Question about Canon Office Equipment & Supplies
Paper jammed at the middle - Canon Office Equipment & Supplies
    Sergeant:
    Champion:
  • 207 Answers
Open the printer up, slowly pull the paper out, reset the printer and try it over, you won't damage it by doing this.
Posted on Mar 24, 2011
3 FLASHES POWER LIGHT COMMUNICATION PROBLEM
Power light blinks slowly
The printer is out of paper in the middle of a print job.
Load more paper. See "Loading paper" on page 20.
Power light blinks rapidly
There is a paper jam.
Clear the paper jam.
Aug 13, 2012 | Lexmark Z1300 InkJet Photo Printer
It says Paper Jam, but there is no paper jam anywhere what can i do
Torn pieces of paper while removing can jam your printer. Check the optical sensors in paper path. You will find these sensors in the middle or at one end of the paper path.
sonsunny
Jun 18, 2011 | Canon imageCLASS MF8180C All-In-One Laser...
Paper jam - I can see the jam, but don't know how to remove the paper.
Hello
Open the top cover of the printer.
If you can see the jammed paper, take one or more sheets of paper and pull them toward you.
While pulling the paper, press the RESUME button to turn the paper feed rollers.
If the paper needs to be fed in the opposite direction, release the RESUME button and then press it again.
If the paper is still jammed, turn the printer off or remove the power cord from the printer. Then turn the printer back on or plug the power cord in.
The printer will run through a reset cycle, which may clear the paper jam.
If the paper is still jammed or if several (8 to 10) sheets are jammed, take hold of a sheet in the middle of the stack using both hands.
With firm, even pressure, pull the sheet toward you.
Usually, removing one or two sheets from the middle of the stack will release the pressure and the rest of the stack can be removed.
Make sure no scraps of paper are left in the printer.
Close the top cover of the printer.
Try printing again.
Apr 16, 2011 | HP PSC 750 All-In-One InkJet Printer
Paper jammed - how do I get it out?
  • Follow the below steps to clear the paper jam
    Clear any loose paper from the paper tray. This will help you locate the jam. You will find it either in front, near the paper tray, or in the rear.
  • To clear a paper jam near the paper tray, grip the paper and pull it firmly but gently from the printer. If you find a stack of papers jammed, grab from the middle of the stack and pull.
  • For a rear jam, remove the back of the printer. When you find a free edge on the paper, grip it firmly and pull it out.
  • Replace the back cover. Press the "Resume" button or turn off the printer, and then turn it back on. Your settings should reset.
  • Try printing another document.
  • Nov 05, 2010 | Epson Stylus Multifunction Inkjet Printer/...
    Printer gets jammed in the middle of printing
    My printer get jammed with a thick paper. I cannot see where the paper is.
    Jan 23, 2010 | HP LaserJet 1320 Printer
    Not printing in the middle of the page, suspect a paper jam. How to get whatever is in the middle out!! when you open the front door - not sure what screws to take out.
    a paper jam will not stop this from printing only in the middle? make sure it is the same for all colors , not printing in the middle. if all colors are not printing in the middle. you may need your mc cleaned. **** glass cleaned, pcu replaced, transfer belt unit replaced. also make sure the problem occurs from memory as well as copies, you can ruleout hdd and scanner then.
    Oct 29, 2009 | Ricoh Aficio 1232C Color Copier
    Middle light blinking message says paper
    Look for any small rips of paper caught in a sensor back there. There are little "fingers" that the paper runs over and its all timed. if one of those sensors are jammed with something or sticky, error messages.
    Sep 22, 2009 | HP DeskJet 550c InkJet Printer
    Paper jam --samsung SCX-4828FN
    i found that paper jam was in the middle of the mechine. i opened the front door and removed papers.
    Sep 17, 2009 | Samsung SCX-4828FN All-In-One Laser...
    Paper jam
    take out cartridge and force paper to take out sometimes it is needed to tear paper to take it off but no problem, main sensitive for this type of printers is cartridge, also find if any "jam lock" is presented to ypur printer and unlock.
    Aug 01, 2009 | Brother HL-2070N Laser Printer
    Printer stopped working Epson C86 and red middle light button on
    The red middle light is the paper feed indicator. If it is on, it means the paper feed is (or the computer thinks it is) jammed. Remove all paper from the hopper and make sure all bits of paper are removed from the feed mechanism. Press the paper feed button (the middle one) a few times during this process to try to feed through any jammed pieces. If this doesn't work, you have an internal jam or broken feed system, or your main board has gone haywire.
    Any further investigation requires you to remove the printer top cover, which you may or may not feel like tackling. If you don't, take your printer to a technician, or sell it on E-Bay for what you can get. If you do, post a new comment to this effect and I will provide a tutorial on removing the top cover. It's not difficult if you know how.
    Apr 10, 2009 | Epson Stylus C86 InkJet Printer
    16 people viewed this question
    old marine
    old marine
