9860G Graphic Calculator
Installed a wrong OS update version
get battery out-and install it again(after you return the battery)
Jun 27, 2008 | Casio FX-9860G Graphic Calculator
Casio FX-9860G Graphic Calculator Logo
107 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
