I just bought a NEC 59V80 television off a friend. While transporting the bottom of the screen got pushed into the plastic case of the TV. The tope part of the screen is still attached in place where it should be. When I turn the TV on now only a small dot of light will appear on the middle of the screen. Is this fixable?
    Problem Solver:
  • 5 Answers
Yes
Posted on Sep 20, 2011
NEC CODE
Universal remote codes for NEC TV are:
003 004 005 009 010 085 089 095
0181 0004 0005 0009 0003 0010 0095 0141
Mar 08, 2012 | Televison & Video
NEC PlasmaSync 50MP2 50 in. Television But after looking at the manual I see that I am missing menu options (Option1-4 and Advanced OSM) How do I enable these. This is a hand me down and I've had to get a...
hi mate, did you sort this problem out, i have bought same tv but when u switch it on the rgb2 screen comes up and you cant change it by buttons at the bottom, i dont have a remote either.
what universal remote shall i get and how do i enable the buttons at the bottom
thanks.
fourteen0407@yahoo.co.uk
Jul 05, 2010 | NEC PlasmaSync 50MP2 50 in. Television
Black box on screen
I had the same thing, but on a monitor. It means some pixels on your TV are heavily damaged, meaning your tv fell, or something got thrown at it or just hit it hard, or just because the box you bought it in wasn't completely sealed which damaged the device in transport.
Those pixels cannot be recovered, meaning you would have to use your warranty (if you still have it, or if it is still valid) to send this back to the company (or bringing it to the store you bought it in) to get a new one.
May 04, 2010 | JVC AV-36D303 36" TV
Hitachi UltraScan HD... picture is way off and has red lines
Its a convergence problem. You may want to check the site www.tvrepairkits.com. Every thing they said every description was right on. The best money I ever spent and the confidence you get from doing it yourself, Its a great feeling of achievement not to forget the live messenger support is instantaneous, friendly and informative if you need to fix your tv go to tvrepairkits.com I fixed a philips 60 inch tv in 45 minutes, The convergecne chips were bad thanks a million. You guys saved me 250.00 bucks. I'll be recommending you to everyone I know!
Aug 18, 2009 | Hitachi 43GX01B 43" Rear Projection...
Remove the back on NEC LCD 2010X
Remove the 2 screws from the bottom of the screen at the back of the monitor. Half way between where you removed those screws use a flat tip screwdriver or similar to push the back plastic shell in & up to release the clip holding the 2 parts together. Similar clips also hold the top sections together. Good luck
Mar 19, 2009 | NEC MultiSync LCD2010 20.1" LCD Monitor
Thin red line in middle of screen on nec 42 inch plasma monitor
I had the same problem -red, vertical bars along the right side of my Samsung 42" Plasma- and this is what fixed it: Removed unterminated cable.
I had hooked up an HD video camera to the set about two weeks ago. While I disconnected the camera I left the other end of the connector cable plugged into the T.V.. As I've since learned from friends who work in television, this is what's called an "unterminated cable" -meaning one end is unconnected. It can lead to problems with electrical interference and appears to have been the problem in this case; When I disconnected this cable from the T.V. the red bars went away.
So, check your cables. Make sure everything is properly connected and get rid of anything that might be picking up interference.
Dec 27, 2008 | NEC PlasmaSync 42PD3 42" Monitor
NEC television code
These are the device codes that can be used for the NEC TV
0036, 0038, 0057, 0063, 0197, 0244, 0347, 0401
To let the remote automatically pick up the device code follow the follwing procedure
Step Procedure Result
1 Turn on the TV manually or use the original remote control. Tune in to channel 1.
2 Look up the brand of your TV in the code list One or more four-figure codes are shown for each brand. Note the first code.
3 Keep the TV key pressed for 5 seconds Indicator blinks twice and then remains lit.
4 Enter the code noted in step 2, using the digil keys. The TV key will now blink twice. If the key blinks once for an extended period, the code has not been entered properly or the wrong code has been entered. Start again from step 2.
5 Point the remote at the TV and check that it responds as it should. If the TV responds to all of the key commands, the remote is ready for use. Do not forget to note your code.
If the device does not respond at all, or not to all of the key commands, start again from step 2 and try the next code from the list.
More Info can be found at the following website http://www.urc.philips.com/
Thanks
Proton
Do rate the solution if it fixed your problem.
Aug 04, 2008 | Televison & Video
Black Square in bottom half middle of screen
It sounds like your panel is going out and time for a new TV
Nov 30, 2017 | NEC PlasmaSync 50MP1 50 in. Television
VS 50605 screen replaced
first of all wally heres what to look for. remove speaker grill not sure of your model. speaker grill should pop off. then you will see screws holding the large plastic screen assembly. noww if you look there might be a group of wires going up to screen,they will be atatched to small plugs unplug them, remove small screws on bottom of screen assembly, entire plastic screen assembly will first slide up then pull away put assembly flat on floor (don't scratch screen put on carpit or sort surface ) screen side down. all around plastic screen you will see brackets with screws holding them on remove top,bottom,side bracket carefully put screen back in making sure the front side of screen is down replace brackets if plastic is not damaged should screen in place.reverse order of removal. remember alittle up then screen will slide down in groves doc
Aug 13, 2006 | Mitsubishi VS-50605 50" Rear Projection...
Problem with plasma tv
Something in the path to drive the other half of the screen has failed or is broken. Need some basic troubleshooting information in order to be any more specific, but I've seen this problem before with NEC plasmas. If still under warranty better use it Good luck
Mar 20, 2006 | NEC PlasmaSync 61MP1 61 in. Television
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
