Question about IBM (01N1941) Motherboard
Board is on but display is not appear on monitor
  • IBM Master
  • 27,725 Answers
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Posted on Mar 24, 2011
No monitor display, power okay
Test with an external display. If nothing, there may be a GPU issue.
Jan 31, 2014 | HP Compaq 6735s Notebook
Monitor image is "posterized"...red,yello, blk and white only
you have defective RGB circuit, or re solder all CRT Board maybe you have lost contact at the RGB CRT Board. RGB means red, green, blue. CRT means Cathode Ray Tube.
Oct 08, 2007 | Apple Studio Display 17" CRT Monitor
Delayed display
Capacitors on the power supply board and the back lite control board may be going bad. Look on the top of each one to see if they are not flat. Any that look puffy are bad.
Jan 28, 2014 | Samsung Computers & Internet
Suddenly a very thin vertical yellow/white line appearing on my HP desktop monitor? pls help
Does it appear THE MOMENT you turn the unit on?
If it does, then you will have to run the monitor's self-test function by turning it on with the data cable (the one that does NOT connect to the power outlet) DISCONNECTED from the computer.
If the line still appears, then the monitor is faulty & cannot be "repaired". Usually, the entire LCD module is replaced.
If the line does not appear in the self-test mode, then check if it's connected to an ON-BOARD display adapter (typically found in the back of the machine, towards the middle area, towards where the ethernet cable and USB devices plug in) or a EXPANSION CARD (normally located towards the BOTTOM part in the back of the machine).
If it plugs in to the on-board slot, then the motherboard may be faulty. If it plugs in to an expansion card, then it's the card that may need to be replaced.
Of course, these are merely possibilities, but the most likely failing component here is the monitor itself. Busted display adapters very rarely, if at all, manifest these horizontal or vertical lines and STILL boot up. Regardless if it's on-board or expansion card, a failing display adapter would normally have either no display at all, or it would just simply stop booting up (screen remains dark: no lines).
Aug 12, 2011 | Computers & Internet
Display is not working no details
As you have not mentioned any model of Apple Laptop.Assuming Mac Book Pro 15 " as viewed in the picture.Connect the laptop with external display using DVI to VGA converter and power on the laptop.If the display appears in external monitor,that means the issue is with LCD Panel or may be the LVDS cable is faulty.If stil there is no display in external monitor then the issue is with Logic board. Also check weather the startup chime is appearing or not.If the startup chime is not there, replace the ram with a good one and check.If the issue is with logic board , display or Ram then you have to replace the pirticular par.
Apr 07, 2010 | Apple PowerBook G4 Mac Notebook
On screen display keeps appearing on, and usually
hi..i think you have a problem the CPU/Computer that's whystays on screen for so long.1st step check the IDE cable connection form the mother board to Hard Drive and 2nd check the memory or check all hardware`s.Good Luck and Have a nice day
Jun 17, 2009 | HP mx705 17" CRT Monitor
LG Monitor Display Problem
1. Mostly Loose contacts in video section that means CRT Neck board dry points checke it.
2.Pl check VGA Cable RGB signal pins 123 to ground 75 Ohms (on OK condition).
3.check 5v supply
4.check SDL and SCL signals.
Oct 05, 2008 | LG Studioworks 563N 15" CRT Monitor
No display, clipping sound appear
The clipping sound is the internal safety switch that keep shutting down the monitor.
It means there is an internal problem on the main board (overvoltage, bad component , short).
Try unplugging power cord and leaving it unplugged two or three hours, this will reset ICs by draining power completely from circuits, it is called hard reset, it rarely works.
CRT monitors waste up to 15 times more energy than TFT screen, if your CRT starts giving troubles, then it is a good time for upgrading it to a new TFT.
17'' start at $120
17'' Dell 1703FPt DVI LCD Monitor w/USB Hub (Black/Silver) -B
171ABB 17" Widescreen LCD Monitor - 1440x900 (WXGA+),
Envision H716A4 17 in. LCD Monitor
19'':
19'' Princeton VL1919 DVI LCD Monitor (Black)
19'' panoramic
V7 Series D19W12 19" Widescreen LCD Monitor
Sep 10, 2008 | ViewSonic E70f 17" CRT Monitor
PC monitor not lighting up for around 10 mins
Check the capacitors on the power supply board inside the monitor. They malfunction, heat up, leak or pop and stop doing what they are designed to do, smooth out the power supply to the inverter and display board. You can replace these simply by buying the correct farrad, voltage and temperature rated replacements online for about .30 a piece or go to radio shack and spend 1.50 a piece. You can use a higher voltage like 35V instead of 25V but try and get the 105c rated ones to last longer in the hot P/S environment. My bad ones were 470 micro farrad, 25V and 105c rated and I had 4 out of 8 pop or bulge.
Apr 08, 2008 | Computers & Internet
Where Dell Flat screen 15" monitor has not been used for a period of time or on boot up the screen displays for a seond then goes black (although in a certain light you can see the icons and programs...
You most likely have a bad connection inside the unit. Specifically, there are a couple of "backlights" that provide the light that will pass thru the LCD panel. If you can open up the unit, with the screen facing up, there should be a small PC board on the right. Check the connections on that board. Be careful as there is high voltage there.
Keep us posted.
Dan
IBM (01N1941) Motherboard Logo
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
