Tuner is messed up
How about replacing the board, will that change it over
  • 8,617 Answers
No there is no way to convert analog to digital except with the converter box
Posted on Aug 03, 2008
No audio or video flashing 2 power 1 opc after relay latch?
Yes,this problem are related to the main Tuner signal board,must change the main Tuner signal board,to solved this problem.Put back your old power supply board too might be still good,but some time the power supply board must have to be replace too,becaused it got corrupted by the data from the main CPU from the main Tuner signal board.
Feb 20, 2013 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
CABLE CONNECTION TO LC320EMX TUNER BOARD DOES NOT WORK AND IS SHORTED HOW DO i REPLACE THAT PART ONLY?
Most of these the tuner lays flat on that board and is nearly impossible to get out without destroying the board.
A simple suggestion is why not if you have a cable box with audio/video outputs on it----connect from there to one of the inputs on the back of the set---select that input and bingo you have bypassed the tuner and are changing channels with the box
If you do not have a box but have cable TV or sat the cost for the box should be nominal even over time compared to replacing the board if you can even find that board---Emerson is a name someone bought to use like Westinghouse and both are known for poor availability of parts.
Have you considered bypassing the TV tuner?
Mar 21, 2012 | Emerson LC320EM9 32 in. LCD HDTV
Power light flashing green. No other light or sound. Per directions I found here, I bought a new power supply board. No change at all. Any other ideas?
Ur tv still having the same result a flashing LED power light indication,after u change the tv power supply board.Mean only one thing the main logic Tuner signal board it is also dead too.The Tuner signal board that the board where the tv incomming broadcasting signal wire plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish main logic Tuner signal board for the replacement.Tries out the old power supply board with the new refurbish main logic Tuner signal board too 50/50 the old power supply could be still functioning.If ur old power supply board still good and functioning,than return ur new bought refurbish power supply to the vendor u bought it from to get some money back.
Sep 14, 2011 | Televison & Video
The image on the screen looks like everything is in slow motion, the the color is messed up. I have already tried adjusting contrast, brightness, etc. Is this a fixable problem, or should I just buy a...
I know the colors are all messed up.But the tv LCD screen panel light it is bright enough to see the screen picture,and the tv LCD screen panel are clear,no purples,reds marks or bruses to the tv LCD screen panel itself?Yes,to all of these.The tv can be fixed.The tv Tuner signal board,that the board where the incomming broadcasting signal wire plug into it.The tv Tuner signal board it is dying and the problems to causes this.U have some basic mechanicals skills like take things aparts and putting it back together again?Yes,tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv Tuner signal board for the replacement.Will fixed this tv and get tv this to be working normal again.
Aug 20, 2011 | Samsung LN-T3253H 32 in. LCD Television
Hi Recently i turned on my TV and the picture was crystal clear as always, but then i turned it off for 20mins turned it back on and now the whole screen is messed. it shows a double of everything and...
Tries tv unplug,replug it back like about an hour later.By letting the tv resetting itself back to the factory setting,see if this solved ur problems.Still have the same result.Tv have Tuner signal board have problems.The tv Tuner signal board is causes and the problems,it dead.That the board where the inconming broadcasting signal cable plug into.Tries webssites like Shopjimmy.com,Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
Jan 14, 2011 | Televison & Video
I have an LN37A330JID and there is no video, just audio. A blue square centre screen says "weak or no signal". I tried new video cables but no change. It was going through a stereo receiver...
This probems could be the cable or satalitle receiver boxes itself.Might be the tv Tuner signal board itself is the causes,because it have some kind of shorts inside the tv Tuner signal board circuitries itself.Tries to hook up with a another tv with that incomming broadcasting signal cable.If u have no trouble,than it is the tv Tuner signal board.Tries websites like Shopjimmy.com.Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
Dec 03, 2010 | Samsung LN37A330J LCD TV
WHY IS MY LCD TV CHANGING COLORS?
Check ur input tv signal?like it tight,if u use a HDMI cable.Replaced this HDMI cable.Not work after this.Than ur Main Tuner board is dead.Must replaced this board.Tries Websites Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
Apr 12, 2010 | AOC L22W861 22 in. LCD HDTV
Tv is on, screen is black. Sound is working. Channels won't change. Tv will not turn off.
tuner/decorder is gone out you would need to purchase a new decorder board for this. Try hooking up something on the scart connections and diagnost the tuner but if it does not change channels and its not turning off you got a problem with the decoder/tuner board.
this would cost around $250 for the replacment.
Jul 19, 2009 | Vizio SV420XV 42 in. LCD TV
Coaxial outlet broke off
I assume that you pulled the F connector out of the back of the TV. In most Sharps, the F connector is attached directly to the tuner, which is the rectangular silver metal box soldered to the main PC board. Did you buy a replacement F connector or the entire tuner? Either way, the tuner must be unsoldered from the main board and the new F connector is soldered into the old tuner or the new tuner is soldered in its place. If you do not have experience soldering PC boards then let a qualified tech handle it for you.
Jul 02, 2007 | Sharp 25R-S100 25" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
