Question about Dishwashers
How do i remove the kick plate on a nemo dishwasher
  • 4 Answers
There will likely be two screws either on the top of the panel, or on its bottom. Remove these two screws, and then remove the kickplate.
Posted on Mar 24, 2011
  • joe schuffelen Jan 08, 2013
    Have taken kickplate off, can see washmotor, checked rotor, can turn it via top
Help. I have a model # 58717245 portable Kenmore dishwasher. how do I remove kick plate to find out where leak is coming from?
Just remove the 2 screws located on both sides of the toe-kick plate. If it uses the new plastic fasteners, you just turn them 1/4 turn CCW (so the slot is up and down), and then pry them out.
Mar 17, 2015 | Kenmore Dishwashers
Remove the kick plate or panel from dishwasher 1595
I have a different Asko model so this may not apply. The screws are Torx and you need the proper fitting. Everything is symmetric with the same screws and locations on the left and right. Mine has two screws for a front kick panel, two screws for the front trim piece that matches the door, and then four screws, to on the underside of the cabinet and two on the front to remove the final piece. There are also two adjusters that slide out after pressing a tab on the outside of the slider.
Sep 27, 2014 | Asko Dishwashers
How to replace the kick of a dishwasher
there should be a screw on either side of the kick plated. unscrew and remove the two pieces that make up the kick plate
Apr 06, 2013 | Frigidaire FDB700BFC Built-in Dishwasher
Some water is leaking under the dishwasher and on the kitchen floor during the end of the wash cycle.
Does it leak during pump-out only?
If so , must be drain hose .To see everything,remove kick plate to isolate leak. Check hose connections. Fill and drain and observe.Or run a whole cycle with kick plate off to find leak.
Good luck
Aug 15, 2011 | Kenmore 24 in. 15689 Built-in Dishwasher
Leaking water underneath dishwasher
most dishwasher has a kick plate at bottom ,,remove kick plate ..be careful turn unit on let water fill system..and just look ..just look and see where the water is coming from...warning,,most parts of a dishwasher are not grounded,,,please be careful
Oct 10, 2009 | GE Dishwashers
Leaks water
There are 4 screws holding that kick plate on. Normally, they're 1/4" drive. Lay on the floor with a flashlight and look at all 4 corners (between the kick plate and the door and near the floor).
This is how to get the panel off, but without a make and model I can't help any further. If you could provide those, we can figure out how to repair the leak. Just let me know, OK?
SG
Apr 05, 2009 | Westinghouse Dishwashers
Belling idw603 error code 4 any idear please
Try removing the kick plate front bottom of your dw and see if there is a code chart paper stuck on the back of kick plate.. hopefully there is one.. good luck...
Jan 22, 2009 | Belling 24 in. IDW603 Built-in Dishwasher
Bosch dishwasher problem
remove the kick plate below the door. youll see a white tray behind the kick plate. theres water in the tray thats activating a overflow switch. with a towel or 2 remove as much water from tray as possible. this will solve problem
Nov 16, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher does not start.
remove kick plate from below the door. youll see a white tray behind the kick plate there is water in the tray activating a over flow switch. using a towel remove the water. this will solve the problem
Nov 16, 2007 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Dishwashers Logo
131 people viewed this question
Top Dishwashers Experts
