Question about AcerView 1555 Monitor
ACER Monitor Model 1555. red color gun is not working. After many hours of working it may start working and all colors are seen correctly. Some times the Monitor is slightly gets unfocussed. Please get me the solution.
  • 108 Answers
SOURCE: ACER LCD monitor no image, appears white color only
Quickly go to the Acer website and check FAQ's and while there also find out how to get an RMA to return it. My guess is you have a bad monitor. At $200 roughly for a replacement I would hustle. I am assuming you got nothing but a white screen but did get video on your TV.
Posted on Jan 24, 2008
freetek
  • 5568 Answers
SOURCE: screen flickers for about 20-30 seconds sporadically
Try looking at the LCD screen at a sharp angle to see if ghost-like video can be seen during the 'off' time of the flicker.  If video is still present even though not that visible, then either the backlight or its power supply are failing. The color problem could also be caused by a backlight lamp that is not ionizing completely.
Posted on Dec 14, 2008
SOURCE: Magenta vertical stripe sets plus grid dots problem
Staples office supply store said it was the monitor and, after buying and installing a new $200 monitor, I discovered it wasn't the monitor. I brought my hard drive to a reputable computer repair place, who charged me $50 total to install a new video card. He also supped up my hard drive with an additional 512K ram for $20 and now things are so much better. You were right! It was the video card.
Posted on May 15, 2009
Suricatta
  • 92 Answers
SOURCE: color on Acer 191w
Any of the 3 internal wires that delivers the tree color (Reg-Grenn-Blue) is disconected or damaged.
Open your monitor and try to locate that wires...
Good Luck
Best Regards !
Posted on Jun 24, 2009
  • 14 Answers
SOURCE: Monitor colors are not displaying correctly
Hi, At the worst it is a blown monitor, but have hope. 1st try a new or known good lead, between monitor and PC. 2nd put monitor with own lead on good PC. if 1st works = result. if 2nd and monitor is same, suspect monitor, however, if 2nd works ok on other PC, then look at ur vid card. Either way, this test sequence should save you some $. Be lucky.
Posted on Aug 25, 2009
My dell 1201 projectors displays only in yellow
you have most likely lost 2 of your color guns, most projectors have RED, Green and BLUE as the projector colors (some newer projectors have added a 4th color). if one of your color guns has gone out, you may experience colors that are not correct. that is where I would start. go to the convergence routine, in your setup menu. this is where you can determine if one of your "guns" has quit working.
Mar 23, 2011 | Dell 1201MP Projector
My monitor turns yellowish i can still work what is the problem. the monitor is a Acer V233H
The red "gun" of your CRT monitor is going bad. You will need to get a new monitor, and you should seriously consider an LCD flat screen. It will save you allot in electricity.
A CRT monitor is a very cool piece of technology inside... even though they are going obsolete with the advent of modern LCD displays.
In every CRT (Cathode Ray Tube) monitor, there is a trio of "Electron Guns"- they fire electrons at the front of the screen, hitting it with billions upon billions of electrons... the "bullets". Each gun is aimed at a set of colored targets, called "pixels"... one gun hits red ones, one for green, and one for blue. Combinations of these colors make up everything we can see.
When the red "gun" cannot fire enough electron "bullets" at the screen, the blue and green together make the picture appear yellowish.
If you want to learn more, look up "cathode ray tube" on wikipedia for starters!
A word of warning- the technology is very cool (I used to teach how CRT screens worked as part of my job teaching Missile fire control radar for the Navy), BUT:
THERE ARE VERY HIGH VOLTAGES INSIDE A CRT MONITOR THAT CAN KILL!!! DO NOT OPEN
THE CASE!!!!
Remember- the electron "guns" inside are shooting billions and billions of electrons at the front of the screen. They are being collected from the screen by a high voltage "supply". Most CRT's operate with anywhere from 15 to 45 THOUSAND VOLTS!
Feb 10, 2011 | Computers & Internet
MY MONITER CHANGES COLOR AND ITS PISSING ME OFF HOW CAN I DO IT. IT ALWAYS CHANGES COLOR MOST OF THE TIME IT CHANGES TO RED COLOR
One or two of your color guns are failing. On a CRT, there are three color guns, Red, Green, Blue. They work together to produce all colors in the spectrum. If the monitor goes all one color, it generally means at least one color gun is failing. The cost to repair far exceeds the value of the monitor or the price of a new LCD panel.
Mar 11, 2010 | HP Pavilion MX70 17" CRT Monitor
Aug 15, 2009 | Acer AL1916W 19" LCD Monitor
Red color missing in LCD monitor
if under warranty contact the manufacturer for repairs. otherwise you'd be in the market for a new monitor.
Also check your graphics card. Might be causing the problem rather than your monitor.
Jul 14, 2009 | Acer 22" X223w LCD Monitor
Text color is not consistent on Acer 191 monitor
THE SITTINGS MAYBE ON THE SIDE OF THE MONITOR HALF WAY DOWN OR HALF WAY UP. MODE OPTION, ACER MAY ALSO REQUIRE A SOFTWARE SETTINGS ALSO JUST NOT SURE WITH ACERS SETUP
RODGANDYSR
Mar 07, 2009 | Acer P191WBD LCD Monitor
Screen flickers for about 20-30 seconds sporadically
Dec 14, 2008 | Acer AL1912B 19" LCD Monitor
Jan 11, 2008 | Acer AL1916W 19" LCD Monitor
One of the primary color is absent
Hey Kuld.. Just asking... since both, your TV and your monitor have the same color issue...??.... have you been to the optometrist lately... (My Dad had this color issue with his eyes!).. he was red color blind..
Good luck,
Jun 20, 2017 | LG Studioworks 700B (White) 17 in.CRT...
AcerView 1555 Monitor Logo
27 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
