Question about HEWLETT-PACKARD Hewlett Packard HP G62228NR XB066UA Notebook Athlon II P320 210 GHz 156 3 GB DDR3 SDRAM 500 GB HDD DVDWr (XB066UAABA)
I just need to know the max speed of my network card and physical address of the network card. Can u help me fin it or tell me where to find it?
    Master:
  • 346 Answers
Hi - Your laptop contains two network adapters. The wired adapter is a Gigabit Ethernet card and the wireless (WiFi) is a 802.11g (54 Megabit) device.
To find out the physical addresses of both, In Windows click on the Start Menu then Run, a text box will appear, type in cmd then hit Enter and when the white text on black screen appears type ipconfig /all and hit Enter. On the left side of the screen will appear the words Physical Address and to the right will be the 12-character physical address. There will be such a column for both network cards.
Thanks for using Fix Ya.
Mikeywaf
Posted on Mar 24, 2011
  • 158 Answers
Start>Run>Cmd press enter on the command prompt type ipconfig /all you should have the physical address of your adapter
My camera won't accept it.What doI need to do?
It may be a correct physical size (SD card) but other factors also matter
- un-supportted file system (SDXC is exFAT)
- max addressable space (gb) by the device
- support speed (Class #)
see Speed Class SD Association
- higher processors for Ultra Hi Def recording at higher frames will need higher speed
My suggestion is
(a) verify if your camera has a newer firmware that could support high capacity. if not...
(b) do not format on the camera because it may limit it in size.
(c) use this 64gb on other device like laptop.
(d) sell it on ebay
Prefer newer memory format like MicroSD with microSD adaptor/ holders
Apr 11, 2016 | SanDisk 64GB Ultra SDXC Card
Tip
Protect your ADSL bandwidth and download speeds from your naughty neighbours
This is very simple and will work with most routers that use DHCP to lease the LAN IP addresses to you Home Network, it will work for Wired (Ethernet) and Wired (54g) network cards.
Most third party Routers can be set up not to use either a WEP or WPA-PSK so this is a simple and effective alternative if you struggle to get this type or security to work, if you have a bundled router like SKY with the Sagem and BT with their Netgear home hub then the WEP key will be on the bottom so its easy to use this.
The first step is to goto your admin panel usually 192.168.0.1 you will need to change the admin password from the default to one you will remember this stops anyone else undoing these changes.
You will need to find your MAC addresses for all the PC's and print servers that you will use on your home network. The easiest way to do this is to goto the command prompt and type
c:ipconfig /all
It will also show the MAC or physical addresses of all you connections, shown here is also a Belkin 10m bluetooth adapter.
However you can also do this by going to the Control Panel, Network Connections icon, double click it to show on your physical NIC the MAC address will be a long number in hex-decimal under the details button
click on details an it will show you the Physical Address (MAC) for your network card. it will be in the form of a 12 digit number with either colons or minus signs separating the hex-decimal number XX-XX-XX-XX-XX-XX
You will notice that the IP address 192.168.0.2 has already been leased to the NIC from the routers DHCP server.
The example below is for the SKY Broadband Black Sagem Router just goto the corresponding menu for you router
In this example the IP address 192.168.0.4 has been given an address reservation to allow a Standard IP Printer Port to be used for all wired PC's on the home network. Check out my other Tip for setting up a wireless printer for use with wired computers on you home network for more detailed help.
http://www.fixya.com/support/r3559234-set_up_a_wireless_printer_on_your_router
on Jan 16, 2010 | Computers & Internet
What is mac address?
A Media Access Control address (MAC address) is a unique identifier assigned to network interfaces for communications on the physical network segment. Logically, MAC addresses are used in the Media Access Control protocol sub-layer of the OSI reference model.
MAC addresses are most often assigned by the manufacturer of a network interface card (NIC) and are stored in its hardware, the card's read-only memory, or some other firmware mechanism. If assigned by the manufacturer, a MAC address usually encodes the manufacturer's registered identification number. It may also be known as an Ethernet hardware address(EHA), hardware address, adapter address, or physical address.
Hope this information will help you.
Sep 20, 2010 | Computers & Internet
I added a new Intel PWLA8391GTBLK Gigabyte Network
Most likely your internet provider is MAC based - which means that the internet connection is tied to the distinct identity of the LAN card. You will have to call your ISP and tell them about that, to make the appropriate modifications for your new LAN card.
