Question about Milwaukee Tool Weller Pyropen Jr Cordless Butane Soldering Iron WST2
Hi i have an old weller soldering iron and it wont light up, do i have to have the 2 slide controls in a certain position
    Problem Solver:
  • 5 Answers
A soldering iron is composed of a heated metal tip and an insulated handle. Heating is often achieved electrically, by passing an electric current (supplied through an electrical cord or battery cables) through the resistive material of a heating element. Another heating method includes combustion of a suitable gas, which can either be delivered through a tank mounted on the iron (flameless), or through an external flame.
Posted on Sep 20, 2011
Solder tip is worn out need to replace, how do I remove the old one weller model W-TCP
The barrel to the soldering iron has a nut on it and the nut unscrews and the whole barrel comes off. The tip then comes out of the barrel.
Jan 13, 2013 | Cooper Industries Weller Field Soldering...
Wont heat enough to solder
Hello, does your solder iron --Weller- humming? Also, is the solder tips the right tips for you Weller woldering gun? Are the tips tightened on the end of the solder gun prongs?
Well, if it is humming there is internal short in the windings inside of the gun. Don't mess with. Recyle it by taking the copper, brass, aluminum, and other metal out. Now, if it is not humming.
Make sure you have right tips, make sure that the tip is tightened in the soldering gun prongs.
The working principal of these soldering guns is that they work on low voltage and very high current. The current is regulated to keep the tip from burning into. Just enough current to heat the tipe to a certain temperature.. It can shock you but there not enough voltage with current but it will hurt. and could burn you. Be careful and lots of luck...GB...stewbison
Aug 04, 2011 | Weller Standard Tip: 7200
I have recently bought a Weller 201 soldering iron, but in a very short space of time out of 2 projects it has made the glass crack in 2 out 3 projects. Could it be getting too hot.
You need to adopt an on-off-on---- action to control maximum temperature. Try to keep the tip so that the solder flows properly, but the tip doesn't try to burn up. Hope this helps!
Sep 14, 2010 | RTO Weller D550 Soldering Gun
Cordless Battery-Powered Soldering Iron wont turn on anymore
You can replace the battery with other new batteries, that way, you can tell whether it is the rechargeable batteries or the iron that are faulty.
Mar 09, 2010 | Weller BP860MP Dual Heat Battery Powered...
Repair wiring on weller soldering iron model ec1002
If the coil wire is snaped then you will need to replace all the coil. usually the power from the outlet goes stright to the coil and connects to both ends of it's windings
Mar 27, 2009 | Cooper Industries Weller Field Soldering...
Replacing Tip Weller SP40L
It just corrosion. Take a pair of slip-joint or grip pliers and twist the tip back and forth until it release.
If necessary use PB Blaster® or WD-40® for the corrosion.
MT10 1/4"/10mm diameter replaceable nickel-plated copper tip
Mar 24, 2009 | Weller Marksman Iron 40 Watt SP40L
Tinning tips
Flux the tip, heat the iron, apply solder all over the tip and wipe, while hot, the solder off with fine steel wool.
If the solder is flux core, no need for additional flux
Good Luck
Jan 27, 2009 | Weller SP175 12 - 1/2'' Marksman Extra...
Milwaukee Tool Weller Pyropen Jr Cordless Butane Soldering Iron WST2 Logo
798 people viewed this question
Top Milwaukee Tool Welding Tools Experts
Bill Boyd
Are you a Milwaukee Tool Welding Tool Expert? Answer questions, earn points and help others
