Question about Canon ImageRunner 3025 Black and White Copier
I have canon gp335. The asterisk key is not functioning thats why i cant go on fixing some ajustment *28* What should i do please help me thank you. Larry
  • Canon Expert
  • 270 Answers
You're going to have to replace the control panel. Take apart the control panel to see if the key can be repaired. Good Luck.
Posted on Jun 21, 2011
How to go service mode Cannon ir 400 ?
Here is the error code page http://www.scribd.com/doc/56428927/iR-400-Code-List
And here is the service manual
http://www.scribd.com/doc/135167936/canon-Ir-400-Service-Manual
Looking at what the error is, getting into the service mode will not allow you to fix it; you have some parts to replace first.
Jul 20, 2014 | Cannon Office Equipment & Supplies
Code E000001-0004 what is this code and how to fix.
this is error for abnormal rise of temperature, if it is not seriuos ( I mean nothing faulty ) you can reset it in service mode.
Procedure:
While the copier in copy ready or showing error:
1) Press the asterisk key " * " on the control panel.
2) Press the 2 and 8 keys of the keypad at the same time.
3) Press the asterisk key " * " on the control panel.
Choose:
COPIER
FUNCTION
CLEAR
ERR
Hope that helps!
Aug 23, 2011 | Canon imageRUNNER iR C4080 Color Copier
the E001-004 means that fixing unit is overheating and you have abnormal raise of temperature.
You can try to reset / clear the error in service mode:
1) Press the asterisk key (*) on the operation panel.
2) Press 2 and 8 simultaneously on the numeric keypad.
3) Press the asterisk key (*) on the operation panel.
Choose:
COPIER-FUNCTION-CLEAR-ERR, then turn it off and back on.
If this doesn't help's you, you need to chnage the fixing assy.
Aug 07, 2011 | Canon imageRUNNER C3220 Color Copier
Error E000001-0004
The E001-004, means:
The difference in temperature between the
non-contact thermistor and the end thermistor
remains 80°C or more for 500
msec.
... so, that means, that you have trouble in fixing assy.
You can try to reset the error code in service mode.
1) Press the asterisk key ( * ) on the operation panel.
3) Press the asterisk key ( * ) on the operation panel.
The initial screen now appears.
Select:
1) Select this item, and press the OK key.
2) Turn the main power OFF/ON.
If still after the clearing procedure, error still persist, You need to replace the fixing assy.
Hope that helps!
Jul 24, 2011 | Canon imageRUNNER C3200 Copier
How do i reset my canon IR2010f copier to facory defaults
Hi steve363,
Please follow the steps below to reset the unit to factory default.
1. Go into service mode. (*28) "Function" - "Clear". To get into service mode you might need to push "Additional Function" key. *AD>28 simultaneously and *AD again.
2. There should be an option under the clear menu for "pwd-clr".
3. Highlight it and then press OK.
4. On reboot the ID screen should have gone.
5. If not under the clear menu, please try MN-CON, that will clear the main controller.
Hope it helps.
Thank you for using FixYa.
Jul 11, 2011 | Canon Office Equipment & Supplies
Canon ir2870 error code e000002
these means that in fixing assy is low temperature. It can be that you only need to clear the error trough service mode, or you need to change thermistor.
To clear the error:
enter the service mode:
3) Press the asterisk key " " on the control panel.
then choose COPIER, then FUNCTION, then CLEAR and choose ERR. Shut down and back ON the copier.
If these doesn't helps, replace thermistor which is inside of fixing film ceramics.
Jun 12, 2011 | Canon Office Equipment & Supplies
Error code E000002-0000
Get in the service mode *28* and there under function, clear, err.
If not replace the fixing film unit
Jan 02, 2010 | Canon (6981A002AA) for imagerunner 2200,...
Canon ImageRunner 3025 Black and White Copier Logo
old marine
old marine
