Question about Hoover Dryers
D6034 hoover dryer - everything works but is not getting hot
2 Suggested Answers
SOURCE: hoover tumble dryer (model D6034) cuts out after
may possibly be the motor protection thermistor, open back and see if the motor is caked with lint, if so blow it all clear with compressed air,
as usual make sure you unplug before taking panel off.
Posted on Nov 24, 2011
Hoover dryer lights up element heats but machine wont run keeps saying clean filter ?
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot or not heat at all. . If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
GOD IS still GOOD !!!! SO MY ADIVE IS FREE
Dryer Overheats and or Dryer Gets too Hot
Nov 22, 2016 | Hoover Dryers
My Hoover vhv680c tumble dryer is working but does not get hot I have changed the element but still no good
There are other possibilities. Dryers have one or more temperature sensors that will open circuit the heater element if they get too hot. If the sensor goes bad you get no heat. These are usually located near the end of the heater element. Find the wiring diagram and you will see them. With the dryer unplugged you should be able to measure almost no resistance across their terminals. Another possibillity is in the timer. The contacts inside of it could be bad. This is likely if you get heat on some cycles and not others.
Dec 07, 2014 | Hoover Dryers
Hoover Nextra 7148 not drying
id check for fluff inside the machine casing.............blocking the air flow...........
cheers
Aug 30, 2017 | Hoover Washing Machines
I have a Hoover tumble drier model HDC6 type TCMo1 and it is NOT getting hot HELP
Try hitting the reset button on the back side of the dryer.
Yank out your condenser and give it a good clean.
A nice video:
Dec 02, 2010 | Hoover HDC6 Electric Dryer
Hoover tumble dryer (model D6034) cuts out after about 15 - 20 mins. will not restart for about 30 mins. does not seem particularly hot
Jul 05, 2010 | Hoover Dryers
Not getting hot
Sounds like the heating element has broke. If it spins and doesnt produce heat its best to call someone out, or buy a new one. If nothing works, check fuses and connections
Apr 13, 2009 | Dryers
Tumble dryer appears to be working ok but there is no hot air in drum.
Mame sure that the power to the dryer is good .. If you are only getting 110V .. the heating element wont work .. You may need an electrician to check this
Mar 22, 2009 | Hoover Dryers
Hoover Ultracare 1600 - Dryer not working
Check the duct work see if it is clogged up with lint.  Everything you read tells you to clean it out, but how many of us do it?  I just had the same problem with my duet dryer and when I went under the house to check, the duct was clogged up with lint and works like a charm now.
Jan 01, 2008 | Hoover Nextra HNWF 3135 Front Load...
Dryers Logo
56 people viewed this question
Top Hoover Dryers Experts
Tim Whalen
John Tripp
John Tripp
Are you a Hoover Dryer Expert? Answer questions, earn points and help others
