Oil boiler wont fire up - Heating & Cooling
    Sergeant:
  • 259 Answers
Make sure the electrodes are set properly for your burner. Make sure you are getting oil to the burner by opening up the bleeder on the pump after you press the safety switch to start the furnace. Take the screw out of the transformer and lift it up then hold a screwdriver on 1 of the springs and bring the tip of the screwdriver about 1 half inche from the other contack spring to see if the transformer will spark.
Posted on Mar 24, 2011
Boiler ries to fire on heating or hot water but then shuts down after 10 seconds to F1 with the flashing red light, any ideas. clearly same principle as any boiler but I'm looking for someone who has...
that would indicate that the boiler is not firing up
If oil fired, been there done that
it is out of oil
the oil filter is clogged
the nozzle could be clogged/burned
the igniter wires need adj/replacement
if gas fired - similar issues but no experience
Dec 08, 2014 | Water Water Heaters
I need to turn the temperature down on my Hydrotherm oil-fired burner. How do I do that?
On the front of the unit on the upper right is a grey box. Remove cover. Inside there should be a notched steel dial to adjust the water temperature.
Hope this helps.
Bob
Mar 04, 2014 | Hydrotherm Boiler, Oil Fired - PB-105/120W
Wiring Diagrams
Check out this site
www.peerlessboilers.com/Products/ResidentialBoilers/
SeriesWBVWV/tabid/118/Default.aspx#dnn_relateddocuments
Oct 18, 2013 | Peerless WV-DV-04, Oil Fired, Hot Water...
Where do i adjust boiler temp on a gas fired boiler
difficult to say just where the temperature control is on your system. it will likely be an immersion type control located some on or near the boiler. it should have a temperature range scale on it.
Jan 25, 2013 | Heating & Cooling
Alpha 240e boiler wont fire up for hot water, will for heating
most likely the diverter valve.. when hot tap turned on the movement of the water through the valve operates a diaphragm which pushes a pin/button//switch to tell the boiler to fire up
Aug 21, 2009 | Water Heaters
Boiler makes twitching sound and doenst stay on
If the boiler uses oil (#2 fuel diesel); there are several factors that could cause this problem:
* Lack of oil due to clogged oil filter or restricted oil line.
* Cad resistance greater than 1500 ohms.
* Defective Primary control.
* Shoot accumulated on the retention head.
* En pinching flame in combustion chamber.
* Collapsed combustion chamber into firing range.
* There are other reason not listed here.
* Some problems require expensive testing equipment to make an accurate diagnosis.
* Get in touch with an oil burner technician with several years of experience. I have a license to practice in the state of Massachusetts. My number is 978-5443783
Mar 05, 2009 | Water Heaters
Oil fired boiler
Check how all three "on/off" sequences are programmed firsrt, then all other programmable options. Make sure sliders are in the sliders are in the correct possition. If it becomes more complicated than launching a space shuttle, reset it. Unless your house is a mansion keep it simple with just day and night modes. the money you save wont even cover the cost to fix the hole you punch in the wall trying to do fancy programming ;-D
Nov 24, 2017 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