How you can find your new MAC: Start > Run > type -  cmd - > Enter and  new command window will open > type -  ipconfig /all  - > the MAC will be displayed in Physical address, write it on a piece of paper, the ISP will ask you about it.
May 07, 2010 | Dell Dimension 8200 PC Desktop
I'm trying to set up wireless internet for a laptop (Dell Latitude CPi) that was just given to me. The card is a TDK Global Freedom 5660 v.90. My router wants to know the 12 digit MAC address and I don't...
You can display the MAC address and the IP address of your network card by click on Start - Run - type cmd and press Enter.
This will open a DOS command window - type ipconfig /all then press Enter The MAC address will be displayed as a Physical address.
Jan 27, 2010 | AB Soft TDK Global Freedom 5660 Modem
Can't find my MAC address
Hi, here is a solution for your problem: Obtaining your MAC address
Your MAC address will normally be on the box or registration card for your computer or individual ethernet card. If you can not find it, please follow the instructions below depending on your operating system.
Windows Vista:
  1. Click on Start Button.
  2. Click on All Programs.
  3. Click on Accessories.
  4. Click on System Tools.
  5. Click on System Information.
  6. Click on plus sign in front of Components.
  7. Click on plus sign in front of Network.
  8. Click on Adapter.
  9. Scroll down to your Network Interface Card and it will list the MAC Addresss. (Make sure you do not get the wireless adapter).
WINDOWS NT, 2000, or XP:
  1. Using your mouse, click on the Start Button.
  2. Click on Programs.
  3. Click on Accessories, and then Command Prompt.
  4. Once a small black window appears, type in ipconfig /all (with a space between the g and the /).
  5. Locate the number to the right of Physical Address. This is your MAC address.
WINDOWS 95/98/ME:
  1. After clicking on the Start Button, click on Run.
  2. In the white space of the window, type in the word winipcfg
  3. Click on "OK".
  4. Look under the info for the Ethernet adapter. (Your system may also have a modem.)
  5. The number next to "Adapter Address" is your MAC address.
Hope this helps.
May 10, 2009 | Computers & Internet
Edit MAC Filter List
mac is the address in hex of a network card. To get the mac of a network card: go to command line (windows machine) and type the command ipconfig /all. The mac address is the physical address. It will be in the format of 00-00-00-00-00-00, where the 00's are letters and numbers (hex 0-F) To use this you would take the mac address from your wireless card of your computer and enter this number into the mac address filter table of your router. The idea here is when a computer tries to connect to your router, it looks at the table, if the address in not in the table, no connection. Please remember devices only understand what you give them so a typo is not your device....
Feb 28, 2009 | Gateway Wireless-B Router (wbr-100)
I have Parker Vision USB1500Wireless PC LAN adaper. It just keeps searching for the network, but i know the network is working because i have a belkin PC Card adapter and it connects.
In the router that you are trying to connect to do you know if it has an Allowed Mac Address section.
Depending on how the router is configured you may need to set the mac address of your wireless adapter to be allower on your network.
To find out the mac if its not on the adapter.
Go to Run - CMD. Type Ipconfig /all
The mac address is called the physical address and should be 12 characters with - inbetween.
Jan 06, 2009 | Computers & Internet
I have a netgear router and have a laptop hooked up to it and working but I when I have my desktop hooked up to it, the computer won't let me go online. I have an HP Compaq Presario and I also noticed that...
The most likely culprit is the cable you are using to connect the desktop to the router.
The networking icon with the red X is your computer telling you the network card is not physically connected to a functioning port. Either the cable is bad or one of the ports (your computer's or the router's) has a physical or electrical problem. Try using the laptop cable and/or connecting to the port the laptop is connected to.
If the problem is something else, it is likely more information will be needed to diagnose and fix it (router model, OS version, whether a DHCP server is running, the network address of the router, the exact type and text of the icon that's telling you the network is disconnected).
Wireless
go to command prompt
star->run
type cmd
then type in c:\arp -a
and it will show your address connect in your network
then check the physical address if belongs to your device
if not familiar with the physical address then someone is hijacking your connection
Nov 19, 2008 | Siemens Efficient Networks SpeedStream...
HEWLETT-PACKARD Hewlett Packard HP G62228NR XB066UA Notebook Athlon II P320 210 GHz 156 3 GB DDR3 SDRAM 500 GB HDD DVDWr (XB066UAABA) Logo
93 people viewed this question
Top HEWLETT-PACKARD Computers & Internet Experts
john smith
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
