Question about Compaq Computers & Internet
I have compaq presario V6500 which service tag no is V6604AU problome is when push on power on button then for a second all blue LEDs blink then imediatly system off.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Compaq Master
  • 2,226 Answers
Check the board caps to see if there are any mushroom up if so board bad jim look at the x on the tops
Posted on Mar 24, 2011
I have a HP Pavilion tx 2000 tablet pc. When i turn it on the power button it shows that its on. The hard drive light does not flash and the caps lock and the number lock button keeps on blinking. My...
Hi
Boss you need to mention here in what sequence do the lights blink.
Anyways you can take help from this
Caps Lock/Num Lock LED Component Tested Error Condition LEDs blink 1 time CPU CPU not functional LEDs blink 2 times BIOS BIOS corruption failure LEDs blink 3 times Memory Module error not functional LEDs blink 4 times Graphics Graphics controller not functional LEDs blink 5 times System board General system board failure LEDs blink 6 times BIOS BIOS authentication failure
DO RATE MY SOLUTION
Jul 04, 2011 | Compaq Presario Notebook
My hp compaq Presario V6500 has been damaged and a computer dude in Bathurst NSW said we need a bulb replaced in the screen as it won't light up. Computer functions via TV. R there any local repairers for...
The monitor screen on your laptop is an LCD screen.
An LCD screen cannot produce enough light by itself. It needs an additional light source.
The additional light source is a Backlight.
A Backlight is a CCFL.
Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes and businesses, but on a MUCH smaller scale.
LCD screens are a composite of layers. The layers are held together by a metal frame, much like a picture frame.
The Backlight is usually located on one side, accessed after removing one side of the metal frame.
As stated, a Backlight is a very small type of Fluorescent lamp, (Tube)
Very fragile, easily breakable, and not usually approached by one who has very little, or no experience in replacing.
More common the entire LCD screen is replaced, which includes the Backlight already installed.
A laptop also needs an Inverter to provide power, both for the LCD screen, and the Backlight.
90 percent of the time the fault is the Inverter.
I repeat, 90 percent of the time the fault is a bad Inverter.
An Inverter is cheaper than an LCD screen, and MUCH easier to replace than a Backlight.
Allow me to show you replacing an Inverter on an HP Pavilion dv6000 series laptop.
Granted, it isn't an HP Compaq Presario V6500 series, but the principles still apply the same,
http://www.insidemylaptop.com/remove-replace-lcd-screen-inverter-hp-pavilion-dv6000-laptop/
I can also provide a free link, to the Service Manual for an HP Compaq Presario V6500 laptop, direct from HP Support,
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&lang=en&product=3369429&
In the list click on;
Compaq Presario V6500, V6600, and V6700 Notebook PCs-Maintenance and Service Guide
This is a PDF file.
Allow up to 30 seconds to see the first page, and an additional time may be needed to fully download.
In the Bookmarks menu on the left click on the + sign next to;
1) Removal and replacement procedures
2) Component and replacement procedures
3) Display assembly
And/or go directly to Page 61 to view the Inverter location.
One example of an Inverter for an HP Compaq Presario V6500,
http://www.sparepartswarehouse.com/Compaq,Presario,V6500,Laptop,Inverters.aspx
Granted this is not what you asked for.
My premise is to teach, and hopefully save people money.
If you have additional questions please state in a Comment.
Regards,
joecoolvette
Mar 06, 2011 | Compaq 449901-001 - HP Presario V6500...
Blue screen after I have done system restore on compaq presario CQ60. I have tried F8 on start up to run in safe mode but nothing seems to starp the blue screen on start up now.
Welcome to FixYa
Dear user
Perform a Hard Reset first.
Disconnect devices including USB devices and media cards. Disconnect the AC power adapter, remove the battery Press and hold the power button 15 seconds . connect the power adapter -do not connect the battery- Press the Power button, Look for blinking LEDs near caps lock and num lock keys, and Listen for sounds of a disk drive and fan turning.
Hope this helps...Thanks for Connecting FixYa...
Dec 04, 2010 | Compaq Presario Notebook
Compaq presario f560us will not come to life
It is due to one or more faulty components on the motherboard. You have nothing to do unless you are a laptop technician.If you can do chiplevel repairing I can further assist you as I am a chip level technician.Contact me. Make a comment for this.
Mar 08, 2010 | HP Compaq Presario F560US Notebook
Compaq Presario CQ45 screen remains blank... help
Open the Notebook from the back side and locate the RAM. Now remove the RAM and place it again and check, you can even try inserting the RAM in different slot if any used slot is available.
Check out.
Feb 12, 2010 | Compaq Presario Notebook
Video and lan driver for compaq v6500
i need all drivers of compaq presario v6500.. pls... help me!!!!! thanx
Jan 30, 2009 | Compaq Deskpro EN 6500+ Model 6400 CDS PC...
Window xp driver
kothiya,
Here's the link for all the driver u need,
http://www.zyxware.com/articles/2007/12/17/compaq-presario-v6604au-laptop-drivers-for-windows-xp
Have fun.
Don't forget to rank my solution ya, thanks!!!
Jan 12, 2009 | HP Compaq Presario V6620US 15.4" Notebook...
Compaq presario v6604AU window xp all driver
Go to the Compaq/HP WEB site, the to the support/download page and download the XP device drivers for your model laptop.
www.compaq.com
Jan 12, 2009 | Computers & Internet
Computers & Internet Logo
180 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
